查看: 964|回复: 0
[分享] 图层透明度设置方法vb.net
发表于 2019-12-1 10:56:57 | 显示全部楼层 |阅读模式
    <CommandMethod("tmdtest")> _
    Public Sub tmdtest()
        Dim transparency0 As Integer = 50   '相对透明度0-100百分比
        Dim alp As Byte = (255 * (100 - transparency0) / 100)
        Dim transparency1 As Transparency = New Transparency(alp) ‘转换为CAD标准Transparency类型
        Dim LyrTbl As LayerTable, LyrTblRec As LayerTableRecord
        Dim CurDB As Database = Application.DocumentManager.MdiActiveDocument.Database
        Using docLock As DocumentLock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument()
            Using Trans As Transaction = CurDB.TransactionManager.StartTransaction()
                LyrTbl = Trans.GetObject(CurDB.LayerTableId, OpenMode.ForRead)
                If LyrTbl.Has("0") Then  '此处以“0"层为样本,可根据需要在图面选择实体取得图层后修改
                    LyrTblRec = Trans.GetObject(LyrTbl("0"), OpenMode.ForWrite)
                    LyrTblRec.Transparency = transparency1 '修改图层透明度
                End If
                Trans.Commit()
            End Using
        End Using
    End Sub
GMT+8, 2026-11-3 00:13 , Processed in 0.491598 second(s), 28 queries , Gzip On.
