查看: 1889|回复: 2
[编程申请] 如何表达一段空间多段线的长度和折角 并且 打断 标注 展开 画在平面上j就像pepa kura
发表于 2019-3-11 16:07:41 | 显示全部楼层 |阅读模式
  • (defun c:tcc()
  • 如何表达一段空间多段线的长度和折角 并且 打断 标注 展开  画在平面上j就像pepa kura-1.gif     (if (setq ssa (ssget ":S" '((0 . "lwpolyline"))))
  •         (if (setq wjm (getfiled "存盘文件" "e:\" "csv" 1))
  •              (progn
  •                   (setq ent (ssname ssa 0)
  •                         dxf (entget ent)
  •                         pts (mapcar 'cdr (vl-remove-if '(lambda(x)(/= (car x) 10)) dxf))
  •                   (setq i 0  n (length pts))
  •                   (setq jgb nil)
  •                   (setq fff (open wjm "w"))
  •                   (write-line "节点号,X值,Y值,长度(m),角度(°)" fff)
  •                   (repeat n
  •                       (if (= i 0)
  •                           (setq p1 (last pts))
  •                           (setq p1 (nth (1- i) pts))
  •                       (setq p2 (nth i pts))
  •                       (if (= i (1- n))
  •                           (setq p3 (car pts))
  •                           (setq p3 (nth (1+ i) pts))
  •                       (setq jlz (distance p1 p2))
  •                       (setq ang (- (angle p2 p3) (angle p2 p1)))
  •                       (if (< ang 0) (setq ang (+ ang (* 2 pi))))
  •                       (if (> ang pi) (setq ang (- (* 2 pi) ang)))
  •                       (setq ang (vl-string-subst "" "d" (angtos ang 1 0)))
  •                       (setq i (1+ i))
  •                       (write-line (strcat (itoa i) ","
  •                                           (rtos (car  p2) 2 3) ","
  •                                           (rtos (cadr p2) 2 3) ","
  •                                           (rtos jlz 2 1) ","
  •                                           ang
  •                                   fff
  •                   (close fff)
  •     (princ)
发表于 2019-3-11 17:55:03 | 显示全部楼层
什么是 pepa kura ?
[attachimg]85647[/attachimg] 可以先拍平空间多段线,再标注折角和长度,然后标注或导出高程差和起终点绝对坐标,即可表达空间多段线  详情 回复 发表于 2019-3-12 08:24
 楼主| 发表于 2019-3-12 08:24:30 | 显示全部楼层
Lisphk 发表于 2019-3-11 17:55
什么是 pepa kura ?
可以先拍平空间多段线,再标注折角和长度,然后标注或导出高程差和起终点绝对坐标,即可表达空间多段线,问题是如何修改lisp
GMT+8, 2026-11-22 10:16 , Processed in 0.439346 second(s), 14 queries , Gzip On, File On.
