查看: 2698|回复: 11
[求助] 如何批量把多段线端点连接?
已领礼包: 127个
发表于 2018-10-15 15:07:59 | 显示全部楼层 |阅读模式
   道路设计填充闭合 需要把边线闭合 有没什么批量连接的办法 端点的距离不一定 有的5米 有的三米 有的7米!
现在是手动画线然后再连接 有没什么批量的办法?
连接前: 连接前.jpg 连接后: 连接后.jpg
;;选择对角点连线 ,By 明经通道 Gu_xl 2012.09.14
(defun c:kx-DJLX  (/             PTINBOX           P1          P2         MINX        MINY   MAXX
              MAXY   SS            PL           N          EN         EL        PT     VERTEX
              PTS    DumpPoint)
  (defun ptinbox  (p mi_x mi_y ma_x ma_y)
    (and (>= (car p) mi_x)
         (>= (cadr p) mi_y)
         (<= (car p) ma_x)
         (<= (cadr p) ma_y)
  (defun DumpPoint  (ptLst fuzz / pt1 x)
    (cond ((<= (length ptLst) 1) ptLst)
          (t
           (setq pt1 (car ptLst))
           (cons pt1
                 (vl-remove-if
                   '(lambda (x) (equal pt1 x fuzz))
                   (DumpPoint (cdr ptLst) fuzz))
  (while (and
           (setq p1 (getpoint "\n第一点: "))
           (setq p2 (getcorner p1 "\n对角点: "))
    (setq minx (min (car p1) (car p2))
          miny (min (cadr p1) (cadr p2))
          maxx (max (car p1) (car p2))
          maxy (max (cadr p1) (cadr p2))
    (setq ss (ssget "c" p1 p2 '((0 . "line,*polyline"))))
    (if        ss
      (progn
        (setq pl nil)
        (repeat        (setq n (sslength ss))
          (setq en (ssname ss (setq n (1- n))))
          (cond
            ((= "LINE" (cdr (assoc 0 (setq el (entget en)))))
             (if (ptinbox (setq pt (cdr (assoc 10 el)))
                          minx
                          miny
                          maxx
                          maxy)
               (setq pl (cons (list (car pt) (cadr pt)) pl))
               (if (ptinbox (setq pt (cdr (assoc 11 el)))
                            minx
                            miny
                            maxx
                            maxy)
                 (setq pl (cons (list (car pt) (cadr pt))pl))
            ((= "LWPOLYLINE" (cdr (assoc 0 el)))
             (mapcar '(lambda (a)
                        (if (ptinbox (cdr a) minx miny maxx maxy)
                          (setq pl (cons (cdr a) pl))))
                     (vl-remove-if '(lambda (x) (/= 10 (car x))) el)
            (t
             (setq vertex
                    (vlax-safearray->list
                      (vlax-variant-value
                        (vla-get-Coordinates
                          (vlax-ename->vla-object en)
                   pts nil
             (while vertex
               (if
                 (ptinbox
                   (setq pt (list (car vertex) (cadr vertex)))
                   minx
                   miny
                   maxx
                   maxy)
                  (setq pl (cons pt pl))
               (setq vertex (cdddr vertex))
        (setq pl (DumpPoint pl 1e-6)
              pl (vl-sort pl
                          '(lambda (a b)
                             (if (= (cadr a) (cadr b))
                               (< (car a) (car b))
                               (> (cadr a) (cadr b))
        (while (setq p1        (car pl)
                     p2        (cadr pl)
          (entmake (list '(0 . "line")
                         '(62 . 1)
                         (cons 10 p1)
                         (cons 11 p2)
          (setq pl (cddr pl))
(setq cm (getvar "cmdecho"))
        (setvar "cmdecho" 0)
        ; (prompt "\n 多项选择同时连线----钮广春整理--★QQ-626860125★")
        (setvar "peditaccept" 1) ;加入这个系统变量的代码
        (if (setq ngc01 (ssget '((0 . "LINE,ARC,LWPOLYLINE,POLYLINE"))))
                (command "_pedit" "m" ngc01 "" "j" "j" "b" "0" "")
        (setvar "cmdecho" cm)
  (princ)
框选连线
框选连线
人行道连线.rar
174.88 KB, 下载次数: 26, 下载积分: D豆 -1 , 活跃度 1
已领礼包: 604个
发表于 2018-10-15 16:46:54 | 显示全部楼层
如图4根线,分别是3m,7m.都边起来呢?
我认为规则 是这样,有了3m的,就不联超过3m的。
发表于 2018-10-15 17:39:57 | 显示全部楼层
能不能批量,关键是知道哪个线和哪个线是一对道路,你能说明规则吗?你要说不清,那机器就不懂了。
可以设定距离 比如人行道5米宽 多段线相邻端点等于5m的就连接  详情 回复 发表于 2018-10-15 17:46
已领礼包: 127个
 楼主| 发表于 2018-10-15 17:46:46 | 显示全部楼层
你图中就这几根线行,如果你图中很多实体,什么线都有,什么图层都有,你怎么批量呢?  详情 回复 发表于 2018-10-15 18:31
发表于 2018-10-15 18:31:45 | 显示全部楼层
已领礼包: 127个
 楼主| 发表于 2018-10-15 22:06:53 来自手机 | 显示全部楼层
图层都是程序出的,我一般都是把需要的图层单独打开然后闭合,如果可以选择特定的图层就更好,一般是两个图层
来自: 微社区
已领礼包: 127个
 楼主| 发表于 2018-10-15 22:09:15 来自手机 | 显示全部楼层
是不是能设定个距离区间,或者输入距离只连接复核距离区间的线段
来自: 微社区
已领礼包: 6468个
发表于 2018-10-16 00:05:53 | 显示全部楼层
楼主这样描述不是很清楚。
已领礼包: 6434个
发表于 2018-10-16 07:28:30 | 显示全部楼层
规则不明确
已领礼包: 127个
 楼主| 发表于 2018-10-20 09:52:15 来自手机 | 显示全部楼层
顶下,看有没大神出手解决下
来自: 微社区
已领礼包: 127个
 楼主| 发表于 2018-10-21 20:30:40 | 显示全部楼层
自己找了几个插件 整合了下 也大大的加快了速度  有需要的可以用用  还没法到批量!
已领礼包: 155个
发表于 2019-9-7 19:04:38 | 显示全部楼层
楼上的可以把整合版的发出来看看啊
GMT+8, 2026-11-4 07:17 , Processed in 0.712491 second(s), 60 queries , Gzip On.
