查看: 1989|回复: 9
[求助] 怎样查找表内用逗号分隔的数据
已领礼包: 9个
发表于 2018-6-23 11:54:13 | 显示全部楼层 |阅读模式
有如下一个表,每列数据都是用逗号隔开的,没有内容则为空。
(("JS1,镀锌管,100,,非普查,2666118.11,400678.43,95.39,95.14,0.25,,,,,直埋,,") ("JS2,镀锌管,100,,非普查,2666118.11,400678.43,95.39,95.14,0.25,,,,,直埋,,"))
例如我想查找js1所在的表,并返回指定第N列数据(每行数据用逗号分开)
查找JS1所在表的第二列数据返回    镀锌管
谢谢啊
[sell=10][/sell]
已领礼包: 4044个
发表于 2018-6-23 14:42:48 | 显示全部楼层
(setq sjlb '(("JS100,镀锌管,100,,非普查,2666118.11,400678.43,95.39,95.14,0.25,,,,,直埋,,")
              ("JS200,镀锌管,100,,非普查,2666118.11,400678.43,95.39,95.14,0.25,,,,,直埋,,")
              ("JS111,镀锌管,100,,非普查,2666118.11,400678.43,95.39,95.14,0.25,,,,,直埋,,")
(setq cxjg (caar (vl-remove-if '(lambda(x)(/= (substr (car x) 1 4) "JS1,")) sjlb)))
(setq jglb (mapcar '(lambda(x)(vl-princ-to-string x))
                     (read (strcat "(" (vl-string-translate "," " "  cxjg) ")"))
已领礼包: 20个
发表于 2018-6-23 16:20:12 | 显示全部楼层
(mapcar '(lambda(x)(xd::string:regexps "[^,]+" (car x) "")) sjlb)
((("JS100" "镀锌管" "100" "非普查" "2666118.11" "400678.43" "95.39" "95.14" "0.25" "直埋") ("JS200" "镀锌管" "100" "非普查" "2666118.11" "400678.43" "95.39" "95.14" "0.25" "直埋") ("JS1" "镀锌管" "100" "非普查" "2666118.11" "400678.43" "95.39" "95.14" "0.25" "直埋") ("JS2" "镀锌管" "100" "非普查" "2666118.11" "400678.43" "95.39" "95.14" "0.25" "直埋") ("JS111" "镀锌管" "100" "非普查" "2666118.11" "400678.43" "95.39" "95.14" "0.25" "直埋"))
已领礼包: 3904个
发表于 2018-6-24 07:16:20 | 显示全部楼层
做一个热心并受欢迎的人!
已领礼包: 4044个
发表于 2018-6-24 10:13:22 | 显示全部楼层
(setq sjlb '(("JS100,无缝钢管,100,,非普查,2666118.11,400678.43,95.39,95.14,0.25,,,,,直埋,,")
              ("JS200,无缝钢管,100,,非普查,2666118.11,400678.43,95.39,95.14,0.25,,,,,直埋,,")
              ("JS111,无缝钢管,100,,非普查,2666118.11,400678.43,95.39,95.14,0.25,,,,,直埋,,")
(setq Regexp (vlax-create-object "vbscript.regexp"))
(vlax-put-property Regexp "Global" 1)
(vlax-put-property Regexp "Pattern"  "([^,]+)")
(setq cxjg (mapcar '(lambda(X)
                         (setq Z nil)
                         (vlax-for Y (vlax-invoke Regexp "Execute" (car X))
                                     (setq Z (cons (vla-get-Value Y) Z))
                         (reverse Z)
                    sjlb
(vlax-release-object Regexp)
(nth 1 (assoc "JS1" cxjg))
已领礼包: 9个
 楼主| 发表于 2018-6-24 17:39:34 | 显示全部楼层
太感谢你了!!!强。。。
已领礼包: 9个
 楼主| 发表于 2018-6-24 17:40:57 | 显示全部楼层
感谢!!!想了好久
已领礼包: 9个
 楼主| 发表于 2018-6-24 17:44:37 | 显示全部楼层
谢谢你!!!
已领礼包: 6056个
发表于 2018-6-25 00:03:11 | 显示全部楼层
求助还设权限?
已领礼包: 9个
 楼主| 发表于 2018-6-25 21:28:49 | 显示全部楼层
不会用,我还以为是设置奖励。。。不好意思
GMT+8, 2026-11-5 04:24 , Processed in 0.534925 second(s), 47 queries , Gzip On.
