查看: 1740|回复: 0
[每日一码] 修改填充的背景色为无
发表于 2018-11-22 11:17:30 | 显示全部楼层 |阅读模式
  1. (defun c:tt (/ c a d)
  2.   (vl-load-com)
  3.   (vlax-for l (vla-get-layers (setq d (vla-get-activedocument (vlax-get-acad-object))))
  4.     (cond ((= -1 (vlax-get l 'lock)) (vlax-put l 'lock 0) (setq a (cons l a))))
  5.   )
  6.   (vlax-for b (vla-get-blocks d)
  7.     (if        (= 0 (vlax-get b 'isxref))
  8.       (vlax-for        o b
  9.         (cond
  10.           ((and (vlax-write-enabled-p o) (= (vla-get-objectname o) "AcDbHatch"))
  11.            (or c (progn (setq c (vla-get-backgroundcolor o)) (vla-put-entitycolor c -939524096)))
  12.            (vla-put-backgroundcolor o c)
  13.           )
  14.         )
  15.       )
  16.     )
  17.   )
  18.   (foreach l a (vlax-put l 'lock -1))
  19.   (vla-regen d acallviewports)
  20.   (princ)
  21. )
GMT+8, 2026-11-5 03:52 , Processed in 0.500527 second(s), 28 queries , Gzip On.
