查看: 1207|回复: 1
[求助] 用VB.net开发AutoCAD连接Access数据库时出错,求助各位大神
发表于 2018-12-6 22:42:07 | 显示全部楼层 |阅读模式
Imports Autodesk.AutoCAD.ApplicationServices '定义和注册新的AutoCAD命令
Imports Autodesk.AutoCAD.DatabaseServices '组成AutoCAD图形数据库的元素
Imports Autodesk.AutoCAD.Runtime '提供系统级别的功能,如DLL初始化和运行时类的注册与确认
Imports Autodesk.AutoCAD.EditorInput '提供与用户交互有关的类
Imports Autodesk.AutoCAD.Colors '与颜色有关的类
Imports Autodesk.AutoCAD.Windows '访问AutoCad中的对话框、面板、托盘、状态栏等
Imports Autodesk.AutoCAD.Geometry '用来执行2D或3D几何操作
Imports System.IO
Imports LAcadApp = Autodesk.AutoCAD.ApplicationServices.Application
Public Class LClass_Business
    <CommandMethod("LInitialization")>
    Public Sub LCreateLayer() '创建图层
        Dim LlayerName As String = "abc"
        Dim LlayerColor As Color = Color.FromColorIndex(ColorMethod.ByColor, 120) '通过颜色索引值定义颜色
        Dim db As Database = HostApplicationServices.WorkingDatabase '当前工作CAD
        Dim AcsConStr As String
        Dim AcsCon As New ADODB.Connection
        Dim SqlRs As New ADODB.Recordset
        Dim i As Long
        AcsConStr = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & My.Application.Info.DirectoryPath & "\DATA\Config.mdb;Persist Security Info=False;Jet OLEDB:Database Password=cnpccei"
        Try
            AcsCon.Open(AcsConStr)
            SqlRs.Open("select * from Layers", AcsCon, ADODB.CursorTypeEnum.adOpenStatic, ADODB.LockTypeEnum.adLockOptimistic)
            i = SqlRs.RecordCount
            LlayerName = SqlRs(1).Value
            LlayerColor = SqlRs("LayerColor").Value
            SqlRs.Close()
            AcsCon.Close()
            SqlRs = Nothing
            AcsCon = Nothing
        Catch ex As Exception
            'MsgBox(ex.Message, ex.GetType.ToString(), "打开数据库")
            MsgBox(Err.Description, MsgBoxStyle.OkOnly, "打开数据库链接")
        End Try
end sub
以上代码在执行到AcsCon.Open(AcsConStr)时出错
 楼主| 发表于 2018-12-6 22:46:22 | 显示全部楼层
错误如图
GMT+8, 2026-11-3 07:33 , Processed in 0.450162 second(s), 32 queries , Gzip On.
