查看: 2018|回复: 5
[已解决] 【已解决】想在多段线每个顶点画个圆
已领礼包: 10个
发表于 2018-11-23 16:29:19 | 显示全部楼层 |阅读模式
想在多段线每个顶点画个圆,谢谢
发表于 2018-11-23 16:43:08 | 显示全部楼层
API 随手就写了
  1. (defun c:tt ()
  2.   (if (and (setq r (getreal "\n输入半径<退出>:"))
  3.            (setq e (car
  4.                      (xdrx_entsel "\n选择多段线<退出>:" '((0 . "*polyline")))
  5.                    )
  6.            )
  7.       )
  8.     (progn (xdrx_begin)
  9.            (xdrx_polyline_compress e)
  10.            (mapcar '(lambda (x) (xdrx_circle_make x r))
  11.                    (setq pts (xdrx_getpropertyvalue e "vertices"))
  12.            )
  13.            (xdrx_prompt "\n绘制了" (length pts) "个圆")
  14.            (xdrx_end)
  15.     )
  16.   )
  17.   (princ)
  18. )
已领礼包: 106个
发表于 2018-11-23 16:45:31 | 显示全部楼层
  1. (defun c:tt ()
  2.   (setq ss (ssget ":s" '((0 . "LWPOLYLINE"))))
  3.   (Repeat (setq i (SSlength ss))
  4.     (foreach ass (ENTGET (SSNAME ss (setq i (1- i))))
  5.       (if (= (car ass) 10)
  6.         (command "_.CIRCLE" (cdr ass) "d" 5)
  7.       )
  8.     )
  9.   )
  10.   (PRINC)
  11. )
已领礼包: 20个
发表于 2018-11-23 17:58:16 | 显示全部楼层
  1. (defun c:tt (/ s tmp)
  2.   (if (and (setq r (getreal "\n半径<退出>:"))
  3.            (setq s (ssget '((0 . "*polyline"))))
  4.       )
  5.     (foreach l
  6.               (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
  7.               (mapcar '(lambda (x)
  8.                          (and (not (vl-position x tmp))
  9.                               (setq tmp (cons x tmp))
  10.                               (entmakex (list '(0 . "circle") (cons 10 x) (cons 40 r)))
  11.                          )
  12.                        )
  13.                       (list (vlax-curve-getstartpoint l)
  14.                             (vlax-curve-getendpoint l)
  15.                       )
  16.               )
  17.     )
  18.   )
  19.   (princ)
  20. )
已领礼包: 10个
 楼主| 发表于 2018-11-23 19:22:52 | 显示全部楼层
谢谢楼上各位大师
已领礼包: 6468个
发表于 2018-11-25 00:03:30 | 显示全部楼层
都是高手。
GMT+8, 2026-11-5 00:58 , Processed in 0.757407 second(s), 41 queries , Gzip On.
