查看: 1494|回复: 3
[求助] 如何删除TABLE表格的表头
已领礼包: 2476个
发表于 2018-5-14 09:56:15 | 显示全部楼层 |阅读模式
;   DeleteColumns (2)
;   DeleteRows (2)
只能删除数据行的行和列..如果想删除表头该怎么写呢..请大师指导一下,谢谢!
已领礼包: 2476个
 楼主| 发表于 2018-5-14 09:59:09 | 显示全部楼层
(Vlax-Invoke-Method tb 'DeleteRows 0 1)就行了吧..还是确定一下..这样写对不..
发表于 2018-5-14 10:30:53 | 显示全部楼层
0行,就是表头吧
已领礼包: 20个
发表于 2018-5-14 10:48:54 | 显示全部楼层
  1. (defun c:tt ()
  2.   (if (and (setq e (car (entsel "\n选择表格:")))
  3.            (setq o (vlax-ename->vla-object e))
  4.            (= (vla-get-objectname o) "AcDbTable")
  5.            (setq row (getint "\n删除行号:"))
  6.       )
  7.     (progn
  8.       (if (not
  9.             (vl-catch-all-apply
  10.               (function
  11.                 (lambda nil (vla-deleterows o  row 1))
  12.               )
  13.             )
  14.           )
  15.         (princ (strcat "\n删除了第 " (itoa row) " 行."))
  16.       )
  17.     )
  18.   )
  19.   (princ)
  20. )
GMT+8, 2026-11-6 05:52 , Processed in 0.361962 second(s), 35 queries , Gzip On.
