查看: 2245|回复: 7
[每日一码] 重新生成HATCH边界
发表于 2018-7-22 12:32:08 | 显示全部楼层 |阅读模式
[C++] 纯文本查看 复制代码
;;; HATCHB.LSP ver 2.5
;;; Recreates hatch boundary by selecting a hatch
;;; Known problem with some elipses and splines
;;; By Jimmy Bergmark
;;; Copyright (C) 1997-2008 JTB World, All Rights Reserved
;;; Website: [url]www.jtbworld.com[/url]
;;; E-mail: [email]info@jtbworld.com[/email]
;;; 2000-02-12 - First release
;;; 2000-03-27 - Counterclockwise arcs and ellipses fixed
;;;              Objects created joined to lwpolyline if possible
;;;              Error-handling, undo of command
;;;              Can handle PLINETYPE = 0,1,2
;;; 2000-03-30 - Integrating hatchb and hatchb14
;;;              Selection of many hatches
;;;              Splines supported if closed.
;;; 2001-04-02 - Fixed bug with entmake of line with no Z for r14
;;; 2001-07-31 - Removed an irritating semicolon to enable polylines to be created.
;;; 2001-10-04 - Changed mail and homepage so it's easy to find when new versions comes up.
;;; 2003-02-06 - Minor fix
;;; 2003-02-17 - Area returned if no islands is found since it's not consistant
;;; 2003-05-19 - Fix to take PEDITACCEPT variable used in AutoCAD 2004 into account
;;; 2004-11-05 - Minor bugs fixed
;;; 2006-03-18 - Nothing changed from 2.1 other that it's been confirmed to work with AutoCAD 2007
;;; 2006-05-13 - Create the boundary on the same layer as the hatch using the hbl command and
;;;              on current layer/color/linetype using the hb or hatchb command
;;; 2007-02-08 - Fixed a bug with the hbl command
;;; 2008-02-29 - Support for hatches in non WCS thanks to xiaocai
;;; Tested on AutoCAD r14, 2000, 2000i, 2002, 2004, 2005, 2006, 2007, 2008, 2009
;;; should be working on older versions too.
(defun c:hb () (hatchb nil)) ; this line can be commented out if there is an existing command called hb
(defun c:hbl () (hatchb T)) ; this line can be commented out if there is an existing command called hbl
(defun c:hatchb () (hatchb nil))
(defun hatchb (hl  /     es    blay  ed1   ed2   loops1      bptf  part
             et    noe   plist ic    bul   nr    ang1  ang2  obj *ModelSpace* *PaperSpace*
             space cw errexit undox olderr oldcmdecho ss1 lastent en1 en2 ss lwp
             list->variantArray 3dPoint->2dPoint A2k ent i ss2
             knot-list controlpoint-list kn cn pos xv bot area hst noarea
 (setq A2k (>= (substr (getvar "ACADVER") 1 2) "15"))
 (if A2k
   (progn
     (defun list->variantArray (ptsList / arraySpace sArray)
       (setq arraySpace
	      (vlax-make-safearray
		vlax-vbdouble
		(cons 0 (- (length ptsList) 1))
       (setq sArray (vlax-safearray-fill arraySpace ptsList))
       (vlax-make-variant sArray)
     (defun areaOfObject (en / curve area)
       (if en
	 (if A2k
	   (progn
	     (setq curve (vlax-ename->vla-object en))
	     (if
	       (vl-catch-all-error-p
		 (setq
		   area
		    (vl-catch-all-apply 'vlax-curve-getArea (list curve))
		nil
		area
	   (progn
	     (command "._area" "_O" en)
	     (getvar "area")
 (if A2k
  (defun 3dPoint->2dPoint (3dpt)
    (list (float (car 3dpt)) (float (cadr 3dpt)))
  (defun errexit (s)
    (princ "\nError:  ")
    (princ s)
    (restore)
  (defun undox ()
    (command "._ucs" "_p")
    (command "._undo" "_E")
    (setvar "cmdecho" oldcmdecho)
    (setq *error* olderr)
    (princ)
  (setq olderr  *error*
        restore undox
        *error* errexit
  (setq oldcmdecho (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (command "._UNDO" "_BE")
  (if A2k (progn
    (vl-load-com)
    (setq *ModelSpace* (vla-get-ModelSpace
                         (vla-get-ActiveDocument (vlax-get-acad-object))
          *PaperSpace* (vla-get-PaperSpace
; Remove for testing purpose
; (setq A2k nil)
  (if (/= (setq ss2 (ssget '((0 . "HATCH")))) nil)
   (progn
    (setq i 0)
    (setq area 0)
    (setq bMoreLoops nil)
    (while (setq ent (ssname ss2 i))
      (setq noarea nil)
      (setq ed1 (entget ent))
      (setq layer (cdr (assoc 8 ed1)))
      ; (if (not (equal (assoc 210 ed1) '(210 0.0 0.0 1.0))) (princ "\nHatch not in WCS!"))  ;modified by
xiaocai
      ; (setq xv (cdr (assoc 210 ed1)))                                                      ;modified by
xiaocai
      (command "._ucs" "_w")
      (setq loops1 (cdr (assoc 91 ed1))) ; number of boundary paths (loops)
      (if (and A2k (= (strcase (cdr (assoc 410 ed1))) "MODEL"))
        (setq space *ModelSpace*)
        (setq space *PaperSpace*)
      (repeat loops1
        (setq ed1 (member (assoc 92 ed1) ed1))
        (setq bptf (cdr (car ed1))) ; boundary path type flag
        (setq ic (cdr (assoc 73 ed1))) ; is closed
        (setq noe (cdr (assoc 93 ed1))) ; number of edges
	(setq bot (cdr (assoc 92 ed1))) ; boundary type
	(setq hst (cdr (assoc 75 ed1))) ; hatch style
        (setq ed1 (member (assoc 72 ed1) ed1))
        (setq bul (cdr (car ed1))) ; bulge
        (setq plist nil)
        (setq blist nil)
        (cond
          ((> (boole 1 bptf 2) 0) ; polyline
           (repeat noe
             (setq ed1 (member (assoc 10 (cdr ed1)) ed1))
             (setq plist (append plist (list    (trans (cdr (assoc 10 ed1)) ent 0)     ))) ;;add trans by
xiaocai
             (setq blist (append blist
                                 (if (> bul 0)
                                   (list (cdr (assoc 42 ed1)))
                                   nil
           (if A2k (progn
             (setq polypoints
                    (apply 'append
                           (mapcar '3dPoint->2dPoint plist)
             (setq VLADataPts (list->variantArray polypoints))
             (setq obj (vla-addLightweightPolyline space VLADataPts))
             (setq nr 0)
             (repeat (length blist)
               (if (/= (nth nr blist) 0)
                 (vla-setBulge obj nr (nth nr blist))
               (setq nr (1+ nr))
             (if (= ic 1)
               (vla-put-closed obj T)
	     (if hl (vla-put-layer obj layer))
            (progn
	      (setq ne (append (list '(0 . "POLYLINE")) (list (cons 66 1))))
	      (if (= ic 1) (setq ne (append ne (list (cons 70 1)))))
	      (if hl (setq ne (append ne (list (cons 8 layer)))))
              (entmake ne)
              (setq nr 0)
              (repeat (length plist)
                (if (= bul 0)
                  (entmake (list (cons 0 "VERTEX")
                                 (cons 10 (trans (nth nr plist) ent 0) );;add trans by xiaocai
                                 (cons 42 (nth nr blist))
                (setq nr (1+ nr))
              (entmake '((0 . "SEQEND")))
          (t ; not polyline
           (setq lastent (entlast))
           (setq lwp T)
           (repeat noe
             (setq et (cdr (assoc 72 ed1)))
             (cond
               ((= et 1) ; line
                (if A2k
		  (progn
                    (setq obj (vla-AddLine
                      space
                      (vlax-3d-point (trans (cdr (assoc 10 ed1)) ent 0)   ) ;;add trans by xiaocai
                      (vlax-3d-point (trans (cdr (assoc 11 ed1)) ent 0)   ) ;;add trans by xiaocai
		  (progn
		    (setq ne (append (list (cons 0 "LINE"))
                        (list (list 10 (car (trans (cdr (assoc 10 ed1)) ent 0) ) (cadr (trans (cdr (assoc 10
ed1)) ent 0)) 0)) ;;add trans by xiaocai
                        (list (list 11 (car (trans (cdr (assoc 11 ed1)) ent 0) ) (cadr (trans (cdr (assoc 11
		        ;(cons 210 xv)
                    (entmake ne)
                (setq ed1 (cddr ed1))
               ((= et 2) ; circular arc
                 (setq ang1 (cdr (assoc 50 ed1)))
                 (setq ang2 (cdr (assoc 51 ed1)))
                 (setq cw (cdr (assoc 73 ed1)))
                 (if (and (equal ang1 0 0.00001) (equal ang2 6.28319 0.00001))
                   (progn
                     (if A2k
		       (progn
                         (setq obj (vla-AddCircle
                           space
                           (cdr (assoc 40 ed1))
		       (progn
			 (setq ne (append
				      (list (cons 0 "CIRCLE"))
                                      (list (cons 10 (trans (cdr (assoc 10 ed1)) ent 0)));;;add trans by
xiaocai
                                      (list (assoc 40 ed1))
                         (entmake ne)
                     (setq lwp nil)
                   (if A2k
		     (progn
                       (setq obj (vla-AddArc
                         space
                         (vlax-3d-point (trans (cdr (assoc 10 ed1)) ent 0) );;;add trans by xiaocai
                         (if (= cw 0)
                           (- 0 ang2)
                           ang1
                         (if (= cw 0)
                           (- 0 ang1)
                           ang2
		     (progn
		       (setq ne (append (list (cons 0 "ARC"))
                                    (list (cons 10 (trans (cdr (assoc 10 ed1)) ent 0) ));;add trans by xiaocai
                                    (list (cons 50
                                          (if (= cw 0)
                                            (- 0 ang2)
                                            ang1
                                    (list (cons 51
                                          (if (= cw 0)
                                            (- 0 ang1)
                                            ang2
                       (entmake ne)
                 (setq ed1 (cddddr ed1))
               ((= et 3) ; elliptic arc
                (if A2k (progn
                  (setq obj (vla-AddEllipse
                              space
                              (vlax-3d-point (trans (cdr (assoc 11 ed1)) ent 0) );;add trans by xiaocai
                  (vla-put-startangle obj (if (= cw 0) (- 0 ang2) ang1))
                  (vla-put-endangle obj (if (= cw 0) (- 0 ang1) ang2))
		 (progn
                   (princ "\nElliptic arc not supported!")
		   (setq noarea T)
                (setq lwp nil)
               ((= et 4) ; spline
                (setq ed1 (member (assoc 94 (cdr ed1)) ed1))
                (setq knot-list nil)
                (setq controlpoint-list nil)
		(setq kn (cdr (assoc 95 ed1)))
                (setq cn (cdr (assoc 96 ed1)))
                (setq pos (vl-position (assoc 40 ed1) ed1))
                (repeat kn
                  (setq knot-list (cons (cons 40 (cdr (nth pos ed1))) knot-list))
                  (setq pos (1+ pos))
                (setq pos (vl-position (assoc 10 ed1) ed1))
                (repeat cn
                  (setq controlpoint-list (cons (cons 10 (trans (cdr (nth pos ed1)) ent 0)   ) controlpoint-
list));;add trans by xiaocai
                  (setq pos (1+ pos))
                (setq knot-list (reverse knot-list))
                (setq controlpoint-list (reverse controlpoint-list))
		(setq ne (append
		               (list '(0 . "SPLINE"))
                               (list (cons 100 "AcDbEntity"))
                               (list (cons 100 "AcDbSpline"))
                               (list (cons 70 (+ 1 8 (* 2 (cdr (assoc 74 ed1))) (* 4 (cdr (assoc 73 ed1))))))
                               (list (cons 71 (cdr (assoc 94 ed1))))
                               (list (cons 72 kn))
                               (list (cons 73 cn))
                               knot-list
                               controlpoint-list
		(if hl (setq ne (append ne (cons 8 layer))))
                (entmake ne)
		(setq ed1 (member (assoc 10 ed1) ed1))
                (setq lwp nil)
             ) ; end cond
           ) ; end repeat noe
           (if lwp (progn
             (setq en1 (entnext lastent))
             (setq ss (ssadd))
             (ssadd en1 ss)
             (while (setq en2 (entnext en1))
               (ssadd en2 ss)
               (setq en1 en2)
	     (if (= (getvar "peditaccept") 1)
               (command "_.pedit" (entlast) "_J" ss "" "")
	       (command "_.pedit" (entlast) "_Y" "_J" ss "" "")
          ) ; end t
        ) ; end cond
;	Tries to get the area on islands but it's not clear how to know if an island is filled or not
;	and if it should be substracted or added to the total area.
;	(if (or (= bot 0) (= (boole 1 bot 1) 1)) (setq area (+ area (areaOfObject (entlast)))))
;	(if (and (/= hst 1) (/= bot 0) (= (boole 1 bot 1) 0)) (setq area (- area (areaOfObject (entlast)))))
;	(princ "\n") (princ bot) (princ "\n") (princ hst) (princ "\n")
;	(princ (areaOfObject (entlast)))
      ) ; end repeat loops1
      (if (and (= noarea nil) (= loops1 1)) (setq area (+ area (areaOfObject (entlast)))) (setq bMoreLoops T))
      (setq i (1+ i))
  (setq ss2 nil)
  (if (and area (not bMoreLoops)) (progn
    (princ "\nTotal Area = ")
    (princ area)
  (restore)
  (princ)
已领礼包: 1337个
发表于 2018-7-22 14:28:30 | 显示全部楼层
谢谢,这个好用!
已领礼包: 5800个
发表于 2018-7-22 18:27:28 | 显示全部楼层
谢谢楼主的大作!!!
已领礼包: 6056个
发表于 2018-7-22 20:49:21 | 显示全部楼层
谢谢分享。
已领礼包: 6468个
发表于 2018-7-23 00:03:32 | 显示全部楼层
这个挺不错。
已领礼包: 12个
发表于 2018-7-25 08:21:58 | 显示全部楼层
谢谢分享
已领礼包: 4044个
发表于 2018-8-7 09:27:28 | 显示全部楼层
谢谢分享!
但是,当边界中含有Spline时,会出错,显示“Error:  参数太多”信息,然后中断!
已领礼包: 511个
发表于 2020-1-3 11:56:45 | 显示全部楼层
一直没整明白hatch的dxf,看了此贴终于整懂了。多谢楼主分享
GMT+8, 2026-11-4 07:24 , Processed in 0.295087 second(s), 43 queries , Gzip On.
