查看: 1494|回复: 1
[每日一码] VL修改指定的多重引线样式
发表于 2019-1-8 09:32:06 | 显示全部楼层 |阅读模式
修改名字为Engineering的多重引线样式
[Actionscript3] 纯文本查看 复制代码
(defun c:mleaderstylecreate (/ dict mldict mldstyle thgt)
  (setq dict   (vla-get-dictionaries acadDocument)
        mldict (vl-catch-all-apply
                 'vla-item
                 (list dict "ACAD_MLEADERSTYLE")
  ) ;_ end of setq
  (if (setq ss (sstdblk "TBLK 8x11"))
    (setq thgt 0.06)
    (setq thgt 0.09)
  (if (setq mldstyle (vla-item mldict "Engineering"))
    (progn (vlax-put-property mldstyle 'ArrowSize 0.125)
           (vlax-put-property mldstyle 'LandingGap (/ thgt 2))
           (vlax-put-property mldstyle 'TextHeight thgt)
    ) ;_ end of progn
  ) ;_ end of if
) ;_ end of defun
已领礼包: 1094个
发表于 2020-12-8 15:58:07 | 显示全部楼层
感谢Lisphk,找了好久终于找到我要的了。
GMT+8, 2026-11-3 19:13 , Processed in 0.435382 second(s), 30 queries , Gzip On.
