查看: 3405|回复: 8
[求助] 关于lambda和vl-remove-if-not
发表于 2018-4-24 22:03:51 | 显示全部楼层 |阅读模式
(((541877.0 2795.04 0.0) "高程点" "图层") ((498546.0 4838.52 0.0) "高程点" "图层") ((447400.0 38042.7 0.0) "高程点" "图层") ((405636.0 38930.7 0.0) "高程点" "图层") ((442243.0 8798.93 0.0) "高程点" "图层") ((398913.0 10842.4 0.0) "高程点" "图层") ((97641.1 -108326.0 0.0) "高程点" "图层") ((54310.4 -106282.0 0.0) "高程点" "图层") ((97641.1 -49035.1 0.0) "高程点" "图层") ((54310.4 -46991.6 0.0) "高程点" "图层") ((197274.0 2795.04 0.0) "高程点" "图层") ((153944.0 4838.52 0.0) "高程点" "图层") ((102797.0 38042.7 0.0) "高程点" "图层") ((61033.2 38930.7 0.0) "高程点" "图层") ((97641.1 8798.93 0.0) "高程点" "图层") ((54310.4 10842.4 0.0) "高程点" "图层") ((541877.0 2795.04 0.0) "高程点" "图层") ((498546.0 4838.52 0.0) "高程点" "图层") ((447400.0 38042.7 0.0) "高程点" "图层") ((405636.0 38930.7 0.0) "高程点" "图层") ((442243.0 8798.93 0.0) "高程点" "图层") ((398913.0 10842.4 0.0) "高程点" "图层") ((97641.1 -108326.0 0.0) "高程点" "图层") ((54310.4 -106282.0 0.0) "高程点" "图层") ((97641.1 -49035.1 0.0) "高程点" "图层") ((54310.4 -46991.6 0.0) "高程点" "图层") ((197274.0 2795.04 0.0) "高程点" "图层") ((153944.0 4838.52 0.0) "高程点" "图层") ((102797.0 38042.7 0.0) "高程点" "图层") ((61033.2 38930.7 0.0) "高程点" "图层") ((97641.1 8798.93 0.0) "高程点" "图层") ((54310.4 10842.4 0.0) "高程点" "图层") ((405636.0 38930.7 0.0) "高程点" "图层") ((61033.2 38930.7 0.0) "高程点" "图层") ((447400.0 38042.7 0.0) "高程点" "图层") ((102797.0 38042.7 0.0) "高程点" "图层") ((398913.0 10842.4 0.0) "高程点" "图层") ((54310.4 10842.4 0.0) "高程点" "图层") ((442243.0 8798.93 0.0) "高程点" "图层") ((97641.1 8798.93 0.0) "高程点" "图层") ((498546.0 4838.52 0.0) "高程点" "图层") ((153944.0 4838.52 0.0) "高程点" "图层") ((541877.0 2795.04 0.0) "高程点" "图层") ((197274.0 2795.04 0.0) "高程点" "图层") ((54310.4 -46991.6 0.0) "高程点" "图层") ((97641.1 -49035.1 0.0) "高程点" "图层") ((54310.4 -106282.0 0.0) "高程点" "图层") ((97641.1 -108326.0 0.0) "高程点" "图层"))
(vl-remove-if-not '(lambda (x)  (equal (caar x) (cadar x) 0)) lst)
上面函数我想的是用remove直接求出x轴相同的点表
想了很久,lambda是遍历。上面函数是不是根本就不成立????
发表于 2018-4-24 22:11:20 | 显示全部楼层
你上面的表是几层?
你把你的结果,也贴出对比下。
发表于 2018-4-24 22:21:02 | 显示全部楼层
就三行代码
(setq lst (mapcar '(lambda(x)(cons (caar x) x)) a))
(setq lst (xd::list:groupbyindex lst 0.01))
(setq lst (mapcar 'cdr lst))
每行你看懂了,思路很重要。
你要的结果:
(((102797.0 38042.7 0.0) "高程点" "图层")
   (((153944.0 4838.52 0.0) "高程点" "图层")
   (((197274.0 2795.04 0.0) "高程点" "图层")
   (((398913.0 10842.4 0.0) "高程点" "图层")
   (((405636.0 38930.7 0.0) "高程点" "图层")
   (((442243.0 8798.93 0.0) "高程点" "图层")
   (((447400.0 38042.7 0.0) "高程点" "图层")
   (((498546.0 4838.52 0.0) "高程点" "图层")
   (((54310.4 -46991.6 0.0) "高程点" "图层")
   (((61033.2 38930.7 0.0) "高程点" "图层")
   (((97641.1 -49035.1 0.0) "高程点" "图层")
发表于 2018-4-24 22:28:44 | 显示全部楼层
下面是 Y坐标相同的分到一组
  1. (setq lst (mapcar '(lambda(x)(cons (cadar x) x)) a))
  2. (setq lst (xd::list:groupbyindex lst 0.01))
  3. (setq lst (mapcar 'cdr lst))
((((54310.4 -106282.0 0.0) "高程点" "图层")
  (((97641.1 -108326.0 0.0) "高程点" "图层")
 楼主| 发表于 2018-4-25 09:31:22 | 显示全部楼层
我的那个没结果,就是nil
感谢,我确实没理解透。
你的代码我好好研究
XD::LIST:GROUPBYINDEX是个通用的表的分组函数 你如果从论坛拷贝的这个函数,用上面三行得不到结果,那你就去加载下 “晓东通用LISP函数库”。 问题要归纳整理,才提高效率。不要这次要排X轴,写个代码,下次排Y  详情 回复 发表于 2018-4-25 10:08
已领礼包: 4044个
发表于 2018-4-25 09:46:16 | 显示全部楼层
    (setq lst (vl-sort lst '(lambda(a b)
                                (if (equal (caar a) (caar b) 1e-3)
                                    (> (cadar a) (cadar b))
                                    (> (caar a)(caar b))
    (setq jgb nil)
    (while (setq pt (car lst))
        (setq zbb (vl-remove-if-not '(lambda(a)(= (caar pt) (caar a))) lst))
        (setq jgb (cons zbb jgb))
        (setq lst (vl-remove-if '(lambda(a)(= (caar pt) (caar a))) lst))
((((54310.4 10842.4 0.0) "高程点" "图层") ((54310.4 10842.4 0.0) "高程点" "图层")
  ((54310.4 10842.4 0.0) "高程点" "图层") ((54310.4 -46991.6 0.0) "高程点" "图层")
  ((54310.4 -46991.6 0.0) "高程点" "图层") ((54310.4 -46991.6 0.0) "高程点" "图层")
  ((54310.4 -106282.0 0.0) "高程点" "图层") ((54310.4 -106282.0 0.0) "高程点" "图层")
  ((54310.4 -106282.0 0.0) "高程点" "图层"))
  ((61033.2 38930.7 0.0) "高程点" "图层") ((61033.2 38930.7 0.0) "高程点" "图层"))
(((97641.1 8798.93 0.0) "高程点" "图层") ((97641.1 8798.93 0.0) "高程点" "图层")
  ((97641.1 8798.93 0.0) "高程点" "图层") ((97641.1 -49035.1 0.0) "高程点" "图层")
  ((97641.1 -49035.1 0.0) "高程点" "图层") ((97641.1 -49035.1 0.0) "高程点" "图层")
  ((97641.1 -108326.0 0.0) "高程点" "图层") ((97641.1 -108326.0 0.0) "高程点" "图层")
  ((102797.0 38042.7 0.0) "高程点" "图层") ((102797.0 38042.7 0.0) "高程点" "图层"))
(((153944.0 4838.52 0.0) "高程点" "图层") ((153944.0 4838.52 0.0) "高程点" "图层")
  ((153944.0 4838.52 0.0) "高程点" "图层"))
  ((197274.0 2795.04 0.0) "高程点" "图层") ((197274.0 2795.04 0.0) "高程点" "图层"))
(((398913.0 10842.4 0.0) "高程点" "图层") ((398913.0 10842.4 0.0) "高程点" "图层")
  ((398913.0 10842.4 0.0) "高程点" "图层"))
  ((405636.0 38930.7 0.0) "高程点" "图层") ((405636.0 38930.7 0.0) "高程点" "图层"))
(((442243.0 8798.93 0.0) "高程点" "图层") ((442243.0 8798.93 0.0) "高程点" "图层")
  ((442243.0 8798.93 0.0) "高程点" "图层"))
  ((447400.0 38042.7 0.0) "高程点" "图层") ((447400.0 38042.7 0.0) "高程点" "图层"))
(((498546.0 4838.52 0.0) "高程点" "图层") ((498546.0 4838.52 0.0) "高程点" "图层")
  ((498546.0 4838.52 0.0) "高程点" "图层"))
  ((541877.0 2795.04 0.0) "高程点" "图层") ((541877.0 2795.04 0.0) "高程点" "图层"))
已领礼包: 4044个
发表于 2018-4-25 10:05:01 | 显示全部楼层
;或者如下也行
   (setq jgb nil)
发表于 2018-4-25 10:08:56 | 显示全部楼层
124803430 发表于 2018-4-25 09:31
我的那个没结果,就是nil
感谢,我确实没理解透。
你的代码我好好研究
问题要归纳整理,才提高效率。不要这次要排X轴,写个代码,下次排Y轴,又重写,以后排Z轴或者其他条件呢?
表要分组,首先要有条件,根据什么分组。根据什么条件,就把条件提出来,放到子表的第一个元素。
然后你的代码,根据子表的 第一个元素(条件),进行分组。
分组后,把第一个条件元素去掉,就是原来的分组后的表(就是上面三行代码的最后一行)
上面三行代码
第一行,把条件提出放到子表的第一个元素
第二行,分组
第三行,把第一个元素去掉,得到分组后的表。
要善于用MAPCAR和LAMBBDA组合,尽量少用WHILE,REPEAT,FOREACH其他循环。
MAPCAR是LISP的精髓。用它,才能让表层层递进,求值结果做上层函数的参数,才体现了LISP作为人工智能首选语言的作用。
谢谢大佬指点  详情 回复 发表于 2018-4-25 10:38
 楼主| 发表于 2018-4-25 10:38:29 | 显示全部楼层
你如果从论坛拷贝的这个函数,用上面三行得不到结果,那 ...
谢谢大佬指点
GMT+8, 2026-11-6 05:52 , Processed in 0.590764 second(s), 49 queries , Gzip On.
