查看: 2807|回复: 15
[已解决] 【已解决】如何取得视口内图层的参数
发表于 2018-12-4 15:22:56 | 显示全部楼层 |阅读模式
在布局中,每个视口均可单独设置图层的冻结、颜色、线型、线宽、透明度等参数,请问如何获取这些参数?
发表于 2018-12-4 15:25:46 | 显示全部楼层
从视口对象,查询它的属性和方法,你想要的都可以通过vla-get-xxx,或者vlax-get-property 得到
命令: (setq e (car (entsel)))
选择对象: <图元名: 7ff4a5c08290>
命令: (xd::vla:dump e)
; IAcadPViewport2: IAcadPViewport 接口
;特性值:
;   Application (RO) = #<VLA-OBJECT IAcadApplication 00007ff6ad7fa1d8>
;   ArcSmoothness = 1000
;   Center = (128.5 97.5 0.0)
;   Clipped (RO) = 0
;   CustomScale = 0.0200558
;   Direction = (0.0 0.0 1.0)
;   DisplayLocked = 0
;   Document (RO) = #<VLA-OBJECT IAcadDocument 00000000334cf550>
;   EntityTransparency = "ByLayer"
;   GridOn = 0
;   Handle (RO) = "259"
;   Ha**tensionDictionary (RO) = -1
;   HasSheetView (RO) = 0
;   Height = 156.0
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 00000000495eac98>
;   LabelBlockId = 0
;   LabelBlockId32 = 0
;   Layer = "0"
;   LayerPropertyOverrides (RO) = 0
;   LensLength = 50.0
;   Linetype = "ByLayer"
;   LinetypeScale = 1.0
;   Lineweight = -1
;   Material = "ByLayer"
;   ModelView = nil
;   ObjectID (RO) = 42
;   ObjectID32 (RO) = 42
;   ObjectName (RO) = "AcDbViewport"
;   OwnerID (RO) = 43
;   OwnerID32 (RO) = 43
;   PlotStyleName = "ByLayer"
;   ShadePlot = 0
;   SheetView = nil
;   SnapBasePoint = (0.0 0.0)
;   SnapOn = 0
;   SnapRotationAngle = 0.0
;   StandardScale = 1
;   StandardScale2 = 1
;   Target = (0.0 0.0 0.0)
;   TrueColor = #<VLA-OBJECT IAcadAcCmColor 00000000495eaff0>
;   TwistAngle = 0.0
;   UCSIconAtOrigin = -1
;   UCSIconOn = -1
;   UCSPerViewport = -1
;   ViewportOn = -1
;   Visible = -1
;   VisualStyle = 1
;   Width = 205.6
;支持的方法:
;   ArrayPolar (3)
;   ArrayRectangular (6)
;   Copy ()
;   Delete ()
;   Display (1)
;   GetBoundingBox (2)
;   GetExtensionDictionary ()
;   GetGridSpacing (2)
;   GetSnapSpacing (2)
;   GetXData (3)
;   Highlight (1)
;   IntersectWith (2)
;   Mirror (2)
;   Mirror3D (3)
;   Move (2)
;   Rotate (2)
;   Rotate3D (3)
;   ScaleEntity (2)
;   SetGridSpacing (2)
;   SetSnapSpacing (2)
;   SetXData (2)
;   SyncModelView ()
;   TransformBy (1)
;   Update ()
 楼主| 发表于 2018-12-4 16:13:43 | 显示全部楼层
这种方法只能得到视口本身的参数吧?我希望得到的是视口内每个图层的参数。
发表于 2018-12-4 16:38:59 | 显示全部楼层
当前视口的图层状态,保存在视口对象的扩展实体数据里面
正常的视口的扩展实体数据
命令: (entget (car (entsel)) '("*"))
选择对象: ((-1 . <图元名: 7ff4a5c084c0>) (0 . "VIEWPORT") (5 . "27C") (102 .
"{ACAD_XDICTIONARY") (360 . <图元名: 7ff4a5c084d0>) (102 . "}") (330 . <图元名:
7ff4a5c03de0>) (100 . "AcDbEntity") (67 . 1) (410 . "布局2") (8 . "abc") (100 .
"AcDbViewport") (10 128.5 97.5 0.0) (40 . 205.6) (41 . 156.0) (68 . 2) (69 . 2)
(12 6237.27 1156.26 0.0) (13 0.0 0.0 0.0) (14 10.0 10.0 0.0) (15 10.0 10.0 0.0)
(16 0.0 0.0 1.0) (17 0.0 0.0 0.0) (42 . 50.0) (43 . 0.0) (44 . 0.0) (45 .
7778.3) (50 . 0.0) (51 . 0.0) (72 . 1000) (90 . 557152) (281 . 0) (71 . 1) (74
. 0) (110 0.0 0.0 0.0) (111 1.0 0.0 0.0) (112 0.0 1.0 0.0) (79 . 0) (146 . 0.0)
(170 . 0) (61 . 5) (348 . <图元名: 7ff4a5c03f50>) (292 . 1) (282 . 1) (141 . 0.0)
(142 . 0.0) (63 . 250) (421 . 3355443) (-3 ("ACAD" (1000 . "MVIEW") (1002 .
"{") (1070 . 16) (1010 0.0 0.0 0.0) (1010 0.0 0.0 1.0) (1040 . 0.0) (1040 .
7778.3) (1040 . 6237.27) (1040 . 1156.26) (1040 . 50.0) (1040 . 0.0) (1040 .
0.0) (1070 . 0) (1070 . 1000) (1070 . 1) (1070 . 3) (1070 . 0) (1070 . 0) (1070
. 0) (1070 . 0) (1040 . 0.0) (1040 . 0.0) (1040 . 0.0) (1040 . 10.0) (1040 .
10.0) (1040 . 10.0) (1040 . 10.0) (1070 . 0) (1002 . "{") (1002 . "}") (1002 .
图层ABC当前视口冻结后的扩展实体数据
选择对象: ((-1 . <图元名: 7ff4a5c08290>) (0 . "VIEWPORT") (5 . "259") (102 .
"{ACAD_XDICTIONARY") (360 . <图元名: 7ff4a5c082a0>) (102 . "}") (330 . <图元名:
7ff4a5c03da0>) (100 . "AcDbEntity") (67 . 1) (410 . "布局1") (8 . "0") (100 .
7778.3) (50 . 0.0) (51 . 0.0) (72 . 1000) (331 . <图元名: 7ff4a5c08350>) (90 .
557152) (281 . 0) (71 . 1) (74 . 0) (110 0.0 0.0 0.0) (111 1.0 0.0 0.0) (112
0.0 1.0 0.0) (79 . 0) (146 . 0.0) (170 . 0) (61 . 5) (348 . <图元名:
7ff4a5c03f50>) (292 . 1) (282 . 1) (141 . 0.0) (142 . 0.0) (63 . 250) (421 .
3355443) (-3 ("ACAD" (1000 . "MVIEW") (1002 . "{") (1070 . 16) (1010 0.0 0.0
0.0) (1010 0.0 0.0 1.0) (1040 . 0.0) (1040 . 7778.3) (1040 . 6237.27) (1040 .
1156.26) (1040 . 50.0) (1040 . 0.0) (1040 . 0.0) (1070 . 0) (1070 . 1000) (1070
. 1) (1070 . 3) (1070 . 0) (1070 . 0) (1070 . 0) (1070 . 0) (1040 . 0.0) (1040
. 0.0) (1040 . 0.0) (1040 . 10.0) (1040 . 10.0) (1040 . 10.0) (1040 . 10.0)
(1070 . 0)
(1002 . "{") (1003 . "abc") (1002 . "}") (1002 . "}"))))
发表于 2018-12-4 16:54:44 | 显示全部楼层
API 关于 viewport 图层相关的函数
xdrx_viewport_thawLayers
xdrx_viewport_thawAllLayers
xdrx_viewport_SetLayersFrozen
xdrx_viewport_FrozenLayerList
xdrx_viewport_IsLayerFrozen
命令: (xdrx_viewport_FrozenLayerList e)
(<图元名: 7ff4a5c08350>)
 楼主| 发表于 2018-12-4 17:26:53 | 显示全部楼层
选择对象: ((-1 . <图元名: 7ffffb54de0>) (0 . "VIEWPORT") (330 . <图元名: 7ffffb54c30>) (5
. "FB0DE") (100 . "AcDbEntity") (67 . 1) (410 . "装修水") (8 . "VPORTS") (100 .
"AcDbViewport") (10 20279.8 14865.4 0.0) (40 . 30324.8) (41 . 20057.9) (68 . 2)
(69 . 2) (12 -152731.0 15608.4 0.0) (13 0.0 0.0 0.0) (14 1.0 1.0 0.0) (15 0.0
0.0 0.0) (16 0.0 0.0 1.0) (17 0.0 0.0 0.0) (42 . 50.0) (43 . 0.0) (44 . 0.0)
(45 . 20057.9) (50 . 0.0) (51 . 0.0) (72 . 100) (331 . <图元名: 7ffffb11570>) (331
. <图元名: 7ffffb25200>) (331 . <图元名: 7ffffb36e90>) (331 . <图元名: 7ffffb3bde0>)
(331 . <图元名: 7ffffb3e2e0>) (331 . <图元名: 7ffffb494a0>) (331 . <图元名:
7ffffb57a00>) (331 . <图元名: 7ffffb57a30>) (331 . <图元名: 7ffffb57a70>) (90 .
819232) (281 . 0) (71 . 1) (74 . 0) (110 0.0 0.0 0.0) (111 1.0 0.0 0.0) (112
0.0 1.0 0.0) (79 . 0) (146 . 0.0) (170 . 0) (61 . 5) (348 . <图元名: 7ffffb03b10>)
(292 . 1) (282 . 1) (141 . 0.0) (142 . 0.0) (63 . 250) (421 . 3355443))
没有-3组码,只有331组码,表示图层被冻结。
 楼主| 发表于 2018-12-4 17:28:20 | 显示全部楼层
问题是,图层是否被冻结只是其中一个参数。还有其它的颜色、线宽等参数到哪儿去找?
在AUTOCAD中,这种一个对象的额外信息,不是在扩展实体,就是在扩展词典中,对视口除了冻结信息保存在扩展实体中,其他的保存在扩展词典里面。420组码是颜色值 XRECORD的名字有: ADSK_XREC_LAYER_COLOR_OVR AD  详情 回复 发表于 2018-12-4 22:53
和视口有关的,只是一个图层是否冻结,其他的参数,是公用的, 你想找什么的颜色?什么的线宽?  详情 回复 发表于 2018-12-4 17:52
发表于 2018-12-4 17:52:21 | 显示全部楼层
你想找什么的颜色?什么的线宽?
 楼主| 发表于 2018-12-4 19:18:25 | 显示全部楼层
就是这样的。
 楼主| 发表于 2018-12-4 19:19:52 | 显示全部楼层
比如说“家具”层,视口中的颜色、线型、线宽都与公用的不同
 楼主| 发表于 2018-12-4 19:22:35 | 显示全部楼层
我想要的就是视口中的图层参数
发表于 2018-12-4 22:53:45 | 显示全部楼层
XRECORD的名字有:
ADSK_XREC_LAYER_LINETYPE_OVR
ADSK_XREC_LAYER_LINEWT_OVR
ADSK_XREC_LAYER_ALPHA_OVR
ADSK_XREC_LAYER_PLOTSTYLE_OVR
图层ABC,在不同的视口里面设置了不同的颜色
下面代码把他们找出来
  1. (defun c:tt (/ lyr ext rec)
  2.   (if (and (/= (setq lyr (getstring "\n输入层名<退出>:")) "")
  3.            (setq lyr (tblobjname "layer" lyr))
  4.            (setq ext (cdr (assoc 360 (entget lyr))))
  5.       )
  6.     (dictsearch ext "ADSK_XREC_LAYER_COLOR_OVR")
  7.   )
  8. )
命令: tt
输入层名<退出>:abc
((-1 . <图元名: 7ff4d7605b00>) (0 . "XRECORD") (5 . "1E8") (102 .
"{ACAD_REACTORS") (330 . <图元名: 7ff4d7605af0>) (102 . "}") (330 . <图元名:
7ff4d7605af0>) (100 . "AcDbXrecord") (280 . 1) (102 .
"{ADSK_LYR_COLOR_OVERRIDE") (335 . <图元名: 7ff4d7605ac0>) (420 . -1023409955)
(102 . "}") (102 . "{ADSK_LYR_COLOR_OVERRIDE") (335 . <图元名: 7ff4d7605c10>) (420
. -1023410175) (102 . "}"))
应该是这样了。但是这个颜色如何转换成索引颜色号呢?  详情 回复 发表于 2018-12-5 10:07
发表于 2018-12-4 22:57:06 | 显示全部楼层
谢谢分享。
 楼主| 发表于 2018-12-5 10:07:17 | 显示全部楼层
marting 发表于 2018-12-4 22:53
在AUTOCAD中,这种一个对象的额外信息,不是在扩展实体,就是在扩展词典中,对视口除了冻结信息保存在扩 ...
去开源函数库 [*](XD::Color:RGB->True)RGB转真彩色0 个回复 - 0 次查看命令: (xd::color:rgb->true 12 34 56) 795192 命令: (xd::color:rgb->true 255 0 0) 167116802018-3-29 16:28 - marting - 开源函数库  详情 回复 发表于 2018-12-5 11:10
发表于 2018-12-5 11:10:15 | 显示全部楼层
去开源函数库
GMT+8, 2026-11-22 10:08 , Processed in 0.429001 second(s), 38 queries , Gzip On, File On.
