查看: 5550|回复: 3
[分享] ObjectARX 2019 SDK下载地址
发表于 2018-3-23 10:46:09 | 显示全部楼层 |阅读模式
http://download.autodesk.com/esd ... _and_32_Bit.sfx.exe
 楼主| 发表于 2018-3-23 10:54:52 | 显示全部楼层
开发环境和系统需求Microsoft® Visual Studio® 2017 with Update 2 and C++ installed
Developing applications with ObjectARX 2019 on 32-bit or 64-bit requires the following software and hardware:
Operating System
Windows 32-bit
Microsoft® Windows® 8.1 with Update KB2919355
Microsoft Windows 7 SP1
NoteAutoCAD 2019 is not supported on the 32-bit version of Windows 10.
Windows 64-bit
Microsoft Windows 10 Anniversary Update (version 1607 or higher)
Microsoft Windows 8.1 with Update KB2919355
NoteWindows 8 (Standard) or Windows 7 Home Premium are not supported development platforms.
Internet Browser
Minimum: Internet Explorer® 11 or later
Recommended: Google™ Chrome™
Processor
Minimum: 2.5-2.9 gigahertz (GHz) or faster processor
Recommended: 3.0+ gigahertz GHz or faster processor
Memory
Windows 32-bit
Minimum: 2 GB RAM
Recommended: 4 GB RAM
Windows 64-bit
Minimum: 16 GB RAM
Recommended: 16+ GB RAM
Display Resolution
Windows 32-bit
Minimum: 1360x768 with True Color, and 125% Desktop Scaling (120 DPI) or less recommended
Recommended: 1920x1080 with True Color, and 125% Desktop Scaling (120 DPI) or less recommended
Windows 64-bit
Minimum:
Conventional Displays - 1360x768 with True Color, and 125% Desktop Scaling (120 DPI) or less recommended
High Resolution & 4K Displays - Resolutions up to 3840x2160 with True Color (Windows 10 64-bit and capable display card)
Recommended:
Conventional Displays - 1920x1080 with True Color, and 125% Desktop Scaling (120 DPI) or less recommended
High Resolution & 4K Displays - 3840x2160 with True Color (Windows 10 64-bit and capable display card)
Display card
Minimum: 1 GB GPU with 29 GB/S Bandwidth and DirectX 11 compliant
Recommended: 4 GB GPU with 106 GB/S Bandwidth and DirectX 11 compliant
Disk Space
500 MB of free disk space for installation
Pointing Device
MS-Mouse compliant
Compiler
.NET Framework
.NET Framework Version 4.7
Additional requirement for Model Documentation and Point Clouds
APIs related to the Model Documentation or Point Cloud features are only supported in applications developed for 64-bit Operating Systems
发表于 2018-3-23 13:24:06 | 显示全部楼层
厉害厉害呀
发表于 2018-3-23 19:36:09 | 显示全部楼层
留个脚印,谢谢楼主了!
GMT+8, 2026-11-22 09:53 , Processed in 0.484871 second(s), 14 queries , Gzip On, File On.
