查看: 1217|回复: 0
[求助] error C2653: “MSXML”: 不是类或命名空间名
发表于 2018-8-15 10:33:05 | 显示全部楼层 |阅读模式
我想做一个Palette, 以下用ARX在自动生成的代码 ,直接编译都不通过提示:
myPalette1.cpp(31): fatal error C1083: 无法打开类型库文件: “msxml.dll”: No such file or directory
网上找资料说windows7不再是MSXML了,而是MSXML6,我直接改成MSXML6名字,编译报错又会提示:: error C2653: “MSXML”: 不是类或命名空间名称
有没有那个大神也遇到过这样的问题啊。或者有知错怎么解决的提点一下,谢谢。
(我的环境是:objectArx 2018 + Vs2015 + Windows 10)
#include "StdAfx.h"
#include "resource.h"
#include "myPalette1.h"
//- Import the MSXML functionality
#import "msxml6.dll" named_guids
//using namespace MSXML ;
IMPLEMENT_DYNAMIC (myPalette1, CAdUiPalette)
BEGIN_MESSAGE_MAP(myPalette1, CAdUiPalette)
        ON_WM_CREATE()
        ON_WM_SIZE()
        ON_WM_SIZING()
END_MESSAGE_MAP()
myPalette1::myPalette1 (HINSTANCE hInstance) : CAdUiPalette (), mChildDlg(NULL, hInstance) {
myPalette1::~myPalette1 () {
//- Load the input data from xml.
BOOL myPalette1::Load (IUnknown *pUnk) {
        //- Call base class first
        CAdUiPalette::Load (pUnk) ;
        //- Initialise for XML
        CComQIPtr<MSXML::IXMLDOMNode> pNode(pUnk) ;
        MSXML::IXMLDOMNodePtr pChild, pChild1 ;
        // TODO: read in data from palette XML
        return (TRUE) ;
//- Save the input data to xml.
BOOL myPalette1::Save (IUnknown *pUnk) {
        CAdUiPalette::Save (pUnk) ;
        //- initialise for XML
        // TODO: save data to palette XML
        return (TRUE) ;
//- Used to add a dialog resource
int myPalette1::OnCreate (LPCREATESTRUCT lpCreateStruct) {
        if ( CAdUiPalette::OnCreate (lpCreateStruct) == -1 )
                return (-1) ;
        //- Create it and set the parent as the dockctrl bar
        mChildDlg.Create (IDD_MYPALETTE1, this) ;
        CRect rect ;
        GetWindowRect (&rect) ;
        //- Move the window over so we can see the control lines
        mChildDlg.MoveWindow (0, 0, rect.Width (), rect.Height (), TRUE) ;
        return (0) ;
//- Called by the palette set when the palette is made active
void myPalette1::OnSetActive () {
        return (CAdUiPalette::OnSetActive ()) ;
//- Called by AutoCAD to steal focus from the palette
bool myPalette1::CanFrameworkTakeFocus () {
        //- Not simply calling IsFloating() (a BOOL) avoids warning C4800
        return (GetPaletteSet ()->IsFloating () == TRUE ? true : false) ;
void myPalette1::OnSize (UINT nType, int cx, int cy) {
        CAdUiPalette::OnSize (nType, cx, cy) ;
        //- If valid
        if ( ::IsWindow (mChildDlg.GetSafeHwnd ()) ) {
                //- Forward the call
                mChildDlg.OnSize (nType, cx, cy) ;
GMT+8, 2026-11-22 10:35 , Processed in 0.320769 second(s), 8 queries , Gzip On, File On.
