查看: 1531|回复: 10
[求助] 内外修剪速度相差,上百倍,几千条线实验,
已领礼包: 1337个
发表于 2018-7-26 21:16:12 | 显示全部楼层 |阅读模式
  1. (defun pts (SS0 / elist n ptlist) ;端点列表
  2.   (setq ptlist nil)
  3.   (setq elist (entget SS0))
  4.   (foreach n elist
  5.     (if  (or (= 10 (car n)) (= 11 (car n))) ;同时处理PLINE和 LINE
  6.       (setq ptlist (cons (cdr n) ptlist))
  7.     )
  8.   )
  9.   (setq ptlist (reverse ptlist))
  10.
  11. )
  12. (defun trim
  13.        (na / las obj os ptlist sss x)
  14.
  15.   (setq os (getvar "osmode"))
  16.   (setvar "osmode" 0)
  17.   (setq Obj (vlax-ename->vla-object na))
  18.       (
  19.        vla-offset obj
  20.   ;-0.3
  21.   0.3   ;这里内外偏移防误选
  22.   )
  23.
  24.       (setq las (entlast))
  25.       (setq ptlist(pts las))
  26.       (entdel las)
  27.       (command "ZOOM" "o" na "")
  28.
  29.       ;;------------------------------------------------------
  30.       (repeat 2
  31.   (command "regen" "")
  32.   (if (SETQ
  33.         SSS (SSGET "f"
  34.        ptlist
  35.        '((0 . "LWPOLYLINE,LINE,ARC,CIRCLE,ELLIPSE,hatch"))
  36.       )
  37.       )
  38.     (progn (command ".trim" na "" "f")
  39.      (foreach x ptlist (command x))
  40.      (command "" "")
  41.     ) ;progn
  42.   )
  43.       ) ;repeat
  44.       ;;------------------------------------------------------
  45.       (command "zoom" "p")
  46.
  47. ;;;;;;;;;;
  48.   (setvar "osmode" os)
  49. )
  50.
  51. (defun c:tt ( / d end-time h m na s start-time ts) ;修剪内部比外部慢几十甚至百倍。不知道什么问题
  52.   (setq na (car (entsel "\n pick")))
  53. (setq start-time (* 86400 (getvar "tdusrtimer")))
  54.   (trim na)
  55.   (if start-time
  56.     (progn
  57.       (setq end-time (* 86400 (getvar "tdusrtimer"))
  58.      ts (- end-time start-time)
  59.      d (rtos (fix (/ ts 86400.0)) 2 0)
  60.      ts (rem ts 86400)
  61.      h (rtos (fix (/ ts 3600.0)) 2 0)
  62.      ts (rem ts 3600)
  63.      m (rtos (fix (/ ts 60.0)) 2 0)
  64.      ts (rem ts 60)
  65.      s (rtos ts 2 2)
  66.       )
  67.       (if (> (distof d) 0)
  68. (princ (strcat "\n用时 : " d "天" h "小时" m "分" s "秒"))
  69. (if (> (distof h) 0)
  70.    (princ (strcat "\n用时 : " h "小时" m "分" s "秒"))
  71.    (if (> (distof m) 0)
  72.      (princ (strcat "\n用时 : " m "分" s "秒"))
  73.      (princ (strcat "\n用时 : " s "秒"))
  74.    )
  75. )
  76.       )
  77.     )
  78.   )
  79. )
很多line或pline,两端通过矩形a.矩形a内部修剪很慢,外部修剪很快,其他地方不变,只是偏移一个图形选内,外,那里变化一下,其他代码均不变,速度相差,上百倍,几千条线实验,|;
发表于 2018-7-26 22:56:25 | 显示全部楼层
请上传个你测试时候的DWG.
谢谢大师光临。就是不明白同样的代码,一个修剪内部要慢那么多  详情 回复 发表于 2018-7-27 08:36
发表于 2018-7-27 00:10:03 | 显示全部楼层
嗯嗯,学习学习
已领礼包: 1337个
 楼主| 发表于 2018-7-27 08:36:19 | 显示全部楼层
newer 发表于 2018-7-26 22:56
请上传个你测试时候的DWG.
已领礼包: 1337个
 楼主| 发表于 2018-7-27 08:39:39 | 显示全部楼层
就是一个矩形,上下穿个他的线,任意的都可以,没特别要求
trim.rar
50.63 KB, 下载次数: 11, 下载积分: D豆 -1 , 活跃度 1
已领礼包: 3904个
发表于 2018-7-27 08:46:21 | 显示全部楼层
做一个热心并受欢迎的人
已领礼包: 6056个
发表于 2018-7-27 23:58:43 | 显示全部楼层
学习一下。
已领礼包: 25个
发表于 2018-8-14 18:57:11 | 显示全部楼层
收藏了,学习学习
已领礼包: 6468个
发表于 2018-8-15 23:39:54 | 显示全部楼层
正好有空,我也来测试一下。
GMT+8, 2026-11-5 06:37 , Processed in 0.449694 second(s), 51 queries , Gzip On.
