查看: 4227|回复: 20
[求助] 两曲线之间插入等距曲线 插件
发表于 2019-1-17 11:51:47 | 显示全部楼层 |阅读模式
悬赏20D豆未解决
求在两曲线之间插入等距曲线 插件,谢谢
发表于 2019-1-17 12:07:04 | 显示全部楼层
你这是用什么插件做的?
把制作的结果的DWG,传下来下吧。
这是在明经论坛上看到的动画示意图,就是不知道用的什么插件  详情 回复 发表于 2019-1-19 09:27
 楼主| 发表于 2019-1-19 09:27:45 | 显示全部楼层
newer 发表于 2019-1-17 12:07
你这是用什么插件做的?
把制作的结果的DWG,传下来下吧。
已领礼包: 586个
发表于 2019-3-20 19:14:33 来自手机 | 显示全部楼层
十等分吗?
来自: 微社区
已领礼包: 586个
发表于 2019-3-25 09:22:08 | 显示全部楼层
10等分,插入了9根线(defun c:djx( / ent1 ent2 num p1list p2list p3list i cp p1 bfb)
        (setq ent1 (car (entsel "\n[选择第1线条]:")))
        (setq ent2 (car (entsel"\n[选择第2线条]:")))
        (setq num 100)
        (if (ssget "x" (list (cons 0 "POINT"))) (command "erase" (ssget "x" (list (cons 0 "POINT"))) ""))
        (command "divide" ent1 num)
        (setq ent1 (ssget "x" (list (cons 0 "POINT"))))
        (setq p1list nil i 0)
        (while (setq cp (ssname ent1 i))
                (setq p1list (append p1list (list (cdr (assoc 10 (entget cp))))))
                (setq i (1+ i))
        (command "erase" ent1 "")
        (command "divide" ent2 num)
        (setq ent2 (ssget "x" (list (cons 0 "POINT"))))
        (setq p2list nil i 0)
        (while (setq cp (ssname ent2 i))
                (setq p2list (append p2list (list (cdr (assoc 10 (entget cp))))))
                (setq i (1+ i))
        (command "erase" ent2 "")
        (if (> (distance (nth 0 p1list) (nth 0 p2list)) (distance (nth 0 p1list) (nth (- num 2) p2list)))
            (setq p2list (reverse p2list))
        (setq bfb 0.1)
        (command "undo" "be")
          (repeat 9
        (setq i 0 p3list nil)
        (while (and (setq cp (nth i p1list)) (setq cp1 (nth i p2list)))
                (setq p3 (list (+ (car cp) (* (- (car cp1) (car cp)) bfb)) (+ (cadr cp) (* (- (cadr cp1) (cadr cp)) bfb))))
                (setq p3list (append p3list (list p3)) i (1+ i))
        (setq temposm (getvar "osmode"))
        (setvar "osmode" 0)
        (setq i 2 p1 (nth 0 p3list) cp (nth 1 p3list))
        (command "pline" (trans p1 0 1) (trans cp 0 1) "")
        (setq ent1 (entlast) p1 cp)
        (while (setq cp (nth i p3list))
                (command "line" (trans p1 0 1) (trans cp 0 1) "")
                (command "pedit" ent1 "J" (entlast) "" "")
                (setq p1 cp i (1+ i))
        (command "change" (entlast) "" "P" "C" "3" "")
        (setq bfb (+ bfb 0.1))
        (setvar "osmode" temposm)
        (command "undo" "e")
        (princ)
大师说错了 是希望 能否改成输入自定义根数。  详情 回复 发表于 2019-6-5 14:58
能否改成可以输入自由段数。就完美了。  详情 回复 发表于 2019-6-1 16:04
已领礼包: 21个
发表于 2019-6-1 16:04:45 | 显示全部楼层
        (setq ent1 (car  ...
能否改成可以输入自由段数。就完美了。
有考虑过:约5mm或其它长设置一个点  发表于 2019-6-3 13:17
已领礼包: 21个
发表于 2019-6-5 14:58:01 | 显示全部楼层
        (setq ent1 (car  ...
肯定可以啊  发表于 2019-6-7 08:38
发表于 2019-6-5 20:57:38 来自手机 | 显示全部楼层
有源码了,改下就行
来自: 微社区
已领礼包: 586个
发表于 2019-6-7 09:16:22 来自手机 | 显示全部楼层
程序中的变量bfb初始值为0.1,即与第一条曲线距离与2曲线距离的比值为0.1的位置插入曲线,每次递增0.1,重复9次(repeat 9),插入了9根曲线。自己修改下bfb的初始值,递增值及重复次数就可以了
来自: 微社区
;n等分,插入n-1根线 (defun c:djx( / ent1 ent2 num p1list p2list p3list i cp p1 bfb n) (prompt "\n插件目的:在选定的2条线之间插入n-1条等分线") (setq n (getint "\n输入等分数量n:"))  详情 回复 发表于 2019-6-8 10:29
已领礼包: 586个
发表于 2019-6-7 09:21:55 来自手机 | 显示全部楼层
如果要n等分,把程序中的0.1修改成 (/ 1.0 n),共2处;把程序中的9改成n,共1处
来自: 微社区
已领礼包: 586个
发表于 2019-6-7 09:23:19 来自手机 | 显示全部楼层
说错了,应该是
把程序中的9改成n-1,共1处
来自: 微社区
已领礼包: 55个
发表于 2019-6-7 10:53:02 | 显示全部楼层
思路很巧妙啊,
已领礼包: 586个
发表于 2019-6-8 10:29:00 | 显示全部楼层
王鹏_pBZlo 发表于 2019-6-7 09:16
程序中的变量bfb初始值为0.1,即与第一条曲线距离与2曲线距离的比值为0.1的位置插入曲线,每次递增0.1, ...
;n等分,插入n-1根线
        (setq num 100)
                (setq i (1+ i))
                (setq i (1+ i))
        (setq bfb (/ 1.0 n))
          (repeat (1- n)
        (setvar "osmode" 0)
        (setq bfb (+ bfb (/ 1.0 n)))
        (princ)
已领礼包: 511个
发表于 2019-6-8 10:57:51 | 显示全部楼层
王老师思路巧妙,如果线条有交点,在交点处有点缺憾。这里对您的程序做了些修改,请多指正
(defun c:df( / ent1 ent2 strr1 strr2 p11 p12 p21 p22 num p1list p2list p3list i ii cp p1 bfb ss)
        (if (/= sss nil)(command "erase" sss ""))
        (setvar "cmdecho" 0)(setvar "osmode" 0)
        (setq ent1 (car (entsel "\n[选择第1线条]:")) ent2 (car (entsel "\n[选择第2线条]:")))
        (setq strr1 (entget ent1) strr2 (entget ent2))
        (setq p11 (vLax-Curve-getStartPoint ent1) p12 (vLax-curve-getEndPoint ent1))
          (setq p21 (vLax-Curve-getStartPoint ent2) p22 (vLax-curve-getEndPoint ent2))
        (zpl)
        (if (> (distance p11 p21) (distance p11 p22))(fx1))
        (setq stjd nil stds nil jd nil)
        (if         (setq jd (vlax-invoke (vlax-ename->vla-object Ent1)'IntersectWith (vlax-ename->vla-object ent2) 0))
                (progn         (setq i 0)
                        (while (< i (length jd))
                                (setq stjd (cons (list (nth i jd)(nth (+ i 1) jd)(nth (+ i 2) jd)) stjd) i (+ i 3)))
                        (if (> (length stjd) 1)
                                (progn
                                        (foreach x stjd        (setq stds (cons (vlax-curve-getdistatpoint ent1 x) stds)))
                                          (setq stds1 nil stmd nil)
                                          (repeat (1- (length stjd))
                                                  (setq md (apply 'max stds))
                                                  (setq ii 0)
                                                (while (/= md (nth ii stds))(setq ii (1+ ii)))
                                                  (setq stmd (cons md stmd))
                                                  (setq stds1 (cons (nth ii stjd) stds1))
                                                  (setq stjd (vl-remove nil (mapcar '(lambda (x) (if (member x stds1) nil  x)) stjd)))
                                                  (setq stds (vl-remove nil (mapcar '(lambda (x) (if (member x stmd) nil  x)) stds)))
                                          (setq stds (cons (nth 0 stds) stmd))
                                          (setq stjd (reverse (cons (nth 0 stjd) stds1)))
                        (setq str1 (reverse (cons p12 (reverse (cons p11 stjd)))) str2 (reverse (cons p22 (reverse (cons p21 stjd)))))
                        (setq nds (length str1) i 1 num 50 p1list nil p2list nil)
                        (while (< i (1- nds))
                                (setq p0 (nth i str1))
                                (command "break" ent1 p0 p0)
                                (setq ent10 (entlast))
                                (setq ss1 (ssget "x" (list (cons 0 "POINT"))))
                                (setq  ii (- num 2) p1list (cons (nth (1- i) str1) p1list))
                                (while        (>= ii 0)
                                          (setq cp (ssname ss1 ii))
                                        (setq p1list (cons (cdr (assoc 10 (entget cp))) p1list) ii (1- ii)))
                                (command "erase" ss1 "")(command "erase" ent1 "")
                                (command "break" ent2 p0 p0)
                                (setq ent20 (entlast))
                                (setq  ii (- num 2) p2list (cons (nth (1- i) str2) p2list))
                                (while        (>= ii 0)
                                        (setq p2list (cons (cdr (assoc 10 (entget cp))) p2list) ii (1- ii)))
                                (command "erase" ss1 "")(command "erase" ent2 "")
                                  (setq ent1 ent10 ent2 ent20)
                                (setq i (1+ i))          )
                        (while        (>= ii 0)
                        (setq p1list (cons (nth i str1) p1list))
                        (while        (>= ii 0)
                        (setq p2list (cons (nth i str2) p2list))
                        (entmake strr1)(entmake strr2)
                        (ht)        )
                (wj)        )
        (princ)        )
(defun fx1()
        (command "T81_TRevPline" ent2)
        (setq p21 (vLax-Curve-getStartPoint ent2) p22 (vLax-curve-getEndPoint ent2) stjd nil jd nil)        )
(defun zpL()
        (setq lb (cdr (assoc 0 (entget ent2))))
        (if (/= lb "LWPOLYLINE")
                (cond ((= lb "LINE")(progn (command "pedit" ent2 "y" "")(setq ent2 (entlast))))
                        ((= lb "ARC")(progn (command "pedit" ent2 "y" "")(setq ent2 (entlast))))
                        ((= lb "POLYLINE")(progn (command "pedit" ent2 "")(setq ent2 (entlast))))
                        (t (zcc)))        )        )
(defun zcc()
        (if (setq e (ssget "aLL" '((0 . "point"))))(command "erase" e ""))
        (setq num 100)
        (setq st1 (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline")(cons 90 (+ 2 (sslength e)))))
          (setq st1 (append st1 (list (cons 10 p22))) mi 0)
        (repeat (sslength e)
                  (setq st1 (append st1 (list (assoc 10 (entget (ssname e mi)))  )))
                  (setq mi (1+ mi))        )
          (setq st1 (append st1 (list (cons 10 p21))))
        (entmake st1)
        (setq ent2 (entlast))        )
(defun wj()
                (setq num 50)
                (setq p1list nil i 0 p1list (cons p12 p1list))
                (while (setq cp (ssname ss1 i))
                        (setq p1list (cons (cdr (assoc 10 (entget cp))) p1list) i (1+ i)))
                (setq p1list (cons p11 p1list))
                (setq ss2 (ssget "x" (list (cons 0 "POINT"))))
                (setq p2list nil i 0 p2list (cons p22 p2list))
                (while (setq cp (ssname ss2 i))
                        (setq p2list (cons (cdr (assoc 10 (entget cp))) p2list) i (1+ i)))
                (setq p2list (cons p21 p2list))
                (command "erase" ss2 "")
                (ht)        )
(defun ht()
        (setq ts 5)
        (if (SETQ ts1 (getint (strcat "\n输入线条数目<" (rtos ts) ">:")))(setq ts ts1))
        (setq yss 20)
        (if (SETQ yss1 (getint (strcat "\n输入等分线颜色数值(1~20)<" (rtos yss) ">:")))(setq yss yss1))
        (setq bfb (/ 1.0 (1+ ts)) nts 1 ii 0)(SETQ YS1 (/ pi (1- ts)))
        (setq sss (ssadd))
        (repeat ts
                        (setq p3 (list (+ (car cp) (* (- (car cp1) (car cp)) (* bfb nts))) (+ (cadr cp) (* (- (cadr cp1) (cadr cp)) (* bfb nts)))))
                        (setq p3list (append p3list (list p3)) i (1+ i)))
                (setq st1 (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline")(cons 90 (length p3list))))
                (setq mi 0)
                (repeat (length p3list)
                          (setq st1 (append st1 (list (cons 10 (nth mi p3list)) )))
                          (setq mi (1+ mi))                )
                (entmake st1)
                (ssadd (entlast) sss)
                (setq ys (+ (* yss 10) (fix  (* (sin (* ii ys1)) 30) ) ) )
                (command "change" (entlast) "" "P" "C" (rtos ys) "")
                (setq nts (1+ nts) ii (1+ ii))
(prompt "\n等阶线示例,命令:df")(princ)
已领礼包: 586个
发表于 2019-6-8 14:30:49 来自手机 | 显示全部楼层
从你的程序中又学到了几个函数,比如获得曲线的起点和终点。我对vlax系列的函数知道的很少。会好好研究一下你的程序,可以改进一下我以前编的插件。你比我高明。
来自: 微社区
GMT+8, 2026-11-2 22:39 , Processed in 0.579086 second(s), 59 queries , Gzip On.
