查看: 1616|回复: 6
[已解决] 【已解决】大神帮忙了
已领礼包: 158个
发表于 2019-3-16 08:23:31 | 显示全部楼层 |阅读模式
下面这个正常
  1. (defun c:anniu1        (/                listtoolbars   bitname1
  2.                  bitname2        bitname3       currmenugroup
  3.                  index1                index2               index3
  4.                  macro1                macro2               macro3
  5.                  name1                name2               name3
  6.                  newtoolbar        newtoolbarbutton1
  7.                  newtoolbarbutton2               newtoolbarbutton3
  8.                  newtoolbarsel
  9.                 )
  10.   (defun listtoolbars (groupname / mgroups mgroup lst)
  11.     (if        (not
  12.           (vl-catch-all-error-p
  13.             (setq mgroup
  14.                    (vl-catch-all-apply
  15.                      'vla-item
  16.                      (list (vla-get-menugroups (vlax-get-acad-object))
  17.                            groupname
  18.                      )
  19.                    )
  20.             )
  21.           )
  22.         )
  23.       (vlax-for        tbar (vla-get-toolbars mgroup)
  24.         (setq lst (cons (vla-get-name tbar) lst))
  25.       )
  26.     )
  27.   )
  28.   (setq        currmenugroup
  29.          (vla-item (vla-get-menugroups (vlax-get-acad-object))
  30.                    0
  31.          )
  32.   )
  33.   (if (and (= (vl-position "经纬仪" (listtoolbars "acad")) nil)
  34.            (= (vl-position "经纬仪" (listtoolbars "custom")) nil)
  35.       )
  36.     (progn
  37.       (setq newtoolbarsel (vla-get-toolbars currmenugroup))
  38.       (setq newtoolbar (vla-add newtoolbarsel "经纬仪"))
  39.       (setq macro1
  40.              (strcat (chr 3) (chr 3) (chr 95) "zjfy" (chr 32))
  41.       )
  42.       (setq macro2
  43.              (strcat (chr 3) (chr 3) (chr 95) "txbh" (chr 32))
  44.       )
  45.       (setq macro3
  46.              (strcat (chr 3) (chr 3) (chr 95) "jdhz" (chr 32))
  47.       )
  48.       (setq index1 0
  49.             index2 1
  50.             index3 2
  51.       )
  52.       (setq name1 "桩机放样")
  53.       (setq name2 "图形编号")
  54.       (setq name3 "基点绘制")
  55.       (setq newtoolbarbutton1
  56.              (vla-addtoolbarbutton
  57.                newtoolbar index1 name1 name1 macro1)
  58.       )
  59.       (setq newtoolbarbutton2
  60.              (vla-addtoolbarbutton
  61.                newtoolbar index2 name2 name2 macro2)
  62.       )
  63.       (setq newtoolbarbutton3
  64.              (vla-addtoolbarbutton
  65.                newtoolbar index3 name3 name3 macro3)
  66.       )
  67.       (setq bitname1 "c:\\temp\\zhuangji.ico")
  68.       (setq bitname2 "c:\\temp\\zwbh.ico")
  69.       (setq bitname3 "c:\\temp\\hui.ico")
  70.       (vla-setbitmaps newtoolbarbutton1 bitname1 bitname1)
  71.       (vla-setbitmaps newtoolbarbutton2 bitname2 bitname2)
  72.       (vla-setbitmaps newtoolbarbutton3 bitname3 bitname3)
  73.       (vla-put-visible newtoolbar :vlax-true)
  74.     )
  75.   )
  76.   (princ)
  77. )
这个出错
  1. (defun c:anniu2 (/              listtoolbars  bitname          currmenugroup
  2.                 index              lst            name          name1
  3.                 newtoolbar    newtoolbarbutton                  newtoolbarsel
  4.                 macro
  5.                )
  6.   (defun listtoolbars (groupname / mgroups mgroup lst)
  7.     (if        (not
  8.           (vl-catch-all-error-p
  9.             (setq mgroup
  10.                    (vl-catch-all-apply
  11.                      'vla-item
  12.                      (list (vla-get-menugroups (vlax-get-acad-object))
  13.                            groupname
  14.                      )
  15.                    )
  16.             )
  17.           )
  18.         )
  19.       (vlax-for        tbar (vla-get-toolbars mgroup)
  20.         (setq lst (cons (vla-get-name tbar) lst))
  21.       )
  22.     )
  23.   )
  24.   (setq        currmenugroup
  25.          (vla-item (vla-get-menugroups (vlax-get-acad-object))
  26.                    0
  27.          )
  28.   )
  29.   (if (and (= (vl-position "经纬仪4" (listtoolbars "acad")) nil)
  30.            (= (vl-position "经纬仪4" (listtoolbars "custom")) nil)
  31.       )
  32.     (progn
  33.       (setq newtoolbarsel (vla-get-toolbars currmenugroup))
  34.       (setq newtoolbar (vla-add newtoolbarsel "经纬仪4"))
  35.       (setq lst        '(("桩机放样" "zjfy" "c:\\temp\\zhuangji.ico")
  36.                   ("图形编号" "txbh" "c:\\temp\\zwbh.ico")
  37.                   ("基点绘制" "jdhz" "c:\\temp\\hui.ico")
  38.                  )
  39.       )
  40.       (setq index 0)
  41.       (foreach x lst
  42.         (setq name    (car x)
  43.               macro   (cadr x)
  44.               bitname (caddr x)
  45.         )
  46.         (setq newtoolbarbutton
  47.                (vla-addtoolbarbutton
  48.                  newtoolbar
  49.                  index
  50.                  name
  51.                  name
  52.                  (strcat (chr 3) (chr 3) (chr 95) macro (chr 95))
  53.                )
  54.         )
  55.         (vla-setbitmaps newtoolbarbutton bitname bitname)
  56.         (setq index (1+ index))
  57.       )
  58.       (vla-put-visible newtoolbar :vlax-true)
  59.     )
  60.   )
  61.   (princ)
  62. )
第一段代码运行正常,第二段出现问题,知识不够,大神们帮帮忙调试
发表于 2019-3-16 21:34:17 | 显示全部楼层
楼主,怎么解决的?
已领礼包: 158个
 楼主| 发表于 2019-3-16 22:37:34 来自手机 | 显示全部楼层
用了牢固大神的一个函数,我也不明白是什么原理
来自: 微社区
哪个函数啊,贴出来啊。  详情 回复 发表于 2019-3-17 00:09
发表于 2019-3-17 00:09:54 | 显示全部楼层
哪个函数啊,贴出来啊。
已领礼包: 158个
 楼主| 发表于 2019-3-17 12:50:32 | 显示全部楼层
newer 发表于 2019-3-17 00:09
哪个函数啊,贴出来啊。
  1. (defun addToolbars (toolbarname         lst              /
  2.                     gxl-catchapply              bitname           toolbars
  3.                     index         lst              name           name1
  4.                     newtoolbar         newtoolbarbutton           macro
  5.                    )
  6.   (defun gxl-catchapply        (fun args / result)
  7.     (if        (not (vl-catch-all-error-p
  8.                (setq result
  9.                       (vl-catch-all-apply
  10.                         (if (= 'sym (type fun))
  11.                           fun
  12.                           (function fun)
  13.                         )
  14.                         args
  15.                       )
  16.                )
  17.              )
  18.         )
  19.       result
  20.     )
  21.   )
  22.   (setq        toolbars
  23.          (vla-get-toolbars
  24.            (vla-item (vla-get-menugroups (vlax-get-acad-object))
  25.                      0
  26.            )
  27.          )
  28.   )
  29.   (if (setq newtoolbar
  30.              (gxl-catchapply
  31.                vla-item
  32.                (list toolbars toolbarname)
  33.              )
  34.       )
  35.     (vla-delete newtoolbar)
  36.   )
  37.   (setq newtoolbar (vla-add toolbars toolbarname))
  38.   (foreach x lst
  39.     (setq index          0
  40.           name          (car x)
  41.           macro          (cadr x)
  42.           bitname (caddr x)
  43.     )
  44.     (cond ((= name "--") (vla-addseparator newtoolbar (1+ index)))
  45.           (t
  47.                   (gxl-catchapply
  48.                     vla-addtoolbarbutton
  49.                     (list newtoolbar
  50.                           index
  51.                           name
  52.                           name
  53.                           (strcat (chr 32) (chr 32) (chr 95) macro (chr 32))
  54.                     )
  55.                   )
  56.            )
  57.            (gxl-catchapply
  58.              vla-setbitmaps
  59.              (list newtoolbarbutton bitname bitname)
  60.            )
  61.           )
  62.     )
  63.     (setq index (1+ index))
  64.   )
  65.   (vla-put-visible newtoolbar :vlax-true)
  66.   (princ)
  67. )
  68. ;|
  69. (addToolbars   "文字工具3"
  70.   '(("文字合并" "wzhb" "wwzhb.ico")
  71.     ("文字对齐" "wzdq" "wwzdq.ico")
  72.         ("--")
  73.     ("文字编号" "wzbh" "wwzbh.ico")
  74.    )
  75. )
已领礼包: 6468个
发表于 2019-3-17 21:08:57 | 显示全部楼层
这个功能是做什么用的?
已领礼包: 6434个
发表于 2019-3-18 08:05:24 | 显示全部楼层
牢固大神的一个函数?
GMT+8, 2026-11-4 22:50 , Processed in 0.477768 second(s), 44 queries , Gzip On.
