查看: 1425|回复: 2
[每日一码] 清理词典中的条目
已领礼包: 20个
发表于 2018-8-13 21:37:41 | 显示全部楼层 |阅读模式
  1. (vl-load-com)
  2. (defun _kpblc-get-ent-name (ent)
  3.   (cond        ((vlax-property-available-p ent 'effectivename)
  4.          (vla-get-effectivename ent)
  5.         )
  6.         ((vlax-property-available-p ent 'name) (vla-get-name ent))
  7.   ) ;_ end of cond
  8. ) ;_ end of defun
  9. (setq sysvar (vl-remove-if-not
  10.                (function cdr)
  11.                (mapcar (function (lambda (x) (cons x (getvar x))) ;_ end of lambda
  12.                        ) ;_ end of function
  13.                        '("frame"        "imageframe"   "pdfframe"
  14.                          "dwfframe"        "dgnframe"     "oleframe"
  15.                         )
  16.                ) ;_ end of mapcar
  17.              ) ;_ end of vl-remove-if-not
  18. ) ;_ end of setq
  19. (vlax-for item (vla-get-dictionaries
  20.                  (vla-get-activedocument (vlax-get-acad-object))
  21.                )
  22.   (if
  23.     (not
  24.       (or (and (not (_kpblc-get-ent-name item))
  25.                (= (cdr (assoc 0 (entget (vlax-vla-object->ename item))))
  26.                   "RASTERVARIABLES"
  27.                )
  28.           ) ;_ end of and
  29.           (and (_kpblc-get-ent-name item)
  30.                (wcmatch        (strcase (_kpblc-get-ent-name item))
  31.                         "ACAD_*,JOBDICT_*"
  32.                )
  33.           ) ;_ end of and
  34.       ) ;_ end of or
  35.     ) ;_ end of not
  36.      (vl-catch-all-apply
  37.        (function (lambda () (vla-delete item)) ;_ end of lambda
  38.        ) ;_ end of function
  39.      ) ;_ end of vl-catch-all-apply
  40.   ) ;_ end of if
  41. ) ;_ end of vlax-for
  42. (foreach item sysvar (setvar (car item) (cdr item))) ;_ end of foreach
已领礼包: 4044个
发表于 2018-8-13 22:14:54 | 显示全部楼层
谢谢分享!下来学习学习!
已领礼包: 5800个
发表于 2018-8-14 07:57:31 | 显示全部楼层
感谢大师分享程序
GMT+8, 2026-11-5 04:44 , Processed in 0.364407 second(s), 33 queries , Gzip On.
