查看: 1429|回复: 1
[求助] 递归求得块内实体,得不到嵌套块的原因
已领礼包: 58个
发表于 2019-9-5 10:40:37 | 显示全部楼层 |阅读模式
(defun gx:block:vlaobjlst (e / lst blks acadObj doc)
  (setq acadObj (vlax-get-acad-object))
  (setq doc (vla-get-ActiveDocument acadObj))
  (setq blks (vla-get-blocks doc))
  (vlax-for each (vla-item blks
      (vla-get-name e)
    (if (EQ (vla-get-objectname each) "AcDbBlockReference")
      (gx:block:vlaobjlst each)
      (setq lst (cons each lst))
  lst
请专家帮忙看看
发表于 2021-2-5 23:03:33 | 显示全部楼层
(if (EQ (vla-get-objectname each) "AcDbBlockReference")       (gx:block:vlaobjlst each)       (setq lst (cons each lst))     )这句的意思就是,不是块才记录到st里面,所以最终返回的表lst,里面没有块,只有普通图元
GMT+8, 2026-11-3 09:23 , Processed in 0.531998 second(s), 31 queries , Gzip On.
