查看: 1476|回复: 4
[求助] 请教大神双边偏移功能
发表于 2019-7-25 08:11:40 | 显示全部楼层 |阅读模式
  1. (defun C:af (/ ss1 entName1 OffDist n i sPt Pt1 Pt2 tAngle IsDelete IsCurLayer oldOSnap)
  2. ;(CMDINIT0);保存用户系统变量.
  3. (vl-load-com)
  4. (setq oldOSnap (getvar "OSmode"))
  5. (if (= #AY_OFF2ISDELETE nil) (setq #AY_OFF2ISDELETE "N"))
  6. (if (= #AY_OFF2ISCURLAYER nil) (setq #AY_OFF2ISCURLAYER "N"))
  7. (initget "S" 0)
  8. (setq OffDist (getdist (strcat "\n设置(S)/指定单向偏移距离<" (rtos (getvar "offsetdist")) ">:")))
  9. (if (= (Type OffDist) 'STR)
  10. (progn
  11. (initget "Y N")
  12. (setq IsDelete (getkword (strcat "\n是(Y)/否(N)删除原曲线对象?<" #AY_OFF2ISDELETE ">:")))
  13. (if (Null IsDelete) (setq IsDelete #AY_OFF2ISDELETE) (setq #AY_OFF2ISDELETE IsDelete))
  14. (initget "Y N")
  15. (setq IsCurLayer (getkword (strcat "\n是(Y)/否(N)将偏移后的对象置到当前层?<" #AY_OFF2ISCURLAYER ">:")))
  16. (if (Null IsCurLayer) (setq IsCurLayer #AY_OFF2ISCURLAYER) (setq #AY_OFF2ISDELETE IsCurLayer))
  17. (setq OffDist (getdist (strcat "\n指定单向偏移距离<" (rtos (getvar "offsetdist")) ">:")))
  18. );end_progn
  19. );end_if
  20. (if (null OffDist) (setq OffDist (getvar "offsetdist")));
  21. (setq ss1 (ssget ))
  22. (setq n (sslength ss1))
  23. (setq i 0)
  24. (setvar "osmode" 0)
  25. (while (< i n)
  26. (setq entName1 (ssname ss1 i))
  27. (setq sPt (vlax-curve-getStartPoint entName1))
  28. (setq tAngle (angle '(0.0 0.0 0.0) (vlax-curve-getFirstDeriv entName1
  29. (vlax-curve-getparamatpoint entName1
  30. (vlax-curve-getclosestpointto entName1 sPt)))))
  31. (setq Pt1 (polar sPt (+ tAngle (/ pi 2.0)) OffDist))
  32. (setq Pt2 (polar sPt (- tAngle (/ pi 2.0)) OffDist))
  33. (command "_.OFFSET" OffDist entName1 Pt1 "")
  34. (if (= IsCurLayer "Y")
  35. (progn
  36. (setq ent1 (entget (entlast)))
  37. (setq ent1 (subst (cons 8 (getvar "clayer")) (assoc 8 ent1) ent1))
  38. (entmod ent1)
  39. );end_progn
  40. );end_if
  41. (command "_.OFFSET" OffDist entName1 Pt2 "")
  42. (if (= IsCurLayer "Y")
  43. (progn
  44. (setq ent1 (entget (entlast)))
  45. (setq ent1 (subst (cons 8 (getvar "clayer")) (assoc 8 ent1) ent1))
  46. (entmod ent1)
  47. );end_progn
  48. );end_if
  49. (if (= IsDelete "Y") (command"_.Erase" entName1 ""))
  50. (setq i (1+ i))
  51. );end_while
  52. (setvar "osmode" oldOSnap)
  53. (princ)
  54. ;(CMDINIT1);恢复用户系统变量.
  55. );end_defun
上面是网上找到双边偏移代码,能否实现双边偏移后把中间线(箭头所指的线)删除掉。
最后重点把堵头封死。
谢谢大神,谢谢大神,谢谢大神!!!
发表于 2019-7-25 09:10:21 | 显示全部楼层
(defun C:af (/ ENT1 ENTNAME1 I N OFFDIST OLDOSNAP PT1 PT2 SPT SS1 TANGLE XT1 XT2 XT3 XT4)
(vl-load-com)
(setq ss1 (ssget ))
(setq i 0)
(setvar "osmode" 0)
(while (< i n)
(entmod ent1);end_if
(setq xt1 (cdr (assoc 10 ent1)))
(setq xt2 (cdr (assoc 11 ent1)))
(setq xt3 (cdr (assoc 10 ent1)))
(setq xt4 (cdr (assoc 11 ent1)))
(entmake (list '(0 . "Line") (cons 10 xt1) (cons 11 xt3) (cons 8 (cdr (assoc 8 ent1)))))
(entmake (list '(0 . "Line") (cons 10 xt2) (cons 11 xt4) (cons 8 (cdr (assoc 8 ent1)))))
(setq i (1+ i))
);end_while
(princ)
;;;;按你
 楼主| 发表于 2019-7-25 09:56:27 | 显示全部楼层
(vl-load- ...
大佬。您写的这个一根线一根线的好像没问题。但是批量选择多根线就出现BUG了。
发表于 2019-7-25 10:54:19 | 显示全部楼层
(defun c:ml( / temposm sx att pt10 pt11 pt1 pt2 attpro nprolst)
        (setq temposm (getvar "osmode"))
        (setq sx (getdist "\n双线间距(mm):"))
        (while (setq sset (ssget))
            (command "undo" "be")
            (setvar "osmode" 0)
            (setq i -1)
            (while        (setq att (ssname sset (setq i (1+ i))))
                (setq attpro (entget att))
                (setq nprolst (list (cons 0 "LINE") (assoc 8 attpro)))
                (if (assoc 62 attpro) (setq nprolst (append nprolst (list (assoc 62 attpro)))))
                (if (assoc 6 attpro) (setq nprolst (append nprolst (list (assoc 6 attpro)))))
                (setq pt10 (cdr (assoc 10 attpro)))
                (setq pt11 (cdr (assoc 11 attpro)))
                (setq pt1 (polar pt10 (- (angle pt10 pt11) (/ pi 2)) (* 0.5 sx)))
                (setq pt2 (polar pt10 (+ (angle pt10 pt11) (/ pi 2)) (* 0.5 sx)))
                (setq pt3 (polar pt11 (- (angle pt10 pt11) (/ pi 2)) (* 0.5 sx)))
                (setq pt4 (polar pt11 (+ (angle pt10 pt11) (/ pi 2)) (* 0.5 sx)))
                (command "move" att  "" pt10 pt1)
                (command "copy" att "" pt1 pt2)
                (entmake (append nprolst (list (cons 10 pt1) (cons 11 pt2))))
                (entmake (append nprolst (list (cons 10 pt3) (cons 11 pt4))))
            )        (command "undo" "e")(setvar "osmode" temposm)
        ) (princ)
发表于 2019-7-29 19:02:42 来自手机 | 显示全部楼层
求助的人怎么没有反馈
来自: 微社区
GMT+8, 2026-11-22 09:55 , Processed in 0.379040 second(s), 18 queries , Gzip On, File On.
