查看: 1493|回复: 4
[编程申请] 帮我修正下这个LSP为视频样子
发表于 2019-12-22 22:41:01 | 显示全部楼层 |阅读模式
(defun c:BZ (/ test0 test tmp int pt ss name pts p1 p9 pt1 pt2 ang ptlst h)
        (list '("cmdecho" 0 "osmode" 0) 0 nil)
        (setq TEST0 t)
        (while TEST0
                (princ "\n点取多段线直线边[取消(U)]: ")
                (setq TEST t)
                (while TEST
                        (setq TMP (grread t 4 2))
                        (cond
                                ;;按下键盘键或者击鼠标右键
                                ((or (= (car TMP) 2) (= (car TMP) 25))
                                        (setq INT (cadr TMP))
                                        (cond
                                                ;;回车,空格或者击鼠标右键,则退出
                                                ((or (= INT 13) (= INT 32) (= (car TMP) 25))
                                                        (setq TEST NIL
        TEST0        NIL
                                                ;;U选项
                                                ((or (= (ascii "u") INT) (= (ascii "U") INT))
                                                        (command "undo" "b")
                                                        (setq test nil)
                                ;;击左键
                                ((= (car TMP) 3)
                                        (setq pt (cadr TMP))
                                        (if (setq ss (ssget pt '((0 . "LWPOLYLINE"))))
                                                (progn
                                                        (setq name (ssname ss 0))
                                                        (if (tao-get-pl-entsel-type name pt)
        (progn
        (setq
        pts  (tao-get-ss-9pt name 19)
        p1   (nth 1 pts)
        p9   (nth 9 pts)
        pts(Tao-mindist-sort(trans pt 1 0)(tao-get-pl-entsel-pt name pt))
        pt1(trans(car pts)0 1)
        pt2(trans(cadr pts)0 1)
        ang(angle pt1 pt2)
        ptlst(Tao-get-viewextents)
        h(/(getvar "viewsize")35)
        (command "undo" "m")
        (tao-zoom-w p1 p9)
        (tao-zoom-s 0.8)
        (setq ss (ssget "c" (trans p1 0 1) (trans p9 0 1)))
        (command "rotate" ss "" pt1 (- 0 (rtd ang)))
        (setq pts  (tao-get-ss-9pt name 19))
        (tao-zoom-w (trans(car ptlst)1 0)(trans(cadr ptlst)1 0))
        (grvecs (list
        3
        (POLAR pt1 3.9270 h)
        (POLAR pt1 0.7854 h)
        3
        (POLAR pt1 2.356 h)
        (POLAR pt1 5.498 h)
        2
        pt1
        (POLAR pt1 ang (+(distance pt1 pt2)(* 2 h)))
        (setq test nil)
                                                (setq test nil)
)[sell=10][/sell]
视频
视频
发表于 2019-12-23 00:27:17 | 显示全部楼层
发表于 2019-12-24 14:31:50 | 显示全部楼层
对于奇葩的求助,只能掠过
发表于 2019-12-28 11:13:14 | 显示全部楼层
看看。。,,,路过
发表于 2020-1-7 14:45:01 | 显示全部楼层
谢谢楼主分享!!!!!!
GMT+8, 2026-11-22 08:55 , Processed in 0.151269 second(s), 18 queries , Gzip On, File On.
