查看: 1326|回复: 0
[求助] 程序运行时卡顿现象很严重
发表于 2019-1-24 12:53:51 | 显示全部楼层 |阅读模式
以下是程序源码,在执行的时候CAD卡顿现象很严重。比如块(见附件)比较多情况下,选择块进行复制或其他操作是都比较卡顿,选中进行下一步操作都会卡顿几秒,已测试是该程序问题。还有该程序会导致保存卡顿,请大神们看下问题在哪,给修改下 。谢谢!
Private Sub AcadDocument_SelectionChanged()
On Error Resume Next
Dim EqINFO As Variant
Dim xtypeout As Variant
Dim xdataout As Variant
Dim ELE As AcadBlockReference
Dim EQ_BLOCK_DATA As Variant       '¿éÄúêôDÔ¼ˉoÏ
Dim EqName_att As AcadAttributeReference  'êôDÔ
Dim EqId_att As AcadAttributeReference    '
Dim EQ_BLOCK_entity As AcadEntity         '¿éÄúμÄêμìå
Dim pline As AcadLWPolyline            '¿éÄú¶à¶ÎÏß
Set ELE = PickfirstSelectionSet.Item(0)
Dim a(2), b(2) As Variant
Dim c(2), d(2) As Variant
           If ELE.HasAttributes Then EQ_BLOCK_DATA = ELE.GetAttributes
            Set EqName_att = EQ_BLOCK_DATA(1)      'μÃμ½êôDÔ¶ÔÏó
            Set EqId_att = EQ_BLOCK_DATA(0)
            'MsgBox EqName_att.MTextAttribute
            'End If
      With EqName_att
     a(0) = .InsertionPoint(0)      '2åèëμãX×ø±ê
     a(1) = .InsertionPoint(1)      '2åèëμãY×ø±ê
     b(0) = .TextAlignmentPoint(0)  '¶ÔÆëμãX×ø±ê,ÖD¼ä¶ÔÆë
     b(1) = .TextAlignmentPoint(1)  '¶ÔÆëμãY×ø±ê£¬ÖD¼ä¶ÔÆë
     End With
      With EqId_att
     c(0) = .InsertionPoint(0)      '2åèëμãX×ø±ê
     c(1) = .InsertionPoint(1)      '2åèëμãY×ø±ê
     d(0) = .TextAlignmentPoint(0)  '¶ÔÆëμãX×ø±ê,ÖD¼ä¶ÔÆë
     d(1) = .TextAlignmentPoint(1)  '¶ÔÆëμãY×ø±ê£¬ÖD¼ä¶ÔÆë
     End With
     Dim S_DATA, S_data1, S_data2
       S_data1 = (b(0) - a(0)) * 2
        'MsgBox S_DATA
       S_data2 = (d(0) - c(0)) * 2
       'MsgBox S_data1 & "," & S_data2
       If S_data1 < S_data2 Then
         S_DATA = S_data2
    ElseIf S_data1 > S_data2 Then
          S_DATA = S_data1
    End If
Dim dybprop As Variant
Dim i
    If ELE.IsDynamicBlock Then
     dybprop = ELE.GetDynamicBlockProperties
       For i = LBound(dybprop) To UBound(dybprop) 'Goes through Results
                    If dybprop(i).PropertyName = "eqline" Then 'Looks for the PropertyName
                    dybprop(i).Value = S_DATA     'Change the Value of the PropertyName
                    End If
       Next i
       End If
End Sub
GMT+8, 2026-11-22 08:55 , Processed in 0.189736 second(s), 8 queries , Gzip On, File On.
