查看: 1532|回复: 7
[求助] 求助各位大神
发表于 2018-7-12 15:50:19 | 显示全部楼层 |阅读模式
各位大神帮帮忙,现在布局空间有一个视口,我怎么用代码改变他的大小
发表于 2018-7-12 16:00:33 | 显示全部楼层
AcDbViewport::setWidth Function Acad::ErrorStatus
setWidth(
double unnamed);
unnamed Input viewport width
This function sets width to be the width of the viewport entity's window in drawing units. This is the width in paperspace of the viewport itself, not the width of the model space view within the viewport.
Returns Acad::eOk if successful.
The viewport height is used for DXF group code 40.
AcDbViewport::setHeight Function
Acad::ErrorStatus
setHeight(
double unnamed);
unnamedInput height for the viewport window
This function sets the viewport's window to be height drawing units high.
The viewport height is used for DXF group code 41.
 楼主| 发表于 2018-7-12 16:19:18 | 显示全部楼层
setWidth(
view.setCenterPoint(PtCenter);
view.setHeight(5.0);
view.setWidth(5.0);
这样写的,命令执行完也不变,需要更新什么东西吗
你这VIEW是什么,把完整代码贴上来看看  详情 回复 发表于 2018-7-12 16:25
发表于 2018-7-12 16:25:34 | 显示全部楼层
view.setWidth(5.0);
 楼主| 发表于 2018-7-12 16:26:57 | 显示全部楼层
网上找的代码
double scale;
    if (ads_getreal(_T("Enter scale:"), &scale) != RTNORM) goto END1;
    AcDbObjectId idVp;
    if ((idVp=acdbGetCurViewportObjectId())==AcDbObjectId::kNull)
                ads_printf(_T("No current viewport. (tilemode=1?)\n"));
                goto END1;
    AcDbViewport* pVp;
    Acad::ErrorStatus es;
    if((es=acdbOpenObject(pVp,idVp,AcDb::kForWrite))==Acad::eOk)
                double height = pVp->height();
                AcDbViewTableRecord view;
                AcGePoint2d max;
                max.x = 5.0;
                max.y = 5.0;
                view.setCenterPoint(max);
                view.setWidth(5.0);
                if ((es=acedSetCurrentView( &view, pVp))==Acad::eOk)
                        ads_printf(_T("Scale set to %f.\n",scale));
                }else
                        ads_printf(_T("Failed to set scale.\n"));
                pVp->close();
    if (es!=Acad::eOk) ads_printf(_T("ERROR: es = %s\n"),acadErrorStatusText(es));
你这个代码是设置视口的缩放的,不是设置视口的宽和高。你要设置AcDbViewPort的宽和高。  详情 回复 发表于 2018-7-12 20:01
发表于 2018-7-12 18:26:07 来自手机 | 显示全部楼层
这个是view不是viewport
发表于 2018-7-12 20:01:20 | 显示全部楼层
1784290342 发表于 2018-7-12 16:26
网上找的代码
double scale;
 楼主| 发表于 2018-7-16 10:00:49 | 显示全部楼层
好的,我试试,先谢谢啊
GMT+8, 2026-11-22 10:07 , Processed in 0.139845 second(s), 22 queries , Gzip On, File On.
