楼主: uualice
[已解决] (已解决)自动修改编号
 楼主| 发表于 2019-5-2 06:09:18 来自手机 | 显示全部楼层
对的,就是这个思路
来自: 微社区
 楼主| 发表于 2019-5-2 06:28:56 | 显示全部楼层
王鹏_pBZlo 发表于 2019-5-2 06:04
如果纯粹是修改,不考虑原因的话,可以修改一下。
条件是,修改某个编号使得编号增加一个1或2或...,图中 ...
对的,就是这样的思路,最好后面自动修改的编号有可供选择的,我需要自动修改哪几个编号,就选择哪几个
发表于 2019-5-2 09:02:52 | 显示全部楼层
(defun c:tt( / catt ctxt pre sset i txt)
        (defun t2l (string / str_ex_num s_word string_list)
        (if (= "" string)
            (setq string_list (list ""))
            (progn        (setq str_ex_num 1 string_list nil)
                (while (not (> str_ex_num (strlen string)))
                        (setq s_word (substr string str_ex_num 1))
                        (if (= s_word "-")
                            (progn        (setq string_list (append string_list (list (substr string 1 (1- str_ex_num)))))
                                    (setq string (substr string (+ 1 str_ex_num)))
                                (setq str_ex_num 1))
                            (setq str_ex_num (1+ str_ex_num))
                (if (/= "" string) (setq string_list (append string_list (list string))))))
        string_list)
        (setq catt (car (entsel "\n选择修改编号:")))
        (command "undo" "be")
        (setq ctxt (t2l (cdr (assoc 1 (entget catt)))))
        (setq pre (strcat (car ctxt) "-"))
        (setq on (cadr ctxt))
        (command "ddedit" catt "")
        (setq nn (- (atoi (cadr (t2l (cdr (assoc 1 (entget catt)))))) (atoi on)))
        (prompt "\n选择需相应修改的其它编号")
        (setq sset (ssget  (list (cons 0 "TEXT") (cons 1 (strcat pre "#," pre "##," pre "###")))))
        (setq i 0)
        (while (setq catt (ssname sset i))
                (setq txt (cdr (assoc 1 (entget catt))) txt (t2l txt))
                (if (>= (atoi (cadr txt)) (atoi on))
                    (progn        (setq txt (strcat pre (itoa (+ nn (atoi (cadr txt))))))
                        (entmod (subst (cons 1 txt) (assoc 1 (entget catt)) (entget catt)))
                (setq i (1+ i))
        (command "undo" "e")(princ)
发表于 2019-5-2 11:30:18 来自手机 | 显示全部楼层
按要求修改完成
来自: 微社区
评分
参与人数 1D豆 +10 收起 理由
cbwt8116 + 10 热心帮忙奖!
查看全部评分
回复 支持 1 反对 0
 楼主| 发表于 2019-5-2 16:38:19 | 显示全部楼层
恩 ,已达到要求,谢谢
发表于 2019-9-20 12:04:11 | 显示全部楼层
强大功能,谢谢提供
GMT+8, 2026-11-22 08:56 , Processed in 0.354011 second(s), 23 queries , Gzip On, File On.
