查看: 1873|回复: 2
[发布] 【AcBr库应用(四)】求空间点到3DSOLID各个面的最近点
发表于 2018-5-26 02:01:38 | 显示全部楼层 |阅读模式
问题:
I have a point in 3D space and I would like to get the closest point on a 3D solid from this input point. Is there any API to achieve this?
求输入点到3DSOLID最近点,哪个API可以解决?
解决方案:
It is possible to realize that using the BRep API (located in the <ObjectARX 2009 Path>\utils\brep directory): you need to traverse all the faces that are contained in your 3D solid and for each face use the AcBrFace::getFace method. It returns an AcGeSurface object from where you can use AcGeSurface::closestPointTo, passing in your input point.
使用BRep API,您需要遍历3D实体中包含的所有面,并为每个面使用AcBrFace :: getFace方法,得到AcGeSurface对象, 使用AcGeSurface :: closestPointTo获得输入点和AcGeSurface对象的最近点。
下面是ARX代码:
[C++] 纯文本查看 复制代码
static AcBr::ErrorStatus TraverseFaces(const AcBrBrep& brepEntity, const AcGePoint3d& pointToTest)
        AcBr::ErrorStatus returnValue = AcBr::eOk;
        // make a global face traverser
        AcBrBrepFaceTraverser brepFaceTrav;
        returnValue = brepFaceTrav.setBrep(brepEntity);
        if (returnValue != AcBr::eOk)
                acutPrintf(ACRX_T("\n Error in AcBrBrepFaceTraverser::setBrep:"));
                errorReport(returnValue);
                return returnValue;
        int faceCount = 0;
       while (!brepFaceTrav.done() && (returnValue == AcBr::eOk))
                ++faceCount;
                AcBrFace face;
                if (brepFaceTrav.getFace(face) == AcBr::ErrorStatus::eOk)
                        AcGeSurface* pSurface;
                        if (face.getSurface(pSurface) == AcBr::ErrorStatus::eOk)
                                AcGePoint3d closestPoint = pSurface->closestPointTo(pointToTest);
                                double dist = AcGeVector3d(closestPoint.asVector() - pointToTest.asVector()).length();
                                acutPrintf(L"\n - Face[%d]: closest point [%f, %f, %f]   Distance: %f", faceCount, closestPoint.x, closestPoint.y, closestPoint.z, dist);
                                delete pSurface;
                returnValue = brepFaceTrav.next();
                if (returnValue != AcBr::eOk) {
                        acutPrintf(ACRX_T("\n Error in AcBrBrepFaceTraverser::next:"));
                        return returnValue;
        return returnValue;
void TestClosestPoint(void)
        Acad::ErrorStatus acadReturnValue = eOk;
        AcGePoint3d pointToTest;
        // pick a point
        acedGetPoint(NULL, L"\nPick a point: ", asDblArray(pointToTest));
        // Get the subentity path for a brep
        AcDbFullSubentPath subPath(kNullSubent);
        acadReturnValue = selectEntity(AcDb::kNullSubentType, subPath);
        if (acadReturnValue != eOk)
                acutPrintf(ACRX_T("\n Error in getPath: %d"), acadReturnValue);
                return;
        // Make a brep entity to access the solid
        AcBrBrep brepEntity;
        returnValue = ((AcBrEntity*)&brepEntity)->set(subPath);
                acutPrintf(ACRX_T("\n Error in AcBrBrep::set:"));
                return;
        returnValue = TraverseFaces(brepEntity, pointToTest);
                acutPrintf(ACRX_T("\n Error in TraverseFaces:"));
                return;
下面使用XDRX API的 ACBR库函数,完成上面ARX同样的工作
  1. (defun c:tt ()
  2.   (defun _traversface (e pnt)
  3.     (setq br (xdbr::constructor e))
  4.     (setq tr (xdbr::constructor "brepfacetraverser" br))
  5.     ;;FACE遍历
  6.     (setq face-count 0)
  7.     (xdrx_entity_delete co-ss)
  8.     (xdrx_setmark)
  9.     (while (not (xdbr::traverser:done tr));循环遍历
  10.       (if (setq face (xdbr::getpropertyvalue tr "face"));;AcBrFace对象
  11.         (progn (setq face-count  (1+ face-count)
  12.                      gface       (xdbr::getpropertyvalue face "surface") ;;得到AcGeSurface对象
  13.                      closest-pnt (xdge::getpropertyvalue gface "closestpointto" pnt);;最近点
  14.                      dist        (distance pnt closest-pnt)
  15.                )
  16.           (xdrx_object_release gface face);;释放AcBrFace、AcGeSurface
  17.           (xdrx_point_make closest-pnt)
  18.           (xdrx_entity_setcolor (entlast) 2)
  19.           (xdrx_line_make pnt closest-pnt)
  20.           (xdrx_entity_setcolor (entlast) 1)
  21.                (xdrx_prompt
  22.                  (xdrx_string_format "\n - 面[%d]: 最近点 [%f, %f, %f]   距离 %f"
  23.                                      face-count
  24.                                      (car closest-pnt)
  25.                                      (cadr closest-pnt)
  26.                                      (caddr closest-pnt)
  27.                                      dist
  28.                  )
  29.                )
  30.         )
  31.       )
  32.       (setq co-ss (xdrx_getss))
  33.       (xdbr::traverser:next tr)
  34.     )
  35.     (xdrx_object_release tr br)
  36.   )
  37.   (if (setq e (car (xdrx_entsel "\n选取3DSOLID<退出>:" '((0 . "3DSOLID")))))
  38.     (progn
  39.       (xdrx_begin)
  40.       (xdrx_sysvar_push '("osmode" 512))
  41.       (xdrx_setvar "pdmode" 35)
  42.       (while (setq pt (getpoint "\n点取测试点<退出>:"))
  43.       (_traversface e (setq pt (trans pt 1 0))))
  44.       (xdrx_end)
  45.     )
  46.   )
  47.   (princ)
  48. )
发表于 2018-5-26 07:43:19 | 显示全部楼层
好啊的,学习了
发表于 2018-5-26 10:35:18 | 显示全部楼层
留个脚印,以后慢慢学习!
GMT+8, 2026-11-22 11:08 , Processed in 0.341283 second(s), 14 queries , Gzip On, File On.
