查看: 1490|回复: 9
[求助] 我写了一段程序,为什么老是提示“语法错误”?请帮忙看看,谢谢!
发表于 2018-11-20 10:38:35 | 显示全部楼层 |阅读模式
(defun C:SBFmain ()
  (setvar "cmdecho" 0)
  (setvar "blipmode" 0)
  (if (null dcl_pt)
    (setq dcl_pt '(-1 -1))
  (setq dcl_id (load_dialog "sbfdcl.dcl"))
  (if (not (new_dialog "sbf" dcl_id))
    (exit)
  (set_tile "lsb" "0")
  (set_tile "bsb" "0")
  (set_tile "llk" "0")
  (set_tile "bk" "0")
  (set_tile "ljc" "0")
  (set_tile "b2" "0")
  (set_tile "hjc" "0")
  (set_tile "ljc1" "0")
  (set_tile "lx" "0")
  (set_tile "b1" "0")
  (set_tile "b3" "0")
  (set_tile "ls" "0")
  (action_tile "lsb" "(setq lsb (atof (get_tile "lsb")))")
  (action_tile "bsb" "(setq bsb (atof (get_tile "bsb")))")
  (action_tile "llk" "(setq llk (atof (get_tile "llk")))")
  (action_tile "bk" "(setq  bk  (atof (get_tile "bk")))")
  (action_tile "ljc" "(setq ljc (atof (get_tile "ljc")))")
  (action_tile "b2" "(setq b2   (atof (get_tile "b2")))")
  (action_tile "hjc" "(setq hjc (atof (get_tile "hjc")))")
  (action_tile "ljc1" "(setq ljc1 (atof (get_tile "ljc1")))")
  (action_tile "lx" "(setq lx   (atof (get_tile "lx")))")
  (action_tile "b1" "(setq b1   (atof (get_tile "b1")))")
  (action_tile "b3" "(setq b3   (atof (get_tile "b3")))")
  (action_tile "ls" "(setq ls   (atof (get_tile "ls")))")
  (action_tile "accept" "(setq dcl_pt  (done_dialog 1))")                                        ; ?
                                       ; 对话框定义
  (action_tile "cancel" "(setq dcl_pt  (done_dialog 0))")                                        ; ?
                                       ; 框
  (setq dd (start_dialog))
  (cond
    ((= dd 1)
      (main)
    ((= dd 0)
      (unload_dialog)
  (prin1)
(defun main ()
(prin1)
已领礼包: 481个
发表于 2018-11-20 11:10:10 | 显示全部楼层
(defun main ()
这里语法有问题
 楼主| 发表于 2018-11-20 11:29:45 | 显示全部楼层
是不是说程序里不能有空函数?谢谢!
至少里面你要加点内容 加行 (princ)  详情 回复 发表于 2018-11-20 11:40
发表于 2018-11-20 11:40:06 | 显示全部楼层
zxc001975cvb 发表于 2018-11-20 11:29
是不是说程序里不能有空函数?谢谢!
至少里面你要加点内容
加行 (princ)
已领礼包: 418个
发表于 2018-11-20 12:47:18 | 显示全部楼层
(defun main ()
(prin1)
已领礼包: 55个
发表于 2018-11-20 13:21:54 | 显示全部楼层
T
命令: (if (not (new_dialog "sbf" dcl_id)) (exit))
; 错误: quit / exit abort
已领礼包: 6056个
发表于 2018-11-20 13:53:15 | 显示全部楼层
程序不完整。
已领礼包: 5295个
发表于 2018-11-20 19:59:26 | 显示全部楼层
试试看这样如何?
(defun C:SBFmain ()
  (if (null dcl_pt)
    (exit)
  (set_tile "bk" "0")
  (set_tile "b2" "0")
  (set_tile "lx" "0")
  (set_tile "b1" "0")
  (set_tile "b3" "0")
  (set_tile "ls" "0")
  (action_tile "lsb" "(setq lsb (atof (get_tile \"lsb\")))")
  (action_tile "bsb" "(setq bsb (atof (get_tile \"bsb\")))")
  (action_tile "llk" "(setq llk (atof (get_tile \"llk\")))")
  (action_tile "bk" "(setq  bk  (atof (get_tile \"bk\")))")
  (action_tile "ljc" "(setq ljc (atof (get_tile \"ljc\")))")
  (action_tile "b2" "(setq b2   (atof (get_tile \"b2\")))")
  (action_tile "hjc" "(setq hjc (atof (get_tile \"hjc\")))")
  (action_tile "ljc1" "(setq ljc1 (atof (get_tile \"ljc1\")))")
  (action_tile "lx" "(setq lx   (atof (get_tile \"lx\")))")
  (action_tile "b1" "(setq b1   (atof (get_tile \"b1\")))")
  (action_tile "b3" "(setq b3   (atof (get_tile \"b3\")))")
  (action_tile "ls" "(setq ls   (atof (get_tile \"ls\")))")
        ; ?; 对话框定义
        ; ?; 框
  (cond
    ((= dd 1)
      (main)
    ((= dd 0)
      (unload_dialog dcl_id)
  (prin1)
(defun main ()
(prin1)
 楼主| 发表于 2018-11-23 17:34:46 | 显示全部楼层
非常感谢!
发表于 2018-11-24 13:13:42 | 显示全部楼层
set_tile & action_tile 可以简化成字串表
  1. (setq keys '("lsb" "bsb" "llk" "bk" "ljc" "b2" "hjc" "ljc1" "lx" "b1" "b3" "ls"))
  2. (foreach x keys (set_tile x "0"))
  3. (foreach x keys
  4.   (action_tile x (strcat "(setq "x" (atof (get_tile \""x"\")))"))
  5.   )
GMT+8, 2026-11-5 00:59 , Processed in 0.750666 second(s), 51 queries , Gzip On.
