查看: 1279|回复: 0
[求助] C# PaletteSet UserControl设置问题
发表于 2018-7-9 09:01:21 | 显示全部楼层 |阅读模式
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Drawing;
using System.Data;
using System.Text;
using System.Windows.Forms;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Windows;
using Autodesk.AutoCAD.ApplicationServices;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace Hello
    public partial class Menubar : UserControl
        public Menubar()
            InitializeComponent();
        private void CommandTools_Load(object sender, EventArgs e)
            //调整高度及大小
            this.Size = new System.Drawing.Size(200, 25);
            this.menuStrip1.Size = new System.Drawing.Size(60, this.Size.Height - 2);
    public class MenubarPalette
        static PaletteSet ps;
        [CommandMethod("kaka")]
        public void ShowMenubar()//ShowMenubar
            //如果面板还没有被创建
            if (ps == null)
                //新建一个面板对象
                ps = new PaletteSet("");
                //添加菜单条面板项
                ps.Add("菜单条", new Menubar());
            //在设置停靠属性之前,必须让面板可见,否则总是停靠在窗口的左侧
            ps.Visible = true;
            //必须在Dock前面
            ps.Size = new System.Drawing.Size(200, 27);//(15, 22);
            //设置面板停靠在窗口的顶面
            ps.Dock = DockSides.Top;
        public void kaka()
            ShowMenubar();
请问怎样去掉上下边缘,求指点
GMT+8, 2026-11-3 01:43 , Processed in 0.429749 second(s), 31 queries , Gzip On.
