楼主: shqvc
[已解决] 今天申请两个功能 希望大神可以看一下
已领礼包: 586个
发表于 2019-7-6 17:30:19 | 显示全部楼层
给你来一个移动圆或圆弧相切的,移动到最近的相切点,切点可能不在圆弧上而在圆弧的延长线上
(defun c:tt( / arc1 arc2 py par1 par2 r1 r2 c1 c2 temp1 temp2 intpt p1 p2)
        (setq arc1 (car (entsel "\n选择圆或圆弧:")))
        (setq arc2 (car (entsel "\n移动到圆或圆弧:")))
        (while (and (/= py "H") (/= py "V"))
                (setq py (strcase (getstring "\n[水平移动(H)/垂直移动(V)]:")))
        (setq par1 (entget arc1) par2 (entget arc2))
        (setq r1 (cdr (assoc 40 par1)) r2 (cdr (assoc 40 par2)))
        (setq c1 (cdr (assoc 10 par1)) c2 (cdr (assoc 10 par2)))
        (entmake (list (cons 0 "CIRCLE") (cons 10 c2) (cons 40 (+ r1 r2)))) (setq temp1 (entlast))
        (cond         ((= py "H") (entmake (list (cons 0 "LINE") (cons 10 c1) (cons 11 (list (+ (nth 0 c1) 10) (nth 1 c1) (nth 2 c1))))) (setq temp2 (entlast)))
                ((= py "V") (entmake (list (cons 0 "LINE") (cons 10 c1) (cons 11 (list (nth 0 c1) (+ 10 (nth 1 c1)) (nth 2 c1))))) (setq temp2 (entlast)))
        (setq intpt (vlax-invoke (vlax-ename->vla-object temp2) 'IntersectWith (vlax-ename->vla-object temp1) acextendthisentity))
        (entdel temp1) (entdel temp2)
        (setq p1 (list (nth 0 intpt)(nth 1 intpt)(nth 2 intpt)) p2 (list (nth 3 intpt)(nth 4 intpt)(nth 5 intpt)))
        (if (< (distance c1 p1) (distance c1 p2)) (setq c1 p1) (setq c1 p2))
        (entmod (subst (cons 10 c1) (assoc 10 par1) par1))
        (princ)
我来试一下 这个圆和圆相切的工具很好用 真的很棒 如果能让一组跟着一起动就好了 不过这样也很棒了  详情 回复 发表于 2019-7-7 20:18
我来试一下  详情 回复 发表于 2019-7-7 19:08
已领礼包: 586个
发表于 2019-7-6 18:38:01 | 显示全部楼层
圆弧或圆移动到直线相切
(defun c:tt1( / arc1 lin2 py par1 par2 c1 p1 p2 ang c2 intpt intpt1temposm)
        (setq lin2 (car (entsel "\n移动到直线:")))
        (command "undo" "be")
        (setq temposm (getvar "osmode"))
        (setq par1 (entget arc1) par2 (entget lin2))
        (setq c1 (cdr (assoc 10 par1)))
        (setq p1 (cdr (assoc 10 par2)) p2 (cdr (assoc 11 par2)))
        (setq ang (+ (/ pi 2.0) (angle p1 p2)))
        (setq c2 (polar c1 ang 10))
        (entmake (list (cons 0 "LINE") (cons 10 c1) (cons 11 c2)))
        (setq intpt (vlax-invoke (vlax-ename->vla-object (entlast)) 'IntersectWith (vlax-ename->vla-object arc1) acextendboth))
        (setq intpt1 (vlax-invoke (vlax-ename->vla-object (entlast)) 'IntersectWith (vlax-ename->vla-object lin2) acextendboth))
        (if (> (distance intpt1 p1) (distance intpt1 p2)) (setq p1 p2))
        (entdel (entlast))
        (cond         ((= py "H") (entmake (list (cons 0 "LINE") (cons 10 p1) (cons 11 (list (1+ (nth 0 p1)) (nth 1 p1) (nth 2 p1))))))
                ((= py "V") (entmake (list (cons 0 "LINE") (cons 10 p1) (cons 11 (list (nth 0 p1) (1+ (nth 1 p1)) (nth 2 p1))))))
        (setq intpt (vlax-invoke (vlax-ename->vla-object (entlast)) 'IntersectWith (vlax-ename->vla-object lin2) acextendboth))
        (entdel (entlast))
        (setvar "osmode" 0)
        (command "move" arc1 "" p1 intpt)
        (setvar "osmode" temposm)
        (command "undo" "e")
        (princ)
已领礼包: 130个
 楼主| 发表于 2019-7-7 19:08:40 | 显示全部楼层
(defun c:tt( / ...
我来试一下
已领礼包: 130个
 楼主| 发表于 2019-7-7 20:18:59 | 显示全部楼层
(defun c:tt( / ...
已领礼包: 586个
发表于 2019-7-7 20:42:20 来自手机 | 显示全部楼层
shqvc 发表于 2019-7-7 20:18
我来试一下    这个圆和圆相切的工具很好用  真的很棒   如果能让一组跟着一起动就好了  不过这样也很棒 ...
一组跟同一个圆相切容易实现,各自对应就不好判断了
来自: 微社区
看不懂没有事 我们可以交流一下 最好是QQ或是微信 这样交流还快 比论坛快也更方便  详情 回复 发表于 2019-7-11 12:53
有联系方式吗 如果有的话 给一个 您可以把我的那个断线的也解决一下  详情 回复 发表于 2019-7-11 10:29
已领礼包: 130个
 楼主| 发表于 2019-7-11 10:29:03 | 显示全部楼层
你那个断线的描述看不懂  发表于 2019-7-11 12:38
已领礼包: 130个
 楼主| 发表于 2019-7-11 12:53:05 | 显示全部楼层
发表于 2019-9-25 00:59:57 来自手机 | 显示全部楼层
不知道说的是什么
来自: 微社区
我们行业不同 所有您不知道  详情 回复 发表于 2019-9-25 10:27
我们行业不同 所有您不知道  详情 回复 发表于 2019-9-25 10:25
已领礼包: 130个
 楼主| 发表于 2019-9-25 10:25:34 | 显示全部楼层
lsthz 发表于 2019-9-25 00:59
不知道说的是什么
我们行业不同  所有您不知道
已领礼包: 130个
 楼主| 发表于 2019-9-25 10:27:15 | 显示全部楼层
不知道说的是什么
我们行业不同  所有您不知道
GMT+8, 2026-11-3 06:28 , Processed in 0.526540 second(s), 51 queries , Gzip On.
