查看: 1103|回复: 3
[求助] 帮忙修改下以下含数,两点在终点画构造线!附上一个即指即显的动态信息显示!
已领礼包: 50个
发表于 2019-7-23 11:56:59 | 显示全部楼层 |阅读模式
菜鸟求助!!!帮忙修改下让线不要出现在中间,要在终点画构造线,可以连续画!
(defun c:CV (/ ang mpt pt1 pt2 v)
    (setq pt1 (getpoint "输入起点:"))
    (setq pt2 (getpoint pt1 "输入终点:"))
    (setq mpt (mapcar (function (lambda (x y) (/ (+ x y)2.0))) pt1 pt2))
        (setq
    ang (+ (angle pt1 pt2) (/ pi 2))
     v (polar '(0 0 0) ang 1)
    (entmake (list
     '(0 . "XLINE")
    '(100 . "AcDbEntity")
    '(62 . 1)
     '(100 . "AcDbXline")
     (cons 10 (trans mpt 1 0))
    (cons 11 (trans v 1 0))
  (princ)
以下为网上找来的--------动态信息显示--------还有很多好玩的动态工具待分享--------
;;-----------------------=={  Dynamic Information Tool  }==----------------------;;
;;  Information about an object is displayed upon the user moving the cursor     ;;
;;  over the object. The cursor size may be altered using the +/- keys, and the  ;;
;;  program mode may be changed using the TAB key.                               ;;
;;  Click or Hit Enter to Exit the Program                                       ;;
;;  +/- Increase or Decrease Cursor Pick Box respectively.                       ;;
;;  Hit 'TAB' to switch modes:-                                                  ;;
;;  DINFO Mode    ~    Information about an object is displayed.                 ;;
;;  LAYISO Mode   ~    Isolate a Layer by clicking an object on that layer,      ;;
;;                     Shift-click to turn on all layers.                        ;;
;;  FUNCTION SYNTAX:  DINFO                                                      ;;
;;  Author:  Lee Mac, Copyright ?2011 -                        ;;
;;  Version 1.0    -    09-05-2009                                               ;;
;;  First Release        ;;
;;  Version 1.1    -    04-04-2010                                               ;;
;;  Complete program upgrade.                                                    ;;
;;  Removed Object Editing functionality (unnecessary).                          ;;
;;  Version 1.2    -    06-04-2010                                               ;;
;;  Added additional properties to list.                                         ;;
;;  Accounted for Radian measurements.                                           ;;
;;  Added 'Belongs to' Field.                                                    ;;
;;  Version 1.3    -    07-04-2010                                               ;;
;;  Fixed Dynamic Block SelectionSet error.                                      ;;
;;  Version 1.4    -    07-04-2010                                               ;;
;;  Added Dynamic Block Flag.                                                    ;;
;;  Version 1.5    -    06-01-2011                                               ;;
;;  Updated code formatting.                                                     ;;
;;  Fixed bug pertaining to Polylines within Blocks/XRefs.                       ;;
(defun c:DInfo
  (   /  ;;         --=={ Local Functions }==--          ;
         *error*
         _Display
         dxf
         _GetColour
         _GetLW
         _GetName
         _GetScale
         PurgeLayer
         _PutDXF
         ss->lst
         _Stringify
         _Text
         _Update
         ;;         --=={ Local Variables }==--          ;
         -pi/4
         5pi/4
         alignment
         celst
         cent
         cobj
         code
         data
         doc
         e
         express
         gr
         inter
         layers
         mode
         modelst
         msg
         msglst
         on
         owner
         pi/4
         r
         rad
         spc
         ss
         telst
         tent
         vs
         x
         ;;         --=={ Global Variables }==--         ;
         ; DInfo:Mode    -- Global: Function Number
         ; DInfo:cRad    -- Global: Cursor Aperture
  (vl-load-com)
  ;;                           --=={  Preliminaries  }==--                         ;;
  (setq spc
    (vlax-get-property
      (setq doc
        (vla-get-ActiveDocument (vlax-get-acad-object))
      (if (= 1 (getvar 'CVPORT)) 'PaperSpace 'ModelSpace)
  (vlax-for l (vla-get-layers doc)
    (setq layers (cons l layers))
    (if (eq :vlax-true (vla-get-Layeron l))
      (setq on (cons l on))
  (setq Express
    (and (vl-position "acetutil.arx" (arx))
      (not
        (vl-catch-all-error-p
          (vl-catch-all-apply
            (function (lambda nil (acet-sys-shift-down)))
  (setq ModeLst '("DINFO" "LAYISO"))
  (or DInfo:Mode (setq DInfo:Mode 0))
  (or DInfo:cRad (setq DInfo:cRad 25.0))
  (setq Alignment
    (list
      (cons acAlignmentLeft               "Left"          )
      (cons acAlignmentCenter             "Center"        )
      (cons acAlignmentRight              "Right"         )
      (cons acAlignmentAligned            "Aligned"       )
      (cons acAlignmentMiddle             "Middle"        )
      (cons acAlignmentFit                "Fit"           )
      (cons acAlignmentTopLeft            "Top-Left"      )
      (cons acAlignmentTopCenter          "Top-Center"    )
      (cons acAlignmentTopRight           "Top-Right"     )
      (cons acAlignmentMiddleLeft         "Middle-Left"   )
      (cons acAlignmentMiddleCenter       "Middle-Center" )
      (cons acAlignmentMiddleRight        "Middle-Right"  )
      (cons acAlignmentBottomLeft         "Bottom-Left"   )
      (cons acAlignmentBottomCenter       "Bottom-Center" )
      (cons acAlignmentBottomRight        "Bottom-Right"  )
  (setq Attachment
    (list
      (cons acAttachmentPointTopLeft      "Top-Left"      )
      (cons acAttachmentPointTopCenter    "Top-Center"    )
      (cons acAttachmentPointTopRight     "Top-Right"     )
      (cons acAttachmentPointMiddleLeft   "Middle-Left"   )
      (cons acAttachmentPointMiddleCenter "Middle-Center" )
      (cons acAttachmentPointMiddleRight  "Middle-Right"  )
      (cons acAttachmentPointBottomLeft   "Bottom-Left"   )
      (cons acAttachmentPointBottomCenter "Bottom-Center" )
      (cons acAttachmentPointBottomRight  "Bottom-Right"  )
  ;;                           --=={  Local Functions  }==--                       ;;
  ;;  --=={  Error Handler  }==--
  (defun *error* ( msg )
    (if cEnt (entdel cEnt))
    (if tEnt (entdel tEnt))
    (if on (mapcar '(lambda ( x ) (vla-put-layeron x :vlax-true)) on))
    (PurgeLayer "LMAC_DINFO")
    (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
        (princ (strcat "\n** Error: " msg " **")))
    (princ)
  (defun _PutDXF ( e x r )
    (entmod (subst (cons x r) (assoc x e) e))
  (defun _Update ( e )
    (entupd (cdr (assoc -1 e)))
  (defun _Text ( tx ) (strcat "{\\fArial|b1|i0|c0|p34;" tx "}"))
  (defun ss->lst ( ss / i ent lst )
    (setq i -1)
    (while (setq ent (ssname ss (setq i (1+ i))))
      (setq lst (cons (vlax-ename->vla-object ent) lst))
    lst
  (defun _GetColour ( e / c )
    (if (setq c (cdr (assoc 62 e)))
      (cond
          (cdr
            (assoc c
                (0 . "ByBlock")
                (1 . "Red")
                (2 . "Yellow")
                (3 . "Green")
                (4 . "Cyan")
                (5 . "Blue")
                (6 . "Magenta")
                (7 . "White")
        ( (itoa c) )
      "ByLayer"
  (defun _GetScale ( e )
    (vl-princ-to-string
      (mapcar
        (function
          (lambda ( x )
            (rtos (dxf x e) (getvar 'LUNITS) 2)
       '(41 42 43)
  (defun _GetName ( obj )
    (if (vlax-property-available-p obj 'EffectiveName)
      (vla-get-EffectiveName obj)
      (vla-get-name obj)
  (defun _GetLW ( e / w )
    (if (setq w (cdr (assoc 370 e)))
      (cond
          (cdr
            (assoc w
                (-1 . "ByLayer")
                (-2 . "ByBlock")
                (-3 . "Default")
        ( (strcat (rtos (/ w 100.) 2 2) "mm") )
      "ByLayer"
  (defun _Stringify ( data / typ )
    (setq data
      (cond
        ( (eq :vlax-true  data) "Yes" )
        ( (eq :vlax-false data) "No"  )
        ( data )
    (cond
      ( (eq 'STR (setq typ (type data)))
        data
      ( (eq 'INT typ)
        (itoa data)
      ( (eq 'REAL typ)
        (rtos data)
      ( (vl-princ-to-string data) )
  (defun _Display ( Cir Tx ss mode / cObj cSs iObj aStr iLst tStr cnt tStr )
    (setq cObj (vlax-ename->vla-object Cir) aStr "")
    (cond
        (or (not ss) (= (sslength ss) 0))
      ( (setq iObj
          (vl-some
            (function
              (lambda ( obj )
                (if (vlax-invoke obj 'IntersectWith cObj acExtendNone) obj)
            (ss->lst ss)
        (setq iLst (entget (vlax-vla-object->ename iObj)))
        (vla-put-Color cObj acRed)
        (cond
            (zerop mode)
            (cond
                (eq "INSERT" (dxf 0 iLst))
                (if (setq cSs (ssget "_X" (list (cons 0 "INSERT") (cons 2 (_GetName iObj)))))
                  (setq cnt (itoa (sslength cSs)))
                (if (= 1 (dxf 66 iLst))
                  (progn
                    (setq aStr "\nATTRIBUTES: \n{\\fArial|b0|i0|c0|p34;")
                    (foreach x (vlax-invoke iObj 'GetAttributes)
                      (setq aStr (strcat aStr (vla-get-TagString x)  ":  " (vla-get-TextString x) "\n"))
                    (setq aStr (strcat aStr "}"))
                (setq tStr
                  (strcat
                    "{\\C4;"         (dxf 0 iLst) "}"
                    "\nNAME:  "      (_GetName iObj)
                    (if cnt (strcat "\nINSTANCES:  " cnt) "")
                    "\nLAYER:  "     (dxf 8 iLst)
                    "\nCOLOR:  "     (_GetColour iLst)
                    "\nLINETYPE:  "  (vlax-get-property iObj 'Linetype)
                    "\nLINEWEIGHT:  "(_GetLW iLst)
                    "\nROTATION:  "  (angtos (dxf 50 iLst))
                    "\nSCALE:  "     (_GetScale iLst)
                    "\nDYNAMIC: "    (_Stringify (vlax-get-property iObj 'isDynamicBlock))
                    "\nXREF:  "      (_Stringify (vlax-get-property (vla-item (vla-get-Blocks doc) (_GetName iObj)) 'ISXREF))
                    aStr
              (t
                (setq tStr (strcat "{\\C4;" (dxf 0 iLst) "}"))
                (foreach prop
                    LAYER
                    COLOR
                    LINETYPE
                    LINEWEIGHT
                    ALIGNMENT
                    ARCLENGTH
                    AREA
                    ATTACHMENTPOINT
                    CENTER
                    CIRCUMFERENCE
                    CLOSED
                    CUSTOMSCALE
                    DEGREE
                    DIAMETER
                    DISPLAYLOCKED
                    ELEVATION
                    HEIGHT
                    LENGTH
                    MEASUREMENT
                    OBLIQUEANGLE
                    RADIUS
                    ROTATION
                    SCALEFACTOR
                    STYLENAME
                    TEXTOVERRIDE
                    TEXTSTRING
                    TOTALANGLE
                    WIDTH
                  (setq tStr
                    (strcat tStr
                      (if
                        (and
                          (vlax-property-available-p iObj prop)
                          (not (eq "" (vlax-get iObj prop)))
                        (strcat "\n"
                          (strcase (vl-princ-to-string prop)) ":  "
                          (cond
                              (eq prop 'COLOR)
                              (_GetColour iLst)
                              (vl-position prop '(DISPLAYLOCKED CLOSED))
                              (_Stringify (vlax-get-property iObj prop))
                              (eq prop 'ALIGNMENT)
                              (cdr (assoc (vlax-get-property iObj prop) Alignment))
                              (eq prop 'ATTACHMENTPOINT)
                              (cdr (assoc (vlax-get-property iObj prop) Attachment))
                              (or
                                (and
                                  (eq 'MEASUREMENT prop)
                                  (vl-position (vla-get-ObjectName iObj) '("AcDb2LineAngularDimension" "AcDb3PointAngularDimension"))
                                (and
                                  (eq 'TOTALANGLE prop)
                                  (eq "AcDbArc" (vla-get-ObjectName iObj))
                                (eq 'ROTATION prop)
                              (angtos (vlax-get iObj prop))
                              (eq prop 'LINEWEIGHT)
                              (_GetLW iLst)
                              (_Stringify (vlax-get iObj prop))
            (_Update
              (_PutDxf
                (_PutDxf (entget tx) 62 251) 1 (_Text tStr)
            t
      (t )
    iObj
  (defun dxf ( code lst ) (cdr (assoc code lst)))
  (defun PurgeLayer ( layer )
    (if
      (not
          (setq layer
            (vl-catch-all-apply 'vla-item
              (list
                (vla-get-layers
                layer
      (vl-catch-all-apply 'vla-delete (list layer))
  (defun RedrawSS ( ss mode )
      (lambda ( i )
        (while (setq e (ssname ss (setq i (1+ i))))
          (redraw e mode)
      -1
  ;;                           --=={  Main Function  }==--                         ;;
  (setq cEnt
    (entmakex
      (list
        (cons 0 "CIRCLE")
        (cons 8 "LMAC_DINFO")
        (cons 10 (getvar 'VIEWCTR))
        (cons 40 (setq rad (/ (getvar 'VIEWSIZE) (float DInfo:cRad))))
        (cons 62 3)
    cELst (entget cEnt)
  (setq tEnt
    (entmakex
      (list
        (cons 0 "MTEXT")
        (cons 100 "AcDbEntity")
        (cons 100 "AcDbMText")
        (cons 1  (_Text (nth DInfo:Mode ModeLst)))
        (cons 40 (/ (getvar 'VIEWSIZE) 60.0))
        (cons 50 0.0)
        (cons 62 71)
        (cons 71 1)
        (cons 90 3)
        (cons 63 256)
        (cons 45 1.2)
    tElst (entget tEnt) -pi/4 (/ pi -4.) pi/4 (/ pi 4.) 5pi/4 (/ (* 5 pi) 4.)
  (setq msgLst
   '("\n[TAB Mode] [+/- Cursor Size] Move Cursor Over Objects to Retrieve Information..."
     "\n[TAB Mode] [+/- Cursor Size] Click Object to Isolate Layer, Shift+Click to Turn on All Layers..."
  (princ (setq msg (nth DInfo:Mode msgLst)))
  (while
    (progn
      (setq gr (grread 't 15 1) code (car gr) data (cadr gr) vs (getvar 'VIEWSIZE))
      (cond
          (and (= 5 code) (listp data))
          (setq r (sqrt (* 2. rad rad)))
          (setq cEnt
            (_Update
              (setq cELst
                (_PutDxf (_PutDxf cELst 10 data) 40 (setq rad (/ vs (float DInfo:cRad))))
          (setq tEnt
            (_Update
              (setq tELst
                (_PutDxf
                  (_PutDxf tELst 10 (polar (polar data -pi/4 rad) 0 (/ vs 90.0))) 40 (/ vs 60.0)
          (if (setq ss (ssget "_C" (polar data  pi/4 r) (polar data 5pi/4 r)))
            (progn
              (ssdel cEnt ss)
              (ssdel tEnt ss)
              (setq Inter (_Display cEnt tEnt ss DInfo:Mode))
          t
          (= 2 code)
          (cond
              (vl-position data '(43 61))
              (if (> DInfo:cRad 1.0)
                (setq cEnt
                  (_Update
                    (setq cELst
                      (_PutDxf cELst 40
                        (setq rad (/ vs (float (setq DInfo:cRad (1- DInfo:cRad)))))
                (princ (strcat "\n** Maximum Cursor Size Reached **" msg))
              (= 45 data)
              (setq cEnt
                (_Update
                  (setq cELst
                    (_PutDxf cELst 40
                      (setq rad (/ vs (float (setq DInfo:cRad (1+ DInfo:cRad)))))
              (= 9 data)
              (setq DInfo:Mode (rem (1+ DInfo:Mode) 2))
              (setq tEnt
                (_Update
                  (setq tELst
                    (_PutDxf tELst 1 (_Text (nth DInfo:Mode ModeLst)))
              (vl-position data '(13 32)) nil
            ( t )
          (and (= 3 code) (listp data) (= 1 DInfo:Mode))
          (if (and Express (acet-sys-shift-down))
            (mapcar
              (function
              on
            (if (and Inter (not (eq "LMAC_DINFO" (vla-get-layer Inter))))
              (mapcar
                (function
                  (lambda ( x )
                    (if (not (eq (strcase (vla-get-layer Inter)) (strcase (vla-get-name x))))
                      (vla-put-layeron x :vlax-false)
                layers
          t
  (mapcar 'entdel (list tEnt cEnt))
  (princ)
(princ)
(princ "\n:: DInfo.lsp | Version 1.5 | ?Lee Mac 2011 ::")
(princ "\n:: Type \"DInfo\" to Invoke ::")
(princ)
;;                             End of Program Code                               ;;
已领礼包: 2个
发表于 2019-7-23 14:53:23 | 显示全部楼层
    (setq mpt  pt2)
     ;(setq mpt (mapcar (function (lambda (x y) (/ (+ x y)2.0))) pt1 pt2))
    (setq ang (+ (angle pt1 pt2) (/ pi 2))  v (polar '(0 0 0) ang 1)  )
    (entmake (list
     '(0 . "XLINE")
    '(62 . 1)
  (princ)
已领礼包: 2个
发表于 2019-7-23 15:24:05 | 显示全部楼层
(DEFUN C:xv ()
  (command "xline" "v")
已领礼包: 50个
 楼主| 发表于 2019-7-23 18:09:22 | 显示全部楼层
    (setq pt2 (getpoint p ...
非常感谢您的帮助!
GMT+8, 2026-11-4 08:17 , Processed in 0.580220 second(s), 35 queries , Gzip On.
