查看: 1432|回复: 0
[编程申请] 怎么把RTK打出来的坐标点在excel中排序,并在CASS中快速连线,编号(f1,1)房1第1点
发表于 2018-9-11 18:16:39 | 显示全部楼层 |阅读模式
Sub pl()
Dim ad As AutoCAD.AcadApplication
    Dim dr As AutoCAD.AcadDocument
    Dim pl As AutoCAD.AcadPolyline
    Dim i As Integer
    Dim n As Integer
    Dim arr() As Double
    n = Range("a65536").End(xlUp).Row
    If n > Range("b65536").End(xlUp).Row Then n = Range("b65536").End(xlUp).Row
    ReDim arr(3 * n - 1)
    i = 1
    Do Until Cells(i, 1).Value = "" Or Cells(i, 2).Value = ""
        arr((i - 1) * 3) = Cells(i, 1).Value
        arr((i - 1) * 3 + 1) = Cells(i, 2).Value
        arr((i - 1) * 3 + 2) = 0
        i = i + 1
    Loop
    Set ad = New AutoCAD.AcadApplication
    Set dr = ad.Documents.Add
    Set pl = dr.ModelSpace.AddPolyline(arr)
    pl.Color = 4
    dr.SaveAs (InputBox("SaveAS?"))
    dr.Close
    Set pl = Nothing
    Set dr = Nothing
    Set ad = Nothing
End Sub
说明:在book1.xls,excel中使用点x,y,连多段线,见excel代码,可运行,引用(AutoCAD 2016 Type Library),dwg文件保存在C:\Windows\SysWOW64\
GMT+8, 2026-11-22 10:42 , Processed in 0.362069 second(s), 9 queries , Gzip On, File On.
