查看: 2046|回复: 2
[点表] (XD::Object:Transform)对象(点,点表)矩阵变换
发表于 2018-4-1 15:47:36 | 显示全部楼层 |阅读模式
函数发布
函数名称: XD::Object:Transform
调用格式: (XD::Object:Transform target matrix)
参数说明: target ----- VLA对象、实体名、对象实体表、选择集、点、点表及组合
matrix ----- 4x4点表矩阵 或 vlax-tmarix生成的 variant对象
返回值: 对象 或 点、点表
函数简介: 对象(点,点表)矩阵变换
函数来源: 原创
函数作者: marting
适用版本: 不限
最后更新时间: 2018-04-01
备注: 对象(点,点表)矩阵变换
演示图片: -
  1. (defun XD::Object:Transform (target matrix / e temp i)
  2.   (cond
  3.     ((eq 'VLA-OBJECT (type target))
  4.      (vla-TransformBy target
  5.                       (if (= (type matrix) 'VARIANT)
  6.                         matrix
  7.                         (vlax-tMatrix matrix)
  8.                       )
  9.      )
  10.      target
  11.     )
  12.     ((eq 'ENAME (type target))
  13.      (vla-TransformBy  target
  14.                       (if (= (type matrix) 'VARIANT)
  15.                         matrix
  16.                         (vlax-tMatrix matrix)
  17.                       )
  18.      )
  19.      target
  20.     )
  21.     ((eq 'PICKSET (type target))
  22.      (setq i -1)
  23.      (while (setq e (ssname target (setq i (1+ i))))
  24.        (XD::Object:Transform e matrix)
  25.      )
  26.      target
  27.     )
  28.     ((listp target)
  29.      (if (and (= (length target) 3)
  30.               (or (= (type (car target)) 'real) (= (type (car target)) 'int))
  31.               (or (= (type (cadr target)) 'real) (= (type (cadr target)) 'int))
  32.               (or (= (type (caddr target)) 'real) (= (type (caddr target)) 'int))
  33.          )
  34.        (car (xd::object:transform (list target) matrix))
  35.        (mapcar '(lambda (x / temp)
  36.                   (cond ((or (= (type x) 'VLA-OBJECT)
  37.                              (= (type x) 'ENAME)
  38.                              (= (type x) 'PICKSET)
  39.                          )
  40.                          (XD::OBJECT:Transform x matrix)
  41.                         )
  42.                         ((and (listp x) (= (length x) 3))
  43.                          (setq temp (if (= (type matrix) 'VARIANT)
  44.                                       (xd::vla:variant->value matrix)
  45.                                       matrix
  46.                                     )
  47.                                temp (mapcar '(lambda (y) (list (car y) (cadr y) (caddr y)))
  48.                                             matrix
  49.                                     )
  50.                          )
  51.                          (mapcar '+
  52.                                  (XD::MAT:M*V temp x)
  53.                                  (reverse (cdr (reverse (mapcar 'last matrix))))
  54.                          )
  55.                         )
  56.                   )
  57.                 )
  58.                target
  59.        )
  60.      )
  61.     )
  62.   )
  63. )
发表于 2018-4-1 19:32:56 | 显示全部楼层
感谢老大一次性提供这么多矩阵函数,对这个还是云里雾里
发表于 2018-4-25 19:58:01 | 显示全部楼层
好好学习天天向上
GMT+8, 2026-11-22 07:39 , Processed in 0.302194 second(s), 14 queries , Gzip On, File On.
