查看: 1281|回复: 3
[每日一码] 打印窗口到DWF文件
已领礼包: 20个
发表于 2018-1-28 19:00:12 | 显示全部楼层 |阅读模式
  1. (defun c:testPlotWindow        (/             acadObject         acadDocument
  2.                          activeLayoutObject         plt
  3.                          p1             point1         pPt1
  4.                          pPt1sa             pt1         p2
  5.                          point2             pPt2         pPt2sa
  6.                          pt2
  7.                         )
  8.   (vl-load-com)
  9.   (setq acadObject (vlax-get-Acad-object))
  10.   (setq acadDocument (vla-get-ActiveDocument acadObject))
  11.   (setq activeLayoutObject (vla-Get-ActiveLayout acadDocument))
  12.   (setq plt (vla-get-plot acadDocument))
  13.   (vla-put-configname activeLayoutObject "DWF6 ePlot.pc3")
  14.   (vla-put-canonicalmedianame
  15.     activeLayoutObject
  16.     "ISO_full_bleed_A3_(420.00_x_297.00_MM)"
  17.   )
  18.   (vla-put-paperunits activeLayoutObject acMillimeters)
  19.   (vla-put-plotrotation activeLayoutObject ac0degrees)
  20.                                         ; How to control the Plot Style Table
  21.                                         ; (vla-put-StyleSheet activeLayoutObject "HP LaserJet 4MV.ctb")
  22.   (setq p1 (getpoint "\nSelect Window Point No 1 (Lower Left): "))
  23.   (setq point1 (list (car p1) (cadr p1)))
  24.   (setq pPt1 (vlax-make-safearray vlax-vbDouble '(0 . 1)))
  25.   (setq pPt1sa (vlax-safearray-fill pPt1 point1))
  26.   (setq        pt1 (vlax-make-variant
  27.               pPt1sa
  28.               (logior vlax-vbarray vlax-vbDouble)
  29.             )
  30.   )
  31.   (setq p2 (getpoint "\nSelect Window Point No 2 (Upper Right): "))
  32.   (setq point2 (list (car p2) (cadr p2)))
  33.   (setq pPt2 (vlax-make-safearray vlax-vbDouble '(0 . 1)))
  34.   (setq pPt2sa (vlax-safearray-fill pPt2 point2))
  35.   (setq        pt2 (vlax-make-variant
  36.               pPt2sa
  37.               (logior vlax-vbarray vlax-vbDouble)
  38.             )
  39.   )
  40.   (vla-SetWindowToPlot activeLayoutObject pt1 pt2)
  41.   (vla-put-plottype activeLayoutObject acWindow)
  42.   (vla-plottofile plt "c:\\test.dwf" "DWF6 ePlot.pc3")
  43. )
已领礼包: 6468个
发表于 2018-1-29 00:05:47 | 显示全部楼层
抢个沙发。支持楼主。
已领礼包: 4044个
发表于 2018-1-29 08:15:27 | 显示全部楼层
回复学习学习!
已领礼包: 347个
发表于 2018-1-29 08:44:57 | 显示全部楼层
牛!牛!牛!牛!牛!牛!牛!牛!
GMT+8, 2026-11-5 08:00 , Processed in 0.348719 second(s), 35 queries , Gzip On.
