查看: 2587|回复: 3
[研讨] acedSSGet :KacedSSGet选择图元时使用关键词
发表于 2019-7-12 22:39:41 | 显示全部楼层 |阅读模式
This method allow a custom code to be executed when the user selects a keyword, which allow us include some additional keywords.
On the sample below, when acedSSGet() is called in a custom command, the user is able to use two new keywords: LInes to select all lines in the current drawing and CIRcles to select all circles. The callback function uses all possible return values.
First, check below the custom command, that register for the call back.
void MyCustomCommand()
  // save the old callback function
  resbuf* (*oldFunc) (const ACHAR*);
  acedSSGetKwordCallbackPtr(&oldFunc);
  // set own callback function
  acedSSSetKwordCallbackPtr(ssCallback);
  // let the user make a selection
  ads_name ss;
  // this is the keyword list
  // to use local and global keywords:
  ACHAR kwordlist[] = { _T("LInes CIRcles _ LInes CIRcles") };
  if (RTNORM != acedSSGet(_T("_:K"), NULL, kwordlist, NULL, ss)) {
    // cancel
  } else {
    acutPrintf(_T("\nDone."));
    acedSSFree(ss);
  // restore old callback function
  acedSSSetKwordCallbackPtr(*oldFunc);
Now the callback that is executed when the keyword is selected:
// Callback function for acedSSGet()
resbuf* ssCallback(const TCHAR* kword)
  // kword contains the global keyword
  acutPrintf(_T("\nCallback: '%s'"), kword);
  // result to return
  // NULL: no changes on selection set
  resbuf *result = NULL;
  if (!wcscmp(kword, _T("LInes"))) {
    // select all lines (just for testing)
    AcDbObjectIdArray objIds;
    getLines(objIds);
    // create resbuf containing single
    // enames from object id array
    result = getResbuf(objIds);
  } else if (!wcscmp(kword, _T("CIRcles"))) {
    // select all circles (just for testing)
    getCircles(objIds);
    // create resbuf containing a selection set
    ads_name ss;
    acedSSGet(_T("X"), NULL, NULL,
      acutBuildList(RTDXF0, _T("CIRCLE"), RTNONE),
      ss);
    result = acutBuildList(RTPICKS, ss, RTNONE);
  } else {
    // return an error message
    result = acutBuildList(RTSTR, _T("\nUnknown error"), RTNONE);
  return result;
And finally some additional methods for this specific sample:
resbuf* getResbuf(AcDbObjectIdArray ids)
  resbuf *result = NULL, *temp1, *temp2;
  ads_name ename;
  int length = ids.length();
  for (int i = 0; i < length; ++i) {
    acdbGetAdsName(ename, ids);
    temp2 = acutBuildList(RTENAME, ename, RTNONE);
    if (result == NULL) {
      result = temp2;
    } else {
      temp1->rbnext = temp2;
    temp1 = temp2;
  return result;
void getLines(AcDbObjectIdArray& ids)
  // select all lines from model space
  // (without any error checking)
  AcDbBlockTable *pTable;
  AcDbBlockTableRecord *pModelSpace;
  AcDbBlockTableRecordIterator *pIter;
  AcDbEntity* pEnt;
  acdbHostApplicationServices()->workingDatabase()->
    getBlockTable(pTable, AcDb::kForRead);
  pTable->getAt(ACDB_MODEL_SPACE, pModelSpace, AcDb::kForRead);
  pTable->close();
  pModelSpace->newIterator(pIter);
  pModelSpace->close();
  for (; !pIter->done(); pIter->step()) {
    pIter->getEntity(pEnt, AcDb::kForRead);
    if (pEnt->isKindOf(AcDbLine::desc()))
      ids.append(pEnt->objectId());
    pEnt->close();
  delete pIter;
void getCircles(AcDbObjectIdArray& ids)
  // select all circles from model space
  AcDbEntity* pEnt;
  pTable->close();
    if (pEnt->isKindOf(AcDbCircle::desc()))
    pEnt->close();
  delete pIter;
以上为ObjectARX示例的acedSSGet使用K模式的示例,
  ads_name ss;
    // cancel
  } else {
    acedSSFree(ss);
现在想知道,当选择时不输入关键词,而是正常选择图元后,如何获取选择集ss?若输入了关键词,如LInes,ssCallback中的
    getLines(objIds);
返回值result从哪里可以获取到?
正常情况下acedSSGet获取到选择集后,都是要对选择集进行处理的,请问选择集处理相关部分代码应该加在哪里?
发表于 2019-7-13 22:44:11 | 显示全部楼层
谢谢分享,尝试一下
发表于 2019-7-14 15:22:07 | 显示全部楼层
    // cancel
  } else {
//无论是否使用关键字,这里返回ss的就是结果的选择集
//这个关键字的例子类似添加过滤,
    acedSSFree(ss);
请问用了关键字后,在关键字调用中继续使用了acedssget,获取到的图元会在ss的选择集中返回吗?  详情 回复 发表于 2019-7-15 08:58
 楼主| 发表于 2019-7-15 08:58:25 | 显示全部楼层
    // cancel
  } else {
谢谢,我试试
GMT+8, 2026-11-22 09:20 , Processed in 0.383561 second(s), 14 queries , Gzip On, File On.
