查看: 1772|回复: 0
[每日一码] WbemScripting获取属性值函数
发表于 2018-2-25 11:35:32 | 显示全部楼层 |阅读模式
  1. (defun _WbemGet ( class props / locator service query temp result )
  2.     (vl-catch-all-apply 'eval
  3.        '(   (vlax-for x
  4.                 (setq query
  5.                     (vlax-invoke
  6.                         (setq service
  7.                             (vlax-invoke
  8.                                 (setq locator (vlax-create-object "WbemScripting.SWbemLocator"))
  9.                                 'ConnectServer "." "root\\cimv2" nil nil nil nil nil nil
  10.                             )
  11.                         )
  12.                         'ExecQuery
  13.                         (strcat "SELECT * FROM " class)
  14.                     )
  15.                 )
  16.                 (setq temp
  17.                     (cons
  18.                         (mapcar
  19.                             (function (lambda (p) (vl-catch-all-apply 'vlax-get (list x p))))
  20.                             (if (listp props) props (list props))
  21.                         )
  22.                         temp
  23.                     )
  24.                 )
  25.             )
  26.         )
  27.     )
  28.     (foreach x (mapcar 'list (list query service locator))
  29.         (vl-catch-all-apply 'vlax-release-object x)
  30.     )
  31.
  32.     (foreach l temp
  33.         (or
  34.             (null (apply 'or l))
  35.             (member l result)
  36.             (setq result (cons l result))
  37.         )
  38.     )
  39.     (if (listp props) result (mapcar 'car result))
  40.
  41. )
(_WbemGet "Win32_Process" '(Name ExecutablePath CommandLine))
(_WbemGet "Win32_Process" '(Name ProcessID))
(_WbemGet "Win32_Process" 'Name)
GMT+8, 2026-11-5 07:59 , Processed in 0.368432 second(s), 29 queries , Gzip On.
