查看: 1881|回复: 1
[图块] (XD:Block:Delete)删除指定文档的块(处理锁定层)
发表于 2018-12-6 09:56:16 | 显示全部楼层 |阅读模式
函数发布
函数名称: XD:Block:Delete
调用格式: (XD:Block:Delete doc lst)
参数说明: doc ---- 文档对象
lst ---- 图块名字符串表
返回值: 图块名表 或 NIL
函数简介: 图块删除,删除图块定义和所有的引用INSERT
函数来源: 原创
函数作者: marting
适用版本: 不限
最后更新时间: 2018-12-06
备注: -
演示图片: -
  1. (defun XD:Block:Delete (doc lst / blc bln lck rtn)
  2.   (if (not doc)
  3.     (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  4.   )
  5.   (setq blc (vla-get-blocks doc)
  6.         lst (mapcar 'strcase lst)
  7.   )
  8.   (vlax-for lay (vla-get-layers doc)
  9.     (if (= :vlax-true (vla-get-lock lay))
  10.       (progn (setq lck (cons lay lck))
  11.              (vla-put-lock lay :vlax-false)
  12.       )
  13.     )
  14.   )
  15.   (vlax-for def blc
  16.     (vlax-for obj def
  17.       (if (and (= "AcDbBlockReference" (vla-get-objectname obj))
  18.                (or (and (vlax-property-available-p obj 'effectivename)
  19.                         (setq bln (strcase (vla-get-effectivename obj)))
  20.                    )
  21.                    (setq bln (strcase (vla-get-name obj)))
  22.                )
  23.                (vl-some '(lambda (x) (wcmatch bln x)) lst)
  24.           )
  25.         (progn (vl-catch-all-apply 'vla-delete (list obj))
  26.                (or (member bln rtn) (setq rtn (cons bln rtn)))
  27.         )
  28.       )
  29.     )
  30.   )
  31.   (foreach lay lck (vla-put-lock lay :vlax-true))
  32.   (vl-remove-if
  33.     '(lambda (x)
  34.        (vl-catch-all-error-p
  35.          (vl-catch-all-apply 'vla-delete (list (vla-item blc x)))
  36.        )
  37.      )
  38.     rtn
  39.   )
  40. )
发表于 2018-12-19 17:39:04 | 显示全部楼层
大师请问这个只在在DBX里面调用有没有问题?
GMT+8, 2026-11-22 07:44 , Processed in 0.188904 second(s), 12 queries , Gzip On, File On.
