查看: 1499|回复: 0
[求助] 外部参照和块参照的区分
发表于 2019-9-4 15:50:08 | 显示全部楼层 |阅读模式
  1. void AcDbReactorApdDatabase::objectAppended(const AcDbDatabase* dwg, const AcDbObject* dbObj)
  2. {
  3.         if (dwg != acdbHostApplicationServices()->workingDatabase())
  4.                 return;
  5.         if (dbObj->isKindOf(AcDbBlockReference::desc()))
  6.         {
  7.                 AcDbBlockTable *pBlockTable;
  8.                 acdbHostApplicationServices()->workingDatabase()
  9.                         ->getSymbolTable(pBlockTable, AcDb::kForRead);
  10.                 AcDbBlockTableIterator* pBTIter = NULL;
  11.                 Acad::ErrorStatus es = pBlockTable->newIterator(pBTIter);
  12.                 if (Acad::eOk != es)
  13.                 {
  14.                         pBlockTable->close();
  15.                         return;
  16.                 }
  17.
  18.                 for (; !pBTIter->done(); pBTIter->step())
  19.                 {
  20.                         AcDbBlockTableRecordIterator* pBTRIter = NULL;
  21.                         AcDbBlockTableRecord* pRecord = NULL;
  22.                         es = pBTIter->getRecord(pRecord, AcDb::kForRead);
  23.                         if (es != Acad::eOk)
  24.                         {
  25.                                 pRecord->close();
  26.                                 return;
  27.                         }
  28.                         es = pRecord->newIterator(pBTRIter);
  29.                         if (Acad::eOk != es)
  30.                         {
  31.                                 return;
  32.                         }
  33.                         for (; !pBTRIter->done(); pBTRIter->step())
  34.                         {
  35.                                 AcDbEntity* pEntity = NULL;
  36.                                 pBTRIter->getEntity(pEntity, AcDb::kForRead);
  37.                                 if (pEntity == dbObj)
  38.                                 {
  39.                                         pBTR = pRecord;
  40.                                         bool b = pBTR->isFromExternalReference();
  41.                                         const ACHAR* pPathName;
  42.                                         pBTR->pathName(pPathName);
  43.                                         break;
  44.                                 }
  45.                         }
  46.                         pRecord->close();
  47.                         if (pBTR)
  48.                         {
  49.                                 break;
  50.                         }
  51.                 }
  52.                 pBlockTable->close();
  53.         }
  54. }
复制代码
添加外部参照,触发数据库反应器,我用 pBTR->isFromExternalReference()判断块是否是外部参照,返回的一直是false,不太明白,难道不是这么用的,求大神指点一下
GMT+8, 2026-11-22 08:54 , Processed in 0.305468 second(s), 8 queries , Gzip On, File On.
