查看: 2150|回复: 3
[原创] 箭头
发表于 2019-7-10 17:10:35 | 显示全部楼层 |阅读模式
  1. Public MsoLineRun1 As Boolean
  2. Private Sub Workbook_SheetSelectionChange(ByVal Sh As Object, ByVal Target As Range)
  3.     If MsoLineRun1 Then
  4.         Call KillMsoLine
  5.     Else
  6.         Call MsoLineRun(Sh, Target)
  7.     End If
  8. End Sub
  9. '''增加一个虚箭头
  10. Function AddMsoLine(ByVal s As String, ByVal Sh As Object) As Object
  11.     Set AddMsoLine = Sh.Shapes.AddConnector(msoConnectorStraight, 0, 0, 100, 50)
  12.     With AddMsoLine.Line
  13.         .EndArrowheadStyle = msoArrowheadOpen
  14.         .Visible = msoTrue
  15.         .DashStyle = msoLineDashDot
  16.         .ForeColor.RGB = RGB(255, 0, 0)
  17.         .Weight = 0
  18.         .Parent.AlternativeText = s
  19.         .Parent.Name = s
  20.     End With
  21. End Function
  22. ''判断虚箭头是否存在,不存在则添加
  23. Function MsoLineExist(ByVal s As String, ByVal Sh As Object) As Object
  24.     For Each x In Sh.Shapes
  25.         If x.Name = s And x.AlternativeText = s Then Set MsoLineExist = x: Exit For
  26.     Next
  27. End Function
  28. '''小平箭头Hor1,竖直箭头Ver1
  29. Sub MsoLineRun(ByVal Sh As Object, ByVal Target As Range)
  30.     Dim obj As Object
  31.     Dim Left1&, Top1&, Column1&, Row1&
  32.     Application.ScreenUpdating = False
  33.     Application.EnableEvents = False
  34.     If Target.Rows.Count = 1 And Target.Columns.Count = 1 Then
  35.     Application.ScreenUpdating = False
  36.     Application.ScreenUpdating = True
  37.         With ActiveCell
  38.             Left1 = .Left
  39.             Top1 = .Top
  40.             Column1 = .Column
  41.             Row1 = .Row
  42.         End With
  43.         Set obj = MsoLineExist("Hor1", Sh)
  44.         If obj Is Nothing Then Set obj = AddMsoLine("Hor1", Sh)
  45.         With obj
  46.             .Left = Left1 + ActiveCell.Width * 0.5
  47.             .Top = Sh.Cells(1, Column1).Top
  48.             .Width = 0
  49.             .Height = Top1
  50.         End With
  51.         Set obj = MsoLineExist("Ver1", Sh)
  52.         If obj Is Nothing Then Set obj = AddMsoLine("Ver1", Sh)
  53.         With obj
  54.             .Left = Sh.Cells(Row1, 1).Left
  55.             .Top = Top1 + ActiveCell.Height * 0.5
  56.             .Width = Left1
  57.             .Height = 0
  58.         End With
  59.     End If
  60.     Application.EnableEvents = True
  61.     Application.ScreenUpdating = True
  62. End Sub
  63. '''箭头驻留
  64. Sub RemainMsoLine()
  65.     Dim name1$, count1&
  66.     Dim x As Object
  67.     Application.ScreenUpdating = False
  68.     Application.EnableEvents = False
  69.     count1 = ActiveSheet.Shapes.Count
  70.     For Each x In ActiveSheet.Shapes
  71.         name1 = x.Name
  72.         If name1 = "Hor1" Or name1 = "Ver1" Then
  73.             x.Name = Left(name1, Len(name1) - 1) & (count1 + 1)
  74.         End If
  75.     Next
  76.     Application.EnableEvents = True
  77.     Application.ScreenUpdating = True
  78. End Sub
  79. '''箭头删除
  80. Sub KillMsoLine()
  81.     Application.ScreenUpdating = False
  82.     Application.EnableEvents = False
  83.     For Each x In ActiveSheet.Shapes
  84.         If x.Type = msoAutoShape Then
  85.             If InStr(x.Name, "Hor") > 0 Or InStr(x.Name, "Ver") > 0 Then x.Delete
  86.         End If
  87.     Next
  88.     Application.EnableEvents = True
  89.     Application.ScreenUpdating = True
  90. End Sub
  91. '''箭头开关,这个值应该保存在注册表中,auto_open时读取
  92. Sub SwitchMsoLine()
  93.     MsoLineRun1 = Not MsoLineRun1
  94. End Sub
指示箭头.xls
52 KB, 下载次数: 5, 下载积分: D豆 -1 , 活跃度 1
发表于 2019-7-10 19:03:28 | 显示全部楼层
谢谢提供好好试试看了
发表于 2019-7-11 09:11:55 | 显示全部楼层
这个就有点厉害了
发表于 2024-8-9 13:02:11 | 显示全部楼层
感谢黄老师分享
GMT+8, 2026-11-22 08:26 , Processed in 0.401223 second(s), 16 queries , Gzip On, File On.
