查看: 1705|回复: 0
[每日一码] AcEdCommand使用INSERT如何显示属性设置对话框
发表于 2018-6-19 18:00:05 | 显示全部楼层 |阅读模式
ssue
How can I force the attribute dialog box to display for an _INSERT issued with acedCommand using ObjectARX?
Solution
You need to use a global function in ObjectARX called acedInitDialog. This is parallel to how the initdia function in AutoLISP must be called prior to issuing the INSERT command.
When dialog initialization occurs before acedCommand, both the "insert" and "Enter Attributes", dialog boxes will display during command execution.Because the "insert" fields do not normally require modification, it is only desirable to display the attributes dialog for user input. In order to display the attribute dialog box instead of command line prompts, divide the command sequence into two parts so that the initialization call is made shortly before
attribute values are solicited.
static void testOut()
    //set vars first
    struct resbuf rb;
    rb.restype = RTSHORT;
    rb.resval.rint = 1;
    acedSetVar(L"ATTDIA", &rb);
    acedSetVar(L"ATTREQ", &rb);
    //block position
    ads_point pt1;
    pt1[X] = pt1[Y] = 4.0;
    //call command
    int rterr = acedCommand ( RTSTR, L"_.insert", RTSTR, L"myBlock", RTPOINT,
pt1, RTNONE );
    // ask to display attribute dialog
    acedInitDialog(Adesk::kTrue);
    // continue the command
    acedCommand(RTREAL, 1.0,  RTREAL, 1.0, RTREAL, 0.0, RTNONE);
GMT+8, 2026-11-22 09:56 , Processed in 0.276691 second(s), 8 queries , Gzip On, File On.
