查看: 1633|回复: 0
[研讨] 两个通过LAYOUT名字获取LAYOUT对象名的函数及效率测试
已领礼包: 20个
发表于 2018-11-20 23:52:54 | 显示全部楼层 |阅读模式
  1. ;;VL方法
  2. (defun _layoutvla (name / o)
  3.   (if (= 'vla-object
  4.          (type
  5.            (setq
  6.              o (vl-catch-all-apply
  7.                  'vla-item
  8.                  (list (vla-get-layouts
  9.                          (vla-get-activedocument (vlax-get-acad-object))
  10.                        )
  11.                        name
  12.                  )
  13.                )
  14.            )
  15.          )
  16.       )
  17.     o
  18.   )
  19. )
  1. ;;LISP方法
  2. (defun _layoutvic (name / o)
  3.   (if (and (setq
  4.              o (cdr (assoc -1 (dictsearch (namedobjdict) "ACAD_LAYOUT")))
  5.            )
  6.            (setq o (cdr (assoc -1 (dictsearch o name))))
  7.       )
  8.     (vlax-ename->vla-object o)
  9.   )
  10. )
测试代码:
  1. (xd::quickbench '((_layoutvic "model") (_layoutvla "model")))
可见,LISP方法dicsearch方法更快。
CPU:(1x)Intel(R) Xeon(R) E3-1575M v5 @ 3.00GHz 4Cores  / Memory:64G / OS:WIN10教育版
Benchmarking ....... done for 8192 iterations. Sorted from fastest.
Statement                    Increment  Time(ms)  Normalize  Relative
(_LAYOUTVIC Model)                8192      2000       2000      1.56 <fastest>
(_LAYOUTVLA Model)                4096      1562       3124      1.00 <slowest>
_$
GMT+8, 2026-11-5 00:59 , Processed in 0.474539 second(s), 29 queries , Gzip On.
