查看: 1410|回复: 0
[每日一码] 计算选取曲线的总长度
发表于 2018-1-7 20:21:31 | 显示全部楼层 |阅读模式
  1. (defun C:GetLength ( / CurEnt CurLgt CurObj CurSet FltLst ObjCnt TmpLgt)
  2. (if (< (atof (getvar "ACADVER")) 15.0)
  3.   (alert "GetLength requires AutoCAD 2000 or higher. ")
  4.   (progn
  5.    (vl-load-com)
  6.    (setq FltLst '(
  7.                   (0 . "ARC,CIRCLE,ELLIPSE,LINE,LWPOLYLINE,POLYLINE,SPLINE")
  8.                   (-4 . "<NOT")
  9.                    (-4 . "<OR")
  10.                     (-4 . "&=") (70 . 16)  ;3DMesh
  11.                     (-4 . "&=") (70 . 64)  ;PolyFace
  12.                    (-4 . "OR>")
  13.                   (-4 . "NOT>")
  14.                  )
  15.          CurLgt 0.0
  16.    )
  17.    (if (setq CurSet (cond ((ssget "I" FltLst)) ((ssget FltLst))))
  18.     (progn
  19.      (setq ObjCnt (sslength CurSet))
  20.      (while (setq CurEnt (ssname CurSet 0))
  21.       (setq CurObj (vlax-ename->vla-object CurEnt)
  22.             TmpLgt (vlax-curve-getDistAtParam CurObj
  23.                     (vlax-curve-getEndParam CurObj)
  24.                    )
  25.             CurLgt (+ CurLgt TmpLgt)
  26.       )
  27.       (ssdel CurEnt CurSet)
  28.      )
  29.      (alert
  30.       (strcat
  31.        "Total length of "
  32.        (itoa ObjCnt) " object(s): "
  33.        (rtos CurLgt) " units. "
  34.       )
  35.      )
  36.     )
  37.    )
  38.   )
  39. )
  40. (princ)
  41. )
GMT+8, 2026-11-5 08:54 , Processed in 0.389536 second(s), 29 queries , Gzip On.
