查看: 1254|回复: 0
[求助] 这代码怎么加进去标注字高的设置,以及标注出来的字是L=xxxm
发表于 2018-7-11 10:03:11 | 显示全部楼层 |阅读模式
; (c) Chris Hardwicke 1996
(DEFUN C:ad ()
  (setq tot_len 0)
  (prompt "\n(c) Chris Hardwicke 1996 ")
  (prompt "\nSelect all objects to count 请选择所有要累计长度的物体: ")
  (setq ss (ssget))
  (while (> (sslength ss) 0)
    (setq en (ssname ss 0))
    (setq ed (entget en))
    (setq e_type (cdr (assoc '0 ed)))
    (cond
      ((= e_type "LINE") (add_lines))
      ((= e_type "ARC") (add_arcs))
      ((= e_type "POLYLINE") (add_poly))
      ((= e_type "LWPOLYLINE") (add_poly))
      ((or
     (/= e_type "LINE")
     (/= e_type "ARC")
     (/= e_type "POLYLINE")
       (ssdel en ss)
  (prompt (strcat "\nTotal length is 总长度是:  " "L=" (rtos tot_len 2 2) "m"))
  (setq txtPt (getpoint "\n 文字标注位置: "))
  (command "._text" "middle" txtpt)
  (if (= 0.00 (cdr (assoc 40 (tblsearch "style" (getvar "textstyle")))))
       (command "" "" (rtos tot_len 2 2))
       (command "" (rtos tot_len 2 2))
(defun add_lines ()
  (setq pt1 (cdr (assoc '10 ed)))
  (setq pt2 (cdr (assoc '11 ed)))
  (setq line_len (distance pt1 pt2))
  (setq tot_len (+ tot_len line_len))
  (ssdel en ss)
(defun add_arcs ()
  (SETQ CEN (CDR (ASSOC '10 Ed))
    RAD (CDR (ASSOC '40 Ed))
    DIA (* RAD 2.00)
    CIRCUM (* (* RAD PI) 2.00)
    S_ANG (CDR (ASSOC '50 Ed))
    E_ANG (CDR (ASSOC '51 Ed))
  (IF (< E_ANG S_ANG)
    (SETQ E_ANG (+ E_ANG (* PI 2.00)))
  (SETQ
    N_ANG (- E_ANG S_ANG)
    N_ANG_1 (* (/ N_ANG PI) 180.00)
    PART_CIRC (/ N_ANG_1 360.00)
    A_LEN (* PART_CIRC CIRCUM)
  (setq tot_len (+ tot_len a_len))
  (PRIN1)
  (SSDEL EN SS)
(defun add_poly ()
  (command "area" "e" en)
  (setq tot_len (+ tot_len (getvar "perimeter")))
  (ssdel en ss)
GMT+8, 2026-11-2 21:58 , Processed in 0.543080 second(s), 29 queries , Gzip On.
