查看: 2372|回复: 2
[每日一码] 关于Layer State 的工具和处理函数
发表于 2018-2-18 12:44:22 | 显示全部楼层 |阅读模式
执行state,可以对layer state进行保存、恢复、读入、输出、删除等操作。
  1. (defun C:State (/ tmp)
  2.   (initget "I X S R D")
  3.   (setq
  4.     tmp        (getkword
  5.           "\n* Layer States: [Import eXport - Save Restore - Delete]"
  6.         )
  7.   )
  8.   (initget 7)
  9.   (cond        ((= tmp "I") (LSImportIT))
  10.         ((= tmp "X") (LSXportIT))
  11.         ((= tmp "S") (LSSaveIT))
  12.         ((= tmp "R") (LSRestoreIT))
  13.         ((= tmp "D") (LSDeleteIT))
  14.   )
  15.   (princ)
  16. )
  17. ;;;
  18. (defun ARCH:State (/ tmp)
  19.   (setq tmp (layerstate-has (getvar "ctab")))
  20.   (if (= tmp T)
  21.     (LSRestoreIT)
  22.   )
  23.   (princ)
  24. )
  25. ;;;
  26. (ARCH:State)                                ;place in your acaddoc file
  27. (defun LSImportIT (/ tmp)
  28.   (setq        tmp (strcat (getvar 'dwgprefix)
  29.                     (vl-string-right-trim ".dwg" (getvar 'dwgname))
  30.                     " ctab-"
  31.                     (getvar "ctab")
  32.                     ".las"
  33.             )
  34.   )
  35.   (if (/= tmp nil)
  36.     (progn (princ (strcat "\n* Importing LayerStates to: " tmp))
  37.            (command "mspace")
  38.            (layerstate-import tmp)
  39.            (command "pspace")
  40.     )
  41.   )
  42.   (princ)
  43. )
  44. ;;;
  45. (defun LSXportIT (/ tmp)
  46.   (setq        tmp (strcat (getvar 'dwgprefix)
  47.                     (vl-string-right-trim ".dwg" (getvar 'dwgname))
  48.                     " ctab-"
  49.                     (getvar "ctab")
  50.                     ".las"
  51.             )
  52.   )
  53.   (princ (strcat "\n* Exporting Layer States to: " tmp))
  54.   (command "mspace")
  55.   (layerstate-export (getvar "ctab") tmp)
  56.   (command "pspace")
  57.   (princ)
  58. )
  59. ;;;
  60. (defun LSSaveIT        ()
  61.   (princ
  62.     (strcat "\n* Saving New Layer States to: " (getvar "ctab"))
  63.   )
  64.   (command "mspace")
  65.   (layerstate-save (getvar "ctab") 255 nil)
  66.   (command "pspace")
  67.   (princ)
  68. )
  69. ;;;
  70. (defun LSRestoreIT ()
  71.   (princ
  72.     (strcat "\n* Restoring Layer States from: " (getvar "ctab"))
  73.   )
  74.   (command "mspace")
  75.   (layerstate-restore (getvar "ctab") nil 255)
  76.   (command "pspace")
  77.   (princ)
  78. )
  79. ;;;
  80. (defun LSDeleteIT ()
  81.   (princ
  82.     (strcat "\n* Deleting Layer States from: " (getvar "ctab"))
  83.   )
  84.   (command "mspace")
  85.   (layerstate-delete (getvar "ctab"))
  86.   (command "pspace")
  87.   (princ)
  88. )
 楼主| 发表于 2018-2-18 12:50:15 | 显示全部楼层
  1. (defun DeleteLayerStates (/)
  2.   ;; Delete all layer states
  3.   ;; Ex: (DeleteLayerStates)
  4.   (vl-catch-all-apply
  5.     '(lambda ()
  6.        (vla-remove
  7.          (vla-getextensiondictionary
  8.            (vla-get-layers
  9.              (vla-get-activedocument (vlax-get-acad-object))
  10.            )
  11.          )
  12.          "ACAD_LAYERSTATES"
  13.        )
  14.      )
  15.   )
  16.   (princ)
  17. )
删除所有的Layer State
已领礼包: 7743个
发表于 2018-2-21 00:08:21 | 显示全部楼层
謝謝大過年的學習了
GMT+8, 2026-11-5 08:00 , Processed in 0.369678 second(s), 33 queries , Gzip On.
