查看: 1241|回复: 2
[每日一码] 将选择的对象拷贝到每一个图层
发表于 2018-11-10 00:45:28 | 显示全部楼层 |阅读模式
  1. (defun c:c2a ( / idx lst lyn sel )
  2.     (if (setq sel (ssget "_:L"))
  3.         (progn
  4.             (repeat (setq idx (sslength sel))
  5.                 (setq idx (1- idx)
  6.                       lst (cons (vlax-ename->vla-object (ssname sel idx)) lst)
  7.                 )
  8.             )
  9.             (while (setq lay (tblnext "layer" (not lay)))
  10.                 (if (wcmatch (setq lyn (cdr (assoc 2 lay))) "~*|*")
  11.                     (foreach obj lst
  12.                         (if (/= lyn (vla-get-layer obj))
  13.                             (vla-put-layer (vla-copy obj) lyn)
  14.                         )
  15.                     )
  16.                 )
  17.             )
  18.         )
  19.     )
  20.     (princ)
  21. )
  22. (vl-load-com) (princ)
已领礼包: 6434个
发表于 2018-11-10 11:28:04 | 显示全部楼层
也来学习一下
已领礼包: 5295个
发表于 2018-11-10 13:39:05 | 显示全部楼层
为什么要这么做?有什么用处?
GMT+8, 2026-11-5 10:58 , Processed in 0.339327 second(s), 33 queries , Gzip On.
