查看: 1005|回复: 1
[求助] 请大神帮忙修改一下代码,因为旋转UCS坐标后,就不行了,谢谢
发表于 2019-10-17 15:33:05 | 显示全部楼层 |阅读模式
(defun c:zx (/ ang mpt pt1 pt2 v)
        (setq pt1 (getpoint "指定第一点"))
        (setq pt2 (getpoint pt1 "指定第二点"))
        (setq mpt (mapcar (function (lambda (x y) (/ (+ x y)2.0))) pt1 pt2))
        (setq
                ang (+ (angle pt1 pt2) (/ pi 2))
                v (polar '(0 0 0) ang 1)
        (entmake (list
                                                 '(0 . "XLINE")
                                                 '(100 . "AcDbEntity")
                                                 '(62 . 1)
                                                 '(100 . "AcDbXline")
                                                 (cons 10 (trans mpt 1 0))
                                                 (cons 11 (trans v 1 0))
  (princ)
已领礼包: 1268个
发表于 2019-10-17 23:13:33 | 显示全部楼层
  1. (defun c:zx (/ ang mpt pt1 pt2 v)
  2.   (if (and (setq pt1 (getpoint "指定第一点"))
  3.            (setq pt2 (getpoint pt1 "指定第二点"))
  4.       )
  5.     (progn
  6.       (setq mpt        (mapcar (function (lambda (x y) (/ (+ x y) 2.0))) pt1 pt2)
  7.             v        (trans (mapcar '- pt2 pt1) 1 0)
  8.       )
  9.       (entmake (list
  10.                  '(0 . "XLINE")
  11.                  '(100 . "AcDbEntity")
  12.                  '(62 . 1)
  13.                  '(100 . "AcDbXline")
  14.                  (cons 10 (trans mpt 1 0))
  15.                  (cons 11 (list (cadr v) (- (car v)) 0.0))
  16.                )
  17.       )
  18.     )
  19.   )
  20.   (princ)
  21. )
GMT+8, 2026-11-4 22:42 , Processed in 0.410417 second(s), 33 queries , Gzip On.
