查看: 1468|回复: 1
[每日一码] 点是否在曲线内部(考虑了自交的曲线)
已领礼包: 13个
发表于 2018-1-31 10:13:06 | 显示全部楼层 |阅读模式
[C#] 纯文本查看 复制代码
public static void testPointInside(Point3d inPt, ObjectId objid)
    Database db = HostApplicationServices.WorkingDatabase;
    Document doc = acadApp.DocumentManager.MdiActiveDocument;
    Editor ed = doc.Editor;
    using (Transaction tr = db.TransactionManager.StartTransaction())
        Polyline pPoly = tr.GetObject(objid, OpenMode.ForRead, false) as Polyline;
        if (pPoly is Polyline)
            if (!pPoly.Closed)
                ed.WriteMessage("\n*** Curve is not closed. "); return;
            Point3dCollection points = new Point3dCollection();
            pPoly.IntersectWith(pPoly, Intersect.OnBothOperands, points, 0, 0);
            if (!points.Count.Equals(pPoly.NumberOfVertices))
                ed.WriteMessage("\n*** Curve self intersect!"); return;
            else
                Point3d P = new Point3d();
                P = Ucs2Wcs(inPt);
                Point3d ClosestPoint = pPoly.GetClosestPointTo(P, false);
                if (P.IsEqualTo(ClosestPoint))
                    ed.WriteMessage("\n*** Point is on curve. "); return;
                Double ClosestParam, EndParam;
                ClosestParam = pPoly.GetParameterAtPoint(ClosestPoint);
                ClosestPoint = Wcs2Ucs(ClosestPoint);
                EndParam = pPoly.EndParam;
                Double Param1 = 0.0, Param2 = dVal, Deflection = 0.0, a2;
                Point3d StartPT = pPoly.StartPoint;
                StartPT = Wcs2Ucs(StartPT);
                Double a1 = Math.Atan2(StartPT.Y - inPt.Y, StartPT.X - inPt.X);
                while (Param2 <= EndParam)
                    Param2 = Math.Min(Param2, EndParam);
                    if (Param1 < ClosestParam && ClosestParam < Param2)
                        a2 = Math.Atan2(ClosestPoint.Y - inPt.Y, ClosestPoint.X - inPt.X);
                        Deflection = Deflection + delta(a1, a2);
                        a1 = a2;
                    bool test = true;
                    while (test)
                        try
                            P = pPoly.GetPointAtParameter(Param2);
                            Param2 = Param2 + dVal;
                        catch (System.Exception ex)
                            ed.WriteMessage("\nERROR = " + ex.Message);
                        finally
                            test = false;
                    P = Wcs2Ucs(P);
                    a2 = Math.Atan2(P.Y - inPt.Y, P.X - inPt.X);
                    a1 = a2;
                    Param1 = Param2;
                if (Math.Abs(Deflection) > 4)
                    ed.WriteMessage("\n*** Point is inside. ");
                else
                    ed.WriteMessage("\n*** Point is outside. ");
        tr.Commit();
已领礼包: 3256个
发表于 2018-3-25 13:36:09 | 显示全部楼层
大哥 少了几个函数呀?
1、 Wcs2Ucs 世界左边转换到用户坐标函数
2、 dVal 变量不存在
3、 delta变量不存在
GMT+8, 2026-11-3 02:13 , Processed in 0.437206 second(s), 30 queries , Gzip On.
