查看: 1091|回复: 2
[求助] ARX如何保存图层要素为DWG文件
发表于 2018-7-10 11:25:37 | 显示全部楼层 |阅读模式
如题,类似CAD中的保存功能,有没有相似的例子
发表于 2018-7-10 12:07:36 | 显示全部楼层
WBLOCK 了。
发表于 2018-7-10 12:14:34 | 显示全部楼层
AcDbDatabase::wblock Function
Acad::ErrorStatus
wblock(
AcDbDatabase* pOutputDb,
const AcDbObjectIdArray& outObjIds,
const AcGePoint3d& basePoint,
AcDb::DuplicateRecordCloning drc);
pOutputDbInput pointer to an existing AcDbDatabase
outObjIdsInput array of object IDs of all objects to be wblocked out
basePointInput base point (in WCS coordinates for pOutputDb) to be used in pOutputDb
drcInput desired DuplicateRecordCloning type
This method uses the wblockClone() mechanism to write the array of objects specified by outObjIds to the model space block table record of the database pointed to by pOutputDb, using basePoint as the base point value for pOutputDb.
The AcDbDatabase pointed to by pOutputDb must contain a header and symbol tables. Thus, if it was created with the AcDbDatabase constructor's buildDefaultDrawing argument set to false, a drawing must have already been read into it in order to populate it with a header and symbol tables.
The drc value determines what happens if symbols or dictionary entries are cloned when one or more duplicates already exist in the destination database. drc must keep the same setting in multiple calls, and can be only one of the following:
AcDb::kDrcIgnoreIf a duplicate is found, ignore the clone, and continue to use the existing record in the destination database. This is how the INSERT command and the AcDbDatabase::insert() function operate.
AcDb::kDrcReplaceIf a duplicate is found, replace it with the cloned record.
AcDb::kDrcMangleNameMangle all the incoming record names. The mangling ensures unique names. This is how the REFEDIT command works.
AcDb::kDrcUnmangleNamePrimarily used by REFEDIT when it checks the records back into the origin database. Any mangling done by kDrcMangleName is undone, and then it defaults to kDrcIgnore. In other words, if a duplicate is found after removing the manging, AutoCAD continues to use the existing record, and ignores the cloned one.
Returns Acad::eOk if operation is successful.
Returns Acad::eInvalidInput if drc is not one of the four valid types.
See the BASE command documentation in the AutoCAD online help for more information on base point.
Acad::ErrorStatus
wblock(
AcDbDatabase*& pOutputDb,
const AcGePoint3d& basePoint);
pOutputDbReturns pointer to the database that was written to
outObjIdsInput array of objectId entities of all objects to be wblocked out
Creates a new AcDbDatabase object, sets pOutputDb to point to it, and then uses the wblockClone mechanism to write the array of objects specified by outObjId entities out to the Model Space block table record of the database pointed to by pOutputDb, using basePoint as the base point value for pOutputDb.
The calling application is responsible for deallocating (via the C++ delete operator) the AcDbDatabase object that pOutputDb is set to point to.
GMT+8, 2026-11-22 09:49 , Processed in 0.348922 second(s), 12 queries , Gzip On, File On.
