查看: 1484|回复: 5
[每日一码] 获得选择集的boudingbox
发表于 2018-11-20 23:21:58 | 显示全部楼层 |阅读模式
  1. (defun ss-boundingbox ( s / a b i m n o )
  2.     (repeat (setq i (sslength s))
  3.         (if
  4.             (and
  5.                 (setq o (vlax-ename->vla-object (ssname s (setq i (1- i)))))
  6.                 (vlax-method-applicable-p o 'getboundingbox)
  7.                 (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-getboundingbox (list o 'a 'b))))
  8.             )
  9.             (setq m (cons (vlax-safearray->list a) m)
  10.                   n (cons (vlax-safearray->list b) n)
  11.             )
  12.         )
  13.     )
  14.     (if (and m n)
  15.         (mapcar '(lambda ( a b ) (apply 'mapcar (cons a b))) '(min max) (list m n))
  16.     )
  17. )
已领礼包: 6468个
发表于 2018-11-21 00:10:55 | 显示全部楼层
boudingbox是什么?
已领礼包: 3256个
发表于 2018-11-21 07:55:41 | 显示全部楼层
楼主这么写,里面判断条件那么多,效率会很慢吧
已领礼包: 1669个
财富等级: 堆金积玉
发表于 2018-11-21 09:22:55 | 显示全部楼层
谢谢楼主的分享,先收藏备用
已领礼包: 5800个
发表于 2018-11-21 09:54:47 | 显示全部楼层
这个比较经典了,谢谢楼主
已领礼包: 9341个
发表于 2018-11-21 11:17:34 | 显示全部楼层
谢谢! Lisphk 分享学习!!!!!!
GMT+8, 2026-11-5 00:58 , Processed in 0.567279 second(s), 38 queries , Gzip On.
