查看: 1223|回复: 1
[每日一码] 删除图中的所有图片IMAGE
发表于 2018-1-9 00:04:09 | 显示全部楼层 |阅读模式
  1. (defun RemoveAllRaster (doc / _catchapply dict lockd)
  2.   (vl-load-com)
  3.   (defun _catchapply (method params / result)
  4.     (if        (not (vl-catch-all-error-p
  5.                (setq result (vl-catch-all-apply method params))
  6.              )
  7.         )
  8.       result
  9.     )
  10.   )
  11.   (vlax-for layer (vla-get-layers doc)
  12.     (if        (eq :vlax-true (vla-get-lock layer))
  13.       (vla-put-lock
  14.         (car (setq lockd (cons layer lockd)))
  15.         :vlax-false
  16.       )
  17.     )
  18.   )
  19.   (vlax-for block (vla-get-blocks doc)
  20.     (vlax-for object block
  21.       (if (member (vla-get-objectname object)
  22.                   '("AcDbOle2Frame" "AcDbRasterImage")
  23.           )
  24.         (_catchapply 'vla-delete (list object))
  25.       )
  26.     )
  27.   )
  28.   (if (setq dict (_catchapply
  29.                    'vla-item
  30.                    (list (vla-get-dictionaries doc) "ACAD_IMAGE_DICT")
  31.                  )
  32.       )
  33.     (progn (vlax-for object dict
  34.              (_catchapply 'vla-delete (list object))
  35.            )
  36.            (_catchapply 'vla-delete (list dict))
  37.     )
  38.   )
  39.   (if (setq dict (_catchapply
  40.                    'vla-item
  41.                    (list (vla-get-dictionaries doc) "ACAD_IMAGE_VARS")
  42.                  )
  43.       )
  44.     (_catchapply 'vla-delete (list dict))
  45.   )
  46.   (foreach layer lockd (vla-put-lock layer :vlax-true))
  47.   (vla-regen doc acallviewports)
  48.   (princ)
  49. )
  50. (defun c:RemoveAllPics nil
  51.   (RemoveAllRaster
  52.     (vla-get-activedocument (vlax-get-acad-object))
  53.   )
  54.   (princ)
  55. )
发表于 2018-1-12 11:03:09 | 显示全部楼层
谢谢分享谢谢分享谢谢分享谢谢分享谢谢分享谢谢分享谢谢分享谢谢分享谢谢分享谢谢分享
GMT+8, 2026-11-5 12:24 , Processed in 0.364176 second(s), 31 queries , Gzip On.
