查看: 6030|回复: 17
[教学] 【AcBr库应用(三)】给3DSOLID每个面设置不同的颜色
发表于 2018-5-28 15:43:00 | 显示全部楼层 |阅读模式
我们知道,CAD里面是没有命令可以将3DSOLID每个面设置不同的颜色的,我们可以通过ACBR API做到。
使用ACBRAPI,遍历每个面(FACE),然后通过子实体路径的子实体ID设置每个面的颜色
下面是ARX代码:
[C++] 纯文本查看 复制代码
void TestBrep(void)
    Adesk::Int32 len;
    ads_name  ssname0;
  struct resbuf *buffer;
    buffer = acutBuildList(-4, _T("<AND"),
              RTDXF0, _T("3DSOLID"),
              -4, _T("AND>"), RTNONE);
    acutPrintf(_T("\nSelect a box:"));
    acedSSGet(NULL, NULL, NULL, buffer, ssname0);
   acutRelRb(buffer);
  if (RTNORM == acedSSLength(ssname0, &len))
        ads_name  ent;
        AcDbObjectId entId;
    for(long k = 0; k < len; k++)
            acedSSName(ssname0, k, ent);
            acdbGetObjectId(entId, ent);
      settingDifferentColorToEachFace(entId);
        acedSSFree(ssname0);
void settingDifferentColorToEachFace(AcDbObjectId solidId)
  AcCmColor specialColor;
  AcDb3dSolid* pSolid;
    if (Acad::eOk == acdbOpenObject(pSolid, solidId, AcDb::kForRead))
        AcDbFullSubentPath path(solidId, AcDbSubentId());
    AcBrBrep brep;
        AcBr::ErrorStatus bs = brep.setSubentPath(path);
        if (bs != AcBr::eOk)
            return;
   //Initialize the BrepFace traverser
        AcBrBrepFaceTraverser bft;
        bs = bft.setBrep(brep);
            return;
        AcArray<AcDbSubentId> arrSubentId;
        // Traverse all faces
        for (;!bft.done();bft.next())
            AcBrFace face;
            bs = bft.getFace(face);
            if (bs != Acad::eOk)
                acutPrintf(L"\ngetFace failed");
                break;
            AcDbFullSubentPath    Path(kNullSubent);
            AcDbSubentId          subentId;
            AcBr::ErrorStatus bss = face.getSubentPath(Path);
            subentId = Path.subentId();
            arrSubentId.append(subentId);
        pSolid->upgradeOpen();
        for (int i = 0; i < arrSubentId.length(); i++)
      specialColor.setColorIndex(i);
            pSolid->setSubentColor(arrSubentId[i],specialColor);
        pSolid->downgradeOpen();
    pSolid->close();
下面是XDRX API的AcBr库函数实现的LISP代码:
  1. (defun c:tt ()
  2.   (defun _traversface (e)
  3.     (setq br (xdbr::constructor e))
  4.     (setq tr (xdbr::constructor "brepfacetraverser" br))
  5.     ;;FACE遍历
  6.     (setq ids nil)
  7.     (while (not (xdbr::traverser:done tr));遍历面
  8.       (if (setq face (xdbr::getpropertyvalue tr "face"));获得当前遍历指针位置的面AcBrFace
  9.         (progn (setq SubEntPath (xdbr::getpropertyvalue face "subentpath");获得面的子实体路径
  10.                      SubEntId   (xdrx_getpropertyvalue SubEntPath "subentid");;获得子实体ID
  11.                      ids        (cons SubEntId ids);保存到全局表
  12.                )
  13.                (xdrx_object_release SubEntPath);;释放子实体路径变量
  14.         )
  15.       )
  16.       (xdbr::traverser:next tr);;遍历器指向下个位置
  17.     )
  18.     (xdrx_object_release tr br);;释放遍历器和BREP变量
  19.     (setq i 0)
  20.     (repeat (length ids);设置子实体面颜色
  21.       (xdrx_setpropertyvalue
  22.         e
  23.         "subentcolor"
  24.         (list (setq SubEntId (nth i ids)) (setq i (1+ i)))
  25.       )
  26.       (xdrx_object_release SubEntId);;释放子实体ID变量
  27.       (xdrx_prompt
  28.         (xdrx_string_format "\n - 面[%d]-颜色[%d]" i i)
  29.       )
  30.     )                                   ;
  31.   )
  32.   (if (setq e (car (xdrx_entsel "\n选取3DSOLID<退出>:" '((0 . "3DSOLID")))
  33.               )
  34.       )
  35.     (progn (xdrx_begin) (_traversface e) (xdrx_end))
  36.   )
  37.   (princ)
  38. )
评分
参与人数 1D豆 +5 收起 理由
sh_h + 5 好主题奖!
查看全部评分
发表于 2018-5-29 10:05:42 | 显示全部楼层
谢谢东哥分享!
其实CAD是有命令的,如果不对,还请指教!
谢谢指正, CAD的命令在编程自动化处理的时候,比较难用。  详情 回复 发表于 2018-5-29 10:21
评分
参与人数 1D豆 +10 收起 理由
XDSoft + 10 热心帮忙奖!
查看全部评分
 楼主| 发表于 2018-5-29 10:21:23 | 显示全部楼层
sh_h 发表于 2018-5-29 10:05
谢谢东哥分享!
谢谢指正,
发表于 2018-8-26 13:40:33 来自手机 | 显示全部楼层
东哥厉害,原来acbr库是这么用的
来自: 微社区
发表于 2018-8-26 15:19:11 来自手机 | 显示全部楼层
我想用acbr库将面域转换成多段线而不是用打破的方法,使用acbredge和acbrloop怎么总是不允许不完整的类型
来自: 微社区
发表于 2020-1-2 13:58:05 | 显示全部楼层
怎样取得每个面的颜色属性?
用上面的代码,循环 其中: (xdrx_setpropertyvalue e "subentcolor" (list (setq SubEntId (nth i ids)) (setq i (1+ i))) ) 是设置颜色的 用函数 xdrx_getpropertyvalue可  详情 回复 发表于 2020-1-8 17:19
发表于 2020-1-2 13:59:34 | 显示全部楼层
怎样取得每个面的颜色属性?
发表于 2020-1-6 08:23:51 | 显示全部楼层
大佬有没有空帮忙解答一下.
 楼主| 发表于 2020-1-8 17:19:10 | 显示全部楼层
kaibing 发表于 2020-1-2 13:58
怎样取得每个面的颜色属性?
用上面的代码,循环
其中:
        e
        "subentcolor"
是设置颜色的
用函数 xdrx_getpropertyvalue可以获取子实体的颜色
(xdrx_getpropertyvalue e "subentcolor")
发表于 2020-1-9 19:08:09 | 显示全部楼层
XDSoft 发表于 2020-1-8 17:19
用上面的代码,循环
其中:
我试过了不行,所以才有以上问题的。请帮忙试一下,这个对我作用很大。谢谢
发表于 2020-2-8 21:24:35 | 显示全部楼层
老大们,是我用的不对吗,请帮忙指正,为什么查不到
发表于 2020-2-8 21:26:15 | 显示全部楼层
发表于 2020-3-31 13:58:22 | 显示全部楼层
怎麼設置我選擇的幾個面的顏色?怎麼建立立體面的選擇集?怎麼樣高亮指定面?
发表于 2020-4-2 13:49:19 | 显示全部楼层
老大們,幫忙看看我的問題
发表于 2020-4-2 15:19:20 | 显示全部楼层
怎样取得每个面的颜色属性?
获取每个面的颜色
  1. (defun c:tt ()
  5.     ;;FACE遍历
  6.     (setq ids nil)
  12.                )
  14.         )
  15.       )
  17.     )
  19.     (setq i 0)
  20.     (repeat (length ids);获取子实体面颜色
  21.       (setq clr (xdrx_getpropertyvalue
  22.                   e
  23.                   "subentcolor"
  25.                 )
  26.       )
  27.       (xdrx_object_release SubEntId);;释放子实体ID变量
  28.       (xdrx_prompt
  29.         (xdrx_string_format "\n - 面[%d]-颜色[%d]" i clr)
  30.       )
  31.     )                                   ;
  32.   )
  33.   (if (setq e (car (xdrx_entsel "\n选取3DSOLID<退出>:" '((0 . "3DSOLID")))
  34.               )
  35.       )
  36.     (progn (xdrx_begin) (_traversface e) (xdrx_end))
  37.   )
  38.   (princ)
  39. )
命令: tt
选取3DSOLID<退出>:
- 面[1]-颜色[224]
- 面[2]-颜色[230]
- 面[3]-颜色[105]
- 面[4]-颜色[136]
- 面[5]-颜色[218]
- 面[6]-颜色[107]
GMT+8, 2026-11-22 09:51 , Processed in 0.387818 second(s), 38 queries , Gzip On, File On.
