查看: 1563|回复: 5
[求助] 复制旋转1次的
发表于 2019-3-19 16:58:07 | 显示全部楼层 |阅读模式
(defun C:HJ (/ LAST_PT SS)
  (while (and (princ "\n★选择对象复制旋转")
              (setq SS (ssget))
    (command "_.COPY" SS "" "_none" "0,0,0" "@")
    (command "_.move" ss "")
    (while (= (getvar "CMDNAMES") "MOVE")
      (command PAUSE)
    (if        (setq LAST_PT (getvar "LASTPOINT"))
      (progn
        (command "_.ROTATE" ss "" "_NON" LAST_pT)
        (while (= (getvar "CMDNAMES") "ROTATE")
          (command PAUSE)
  (princ)
已领礼包: 5295个
发表于 2019-3-19 20:34:39 | 显示全部楼层
这个代码有点意思。
发表于 2019-3-27 00:22:18 | 显示全部楼层
Thanks for sharing ^^
 楼主| 发表于 2019-4-8 10:42:05 | 显示全部楼层
帮忙改下赛!
已领礼包: 138个
发表于 2020-5-5 08:05:12 | 显示全部楼层
资料 收藏 谢谢
已领礼包: 2个
发表于 2020-5-5 16:13:34 | 显示全部楼层
              (setq SS (ssget))
    (setq p0 (getpoint "\选择复制旋转原点:"))
    (command "_.COPY" SS "" "_none" p0 "@")
      (command PAUSE)
      (progn
          (command PAUSE)
  (princ)
GMT+8, 2026-11-4 03:00 , Processed in 0.549956 second(s), 39 queries , Gzip On.
